AVS › AVS Forum › Display Devices › Display Calibration › Can I use a Spyder2 with my Projectore and PS3, Cable box, HTPC and upscaling DVD
post #1 of 4
Someone in another thread said the Spyder2 will only work for a HTPC. I have a HTPC, PS3, Upscaling DVD, and Cable box. All feed the projector via my Onkyo 905 and one HDMI input. Can I use the Spyder2 and the ColorHCFR software to calibrate all these devices?
post #2 of 4
HCFR with the Spyder2 can be used to calibrate your display without a HTPC involved. You do need a PC to run HCFR and plug the Spyder2 into it. Additionally, you need some manner to display specific test patterns (usually using a DVD) to accomplish the calibration.
If you happen to have a HTPC - it allows you to make use of HCFR on that PC, and HCFR has built in patterns eliminating the need for a pattern source (DVD).
You'll have trouble getting patterns from your cable box.
Additionally, as you use your receiver to feed the single HDMI - you'll need to make adjustments at your sources to make them as similar as possible.
I strongly suggest you read, and read, and read this forum for more details before you leap into a purchase.
Roo
post #3 of 4
Thanks, That's what I thought, but mis-information messed me up. I've also read that the spyder2 is not accurate and that it is. I would be a casual user and It's available for under $60 It seems like it would be worth trying at that price.
post #4 of 4
The Spyder2 is widely commented as being less accurate than some of the other low cost devices (under $150). However, there is a point of diminishing returns. Human vision is extremely forgiving, and small variations in accuracy are nearly impossible to spot.
None of the low cost sensors will give you a "perfectly calibrated" zero deltaE deviation image (it is reasonable to expect to be within 3 deltaE IMHO). Most, if not all, of them will not give useful readings below 30IRE.
My experience - as a non-professional - has been that the sensor based calibration has helped me do a better job than I could have ever done by eye. The resulting image has been pleasing, but did take some getting used to. I've had a lot of fun learning about the technology.
My approach is - use the sensor to tweak. Verify results by eye. Iterate until I'm happy with both the sensor readings, and how it looks.
Roo
