AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Denon 788/1908 + PS3 2-channel PCM = no DPLII layer?
post #1 of 6
I can't seem to be able to layer DPLII on 2 channel PCM sources coming from the PS3. Is this something that can't be done or am I missing something?
-Vic
post #2 of 6
It's something that can't be done easily. The ps3 encapsulates 2 channel audio inside a 5.1 or 7.1 multichannel pcm signal. It's not much of a solution, but if you disable all the multichannel modes, you can force it to output 2 channel pcm.
post #3 of 6
Okay, i think I see what you are saying... the only reason I was asking is because the downloadable movie trailers are 2 channel only and when I was using the optical I could just use DPLII, but when using hdmi, all I'm getting now is sound from the two front channels. I guess I'll just have to put up with it.
post #4 of 6
LOL.
Open the flip side of the remote, and choose your poison (Neo6, DPL2x) etc.. There's even a game mode.
Also check your HDMI audio settings in the PS3.
post #5 of 6
Originally Posted by eightninesuited View Post
LOL.
Nope. that's the problem. Even when pressing those, the sound still only comes from the front L, R, speakers when there's a 2 channel PCM signal coming from the PS3. Basically, you can't apply any of the surround modes. When there's a multi channel PCM signal, I'm good as it's already 5.1 so I don't have to do anything.
-Vic
post #6 of 6
The problem is with the PS3. It should output only 2 channels when playing 2 channel content. Instead it still sends out a 7.1 signal even when the content is only 2 channel. The 360 doesn't suffer from this problem.
And the PS3 should have never had this problem to begin with. Maybe one day Sony will fix it but I wouldn't hold my breath.
