AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Denon 3808/4308/5308 Firmware Tracking Thread
post #1 of 3803
WELCOME to the Denon 3808/4308/5308 Firmware Tracking Thread!
Thank you Denon for your continued development of firmware updates and upgrades for the 3808/4308/5308 receivers.
Firmware tracking WIKI most recent consolidated update.
Join the Denon 3808/4308/5308 firmware tracking WIKI: http://denon-firmware-tracking.wetpaint.com/
Create a login using your AVS login name.
WIKI Writers for each Denon model North America and Europe, Asia Pacific territories can update firmware version page logs, confirmed bugs/update issues and fixes/improvements page logs.
Denon owners: report your firmware module version numbers after update or FPU/update for Denon 3808/4308/5308. Along with your update or FPU/update firmware module version report post how you resolved or worked around any problems with the update, and fixes or improvements noticed. WIKI writers please update directly firmware logs upon firmware update.
Please keep your postings in this thread focused on your firmware version update report with your experience the updated firmware and performing the firmware update.
This thread is a firmware update and FPU/update version tracker, with release notes, confirmed outstanding issues list, and any issues people report with the firmware update process itself.
To purchase Feature Pack Upgrade (for FPU/updates) please visit Denon website beginning Oct 1, 2008 for information. Contact Denon technical support any questions concerning the Oct 2008 Feature Pack Upgrade.
For Feature Pack Upgrade discussion please use the "Owners" threads or thread: http://www.avsforum.com/avs-vb/showt...0#post14647710
Please use thread: http://www.avsforum.com/avs-vb/showthread.php?t=887746 for general discussion of bugs, undesired features, and enhancements desired for the 3808/4308 or other general discussion use one of the 3808, 4308, and 5308 "Owners" threads for these receivers.
Please be aware owner reports Denon technical support advises on or about September 9, 2008: "Also please remember that the firmware updates are made available so that if a user should be experiencing the problem that the firmware corrects they can have the "fix". However, if you are not experiencing these issues we do not advise that you update the receiver."
If you are not comfortable performing firmware updates or have questions about a particular update Denon makes available then contact Denon technical support for assistance. There is always a chance something could go badly requiring repair by Denon.
Take your time and carefully review Denon update instruction links, notes and tips below. Check Denon's web site for updated instruction as posted links can change at any time. You may wish to read through this entire thread and review what us owners are saying. Caveat emptor
1. Check and Record Firmware Module Versions
Checking firmware module versions for 3808/4308:
Behind front panel hold the 'return' and 'status' buttons down at the same time and turn on the receiver using small power button. Then release the 'return' and 'status' buttons and turn the receiver on using large power button. Then use 'status' button to cycle display firmware module versions.
Checking firmware module versions for 5308:
Behind front panel hold the 'dimmer' and 'status' buttons down at the same time and turn on the receiver using small power button. Then release the 'dimmer' and 'status' buttons and turn the receiver on using large power button. Then use 'status' button to cycle display firmware module versions.
Note: write down each of these firmware module versions prior to update and have available for reporting.
Note: World wide reports of firmware module changes 3808/4308/5308 requested.
Note: power cycle receiver using small power button after checking firmware module versions using above procedure when performed any time before or after update process. This will return 'status' button to normal operation.
2. Configuring Receiver on Network
How to configure networking for the 3808 receiver (Page 20, 32 users manual):
http://usa.denon.com/AVR-3808CI-OM-EU_200.pdf (posted 2/19/08)
How to configure networking for the 4308 receiver (Page 20, 32, 33 users manual):
http://usa.denon.com/AVR-4308CI-OM-E_208.pdf (posted 2/19/08)
How to configure networking for the 5308 receiver (Page 22, 35, 36 users manual):
http://usa.denon.com/AVR-5308CI-OM-E_003.pdf
Home Networking 101:
http://compnetworking.about.com/cs/h...menetguide.htm
3. Saving Receiver Configuration Before Update
BEFORE UPDATING (OR HARD RESET IF NEEDED AT ANY POINT) BE SURE TO SAVE YOUR CURRENT CONFIGURATION USING THE WEB INTERFACE (OPTION AVAILABLE SINCE 1.57 on 3808/4308). ALWAYS TRY COMPLETE POWER CYCLE USING SMALL POWER BUTTON SEEING IF PROBLEM GOES AWAY BEFORE HARD RESET (Miroprocessor Reset "Hard Reset" Instructions below).
Procedure for saving receiver configuration using Internet Explorer (Web page control not fully functional in very early firmware releases on 3808/4308):
1. Set the GUI menu "Manual Setup" - "Network Setup" - "Other" - "Power Saving" setting to "OFF"
2. Have the receiver powered up with the main Zone turned on.
3. In Internet Explorer go to http://XX.XX.XX.XX (XX.XX.XX.XX is IP address of receiver)
4. Press "Setup Menu"
5. Press "Save" (left hand side).
6. FL display "Saving" after POWER LED lit red.
7. Please wait about 5 minutes.
8. Select "save" in File Download dialog. Please use alphanumeric, do not use "space". Recommend using: C:\\denon\\configa.dat
9. Save is completed after file is downloaded.
10. Wait for receiver to restarted automatically.
Note: AVR is restarted automatically only if power saver option turned off.
Note: There have been reports of configurations saved incomplete. You may want to repeat the above procedure and save the receiver configuration several times using different file names. i.e. C:\\denon\\configa.dat , C:\\denon\\configb.dat , C:\\denon\\configc.dat
Note: When performing a restore use the same file location and name used when saving the configuration.
Note: Recommend saving receiver configuration again after update.
Note: Audyssey settings are saved. Internet radio presets are not saved.
Note: To load a saved configuration Press "load" (left hand side) of "Setup Menu". Follow instruction on page after pressing "load"
4. Performing the Firmware Update/Upgrade
NOTE: UPnP enabled on your network router may need disabled for update process to work correctly. Members have reported disabling UPnP on their router to resolve update and network connectivity problems with the receiver. Contact your the router manufacturer for instruction how to disable UPnP. If you do not disable UPnP on your router then you might try configuring receiver with static IP instead of DHCP prior to update or after update potentially fails.
NOTE: Recommended Methods to perform firmware update: Use GUI Interface via attached monitor, Use front display of the receiver. Perform firmware update using a hard wired Ethernet connection to the Internet (not wireless, power line or some other connection method).
Denon Knowledge Base article using wireless for firmware update: http://denon.custhelp.com/cgi-bin/denon.cfg/php/enduser/std_adp.php?p_faqid=288
NOTE: Power cycle the receiver using small power button prior to performing the update. Power cycling the receiver helps clear any anomalies that may exist causing problems with the update.
Follow these instructions for 3808/4308 update for firmware versions earlier then 1.57 (i.e. 1.28), Owner reports Denon USA support recommends using these instructions when updating:
Denon 3808 update instructions:
http://usa.denon.com/AVR-3808CIFirmw...te-Web1128.pdf
Denon 4308 update instructions:
http://usa.denon.com/AVR-4308CIFirmw...te-Web1128.pdf
Note: Owner reports needing to follow 'procedure #2' even though serial # greater then posted instruction and with receiver at firmware 1.28. Update successfully completed with receiver showing firmware 1.69.
Note: Per Denon instruction links posted, do not power cycle or reset the receiver when update in process.
Note: Per Denon instruction use Ethernet hard wired (not wireless, power line or some other connection method) connection when performing firmware updates.
Note: Power cycle receiver once update completed using small power button.
Note: Update circumstances can cause incomplete firmware module versions update. Once update completed check again for update showing 'latest', verify module versions updated.
User manual addendum Update/Upgrade instructions for 3808/4308/5308:
Denon 3808 update/upgrade sheet:
http://usa.denon.com/AVR-3808CI-OMSheet-E-PG36_000.pdf
Denon 4308 update/upgrade sheet:
http://usa.denon.com/AVR-4308CI-OMSheet-E-PG37_003.pdf
Denon 5308 update instructions page 41 user manual:
Denon 3808/4308 Feature Pack Upgrade instructions:
http://usa.denon.com/Feature_Upgrade_Instructions.pdf
FIRMWARE CHANGE LOGS:
See post #2: http://www.avsforum.com/avs-vb/showp...88&postcount=2
FIRMWARE VERSION MODULE CHANGE TRACKING:
See post #3: http://www.avsforum.com/avs-vb/showp...45&postcount=3
How to Hard Reset the Receiver
How to hard reset the 3808 receiver (Page 58 users manual):
http://usa.denon.com/AVR-3808CI-OM-E_103_R1.pdf
How to hard reset the 4308 receiver (Page 60 users manual):
http://usa.denon.com/AVR-4308CI-OM-E_101.pdf
How to hard reset the 5308 receiver (Page 74 users manual):
UPDATE STATS:
3808 Firmware main (1.69, 1.70, 1.73, 1.95, A1.94(FPU), 1.97, 2.01)
4308 Firmware main (1.69, 1.72, 1.95, A1.94(FPU), 1.97, 2.01)
5308 Firmware main (1.05, 1.57, 1.76, 1.77, 1.81)
Update experience statistics as of Nov 9, 2008 7:30PM EDT:
(42) owners report update completed losing or resetting configuration settings.
(452) owners report update completed.
(7) owners report having to send receiver in for repair under warranty or got replacement
Stats gather from WIKI site reporting thread and AVS reporting thread.
post #2 of 3803
Firmware tracking WIKI most recent consolidated update: http://denon-firmware-tracking.wetpaint.com/
Firmware Change Logs
Logs are in descending order. After performing update/upgrade the unit will be at *LATEST* for update or FPU/update and includes all previous updates.
Bugs/Upgrade Issues
are confirmed outstanding with *LATEST*
Fixed/Improved is cumulative to *LATEST*
*FPU/update for Feature Pack Upgraded units.
3808/4308 Firmware Version Tracking
Firmware version A2.01 *LATEST* Feature Pack Upgraded units only - 3808/4308 owners report (firmware FPU/update reported October 27, 2008 - for Denon territory North America and European)
BUGS/UPGRADE ISSUES
1. Web controller NET/USB Internet radio or local music server track information sometimes does not automatically update on web page when changes during play. Work around click on back arrow navigation control left of 'stop' button on Net Audio web page and wait for refresh.
2. Web controller Setup Menu, Information, Audio Input Signal displays incorrect format 3/3/.1 when should be 3/2/.1 as displayed in GUI interface.
3. GUI AutoSetup>ParameterCheck>DistanceCheck showing incorrectly 'Surr. Back' for 'Subwoofer' distance.
4. When playing Rhapsody tracks the TV display sometimes continues to show 'Connecting...' for track information. Workaround press GUI menu button twice for refresh. (USA feature pack upgraded models only)
5. Search by letter function not working in Rhapsody folders.
6. Web controller NET/USB unable to start Rhapsody 30 day trial access. Workaround start Rhapsody trial from GUI then use Web controller. (USA feature pack upgraded models only)
7. After update and running Audyssey calibration the speaker distance detection showing completely incorrect distances such as 0.1 for some or all speakers. This issue has occured with previous updates and is not exclusive to FPU/updates. The receiver will need serviced by Denon or you might see if your next update resolves.
FIXED/IMPROVED
Reported by Denon USA owner the following Denon change log and are fixed in firmware A2.01 reported available October 27, 2008:
- If Volume of the unit is operated when the voice changes from "DIRECT mode" to "Another mode" when "DynamicEQ mode" is selected, the level might become large.
- When the input signal is changed while displaying the Audyssey Setting screen of MENU, the key might not be able to be operated.
Note: For first time Feature Pack Upgrade also see firmware A1.94 change log below.
Firmware version 1.97 *LATEST* and A1.97 - 3808/4308 owners report (firmware update and FPU/update reported October 15, 2008 and October 20, 2008 - for Denon territory North America and European):
BUGS/UPGRADE ISSUES
4. Net Radio presets lost after update.
5. When playing Rhapsody tracks the TV display sometimes continues to show 'Connecting...' for track information. Workaround press GUI menu button twice for refresh. (USA feature pack upgraded models only)
7. When receiving 'connection failed' trying to update firmware Denon technical support advises on or about September 9, 2008 owner having Comcast ISP: "The reason why you are experiencing the "connection failed" when trying to access the firmware update is because Comcast takes much longer to make the connection than the receiver will allow. The AVR-3808CI will take about 30 hops before it times out waiting for the connection. While Comcast takes about 40 hops to connect. Therefore the connection is never made for the download. We are well aware of this issue and if there is a firmware update for comcast users we will make it available. You can take or send the unit to an authorized Denon service center and they will update the receiver with the latest firmware version. The other option, if possible, is to take the unit to a friend or relative's home where a different ISP is used. You will be able to complete the firmware update." Note: Based on Denon's explanation, this issue is not exclusive to Comcast and may be encountered with other ISP's or due to your ISP's current network traffic conditions when trying to update. Owner reports Denon support said they are working on this issue.
Denon Knowledge Base article connection failed message: http://denon.custhelp.com/cgi-bin/denon.cfg/php/enduser/std_adp.php?p_faqid=293
8. Owner reports incorrect assigned source inputs showing in GUI configuration after update. Workaround verify source input assignments and correct if needed.
FIXED/IMPROVED
1. Owner reports problem with speaker distance detection fixed after update and re-running Audyssey calibration.
Reported by Denon USA owner the following Denon change log and are fixed in firmware 1.97 reported available October 15, 2008:
- Translation mistake in German and other languages.
- The GUI and OSD of the A/V amplifier doesn't operate correctly when the A/V amplifier is connected with "iPhone 3G".
- Improvement of the Audyssey Dynamic Volume function. (For only PAY-Upgraded models.)
Firmware version A1.94 (Pay Upgrade - Feature Pack) - 3808/4308 owners report (firmware FPU/update reported October 1, 2008 for Denon territory North America and October 22, 2008 for Denon territory European):
BUGS/UPGRADE ISSUES
3. Audyssey calibration needed to enable new features Dynamic EQ and Dynamic Volume.
4. GUI AutoSetup>ParameterCheck>DistanceCheck showing incorrectly 'Surr. Back' for 'Subwoofer' distance.
7. HDMI assignment option missing from TV/CBL source input in GUI after update. Check HDMI control is turned off. Note: See page 17 user manual addendum: http://usa.denon.com/3843_Addendum_IM_008.pdf
8. Owner reports lost receiver settings for the currently active device (had renamed it to HDTV, changed default settings, etc), making only that one device reset to factory defaults. Reloaded saved configuration to restore it. Note: HDMI control turned ON the TV/CBL source assignment unavailable.
9. Update gets stuck and does not proceed sometimes several hours. Owner power cycled receiver using small power button to complete update. Note: Do not power cycle receiver while receiver is updating. Be patient, receiver can take extended period of time to complete update.
FIXED/IMPROVED
1. The 'para' remote control button (except with source NET/USB) cycles between Dynamic EQ / Dynamic Volume ON/OFF
2. GUI menu Paramters>Audio>Audyssey for changing Audyssey settings and Dynamic Volume midnight/evening/day settings.
3. HDMI control set to ON now enables powered off HDMI pass through.
4. Source select and quick select IR commands now power the unit on.
5. GUI menu OptionSetup>GUI>MasterVolume can now be set to bottom, top, or off.
6. Repeat and Random added for Music Server and Rhapsody.
7. Owner reports sound is much more rich and immersive after re-running audyssey setup. Note: Audyssey Dynamic EQ turned on by default after Audyssey calibration.
8. Owner reports improved HDMI operation with Sony TV. Note: This reported improvement may or may not resolve HDMI issues you might be having with a Sony TV.
Feature Pack Upgrade (FPU/update 3808/4308 USA owners manual addendum: http://usa.denon.com/3843_Addendum_IM_008.pdf):
- SIRIUS Ready (North America only)
- Rhapsody Ready (Rhapsody 30 day free trial, USA only)
- Audyssey Dynamic Volume
- Audyssey Dynamic EQ
- HDMI Control
Note: Receiver must be updated to firmware 1.95 or higher prior to upgrade. To purchase Feature Pack Upgrade (for firmware FPU/updates) please visit Denon website beginning Oct 1, 2008 for information. Contact Denon technical support any questions concerning the Oct 2008 Feature Pack Upgrade.
Firmware version 1.95, GUI DAT = 37750019 - Denon territory European only - 3808/4308 owners report (firmware update reported September 28, 2008):
BUGS/UPGRADE ISSUES
3. Receiver continues to display album art image with screen saver turned on and active (4308 only).
4. When receiving 'connection failed' trying to update firmware Denon technical support advises on or about September 9, 2008 owner having Comcast ISP: "The reason why you are experiencing the "connection failed" when trying to access the firmware update is because Comcast takes much longer to make the connection than the receiver will allow. The AVR-3808CI will take about 30 hops before it times out waiting for the connection. While Comcast takes about 40 hops to connect. Therefore the connection is never made for the download. We are well aware of this issue and if there is a firmware update for comcast users we will make it available. You can take or send the unit to an authorized Denon service center and they will update the receiver with the latest firmware version. The other option, if possible, is to take the unit to a friend or relative's home where a different ISP is used. You will be able to complete the firmware update." Note: Based on Denon's explanation, this issue is not exclusive to Comcast and may be encountered with other ISP's or due to your ISP's current network traffic conditions when trying to update. Owner reports Denon support said they are working on this issue.
FIXED/IMPROVED
Reported by Denon USA owner the following Denon change log and are fixed in firmware 1.95, GUI DAT = 37750019 reported available September 28, 2008:
- Translation mistake in German.
- Translation mistake in French.
- Translation mistake in Swedish.
Note: To purchase Feature Pack Upgrade (for firmware FPU/updates) please visit Denon website beginning Oct 1, 2008 for information. Contact Denon technical support any questions concerning the Oct 2008 Feature Pack Upgrade.
Firmware version 1.95 - 3808/4308 owners report (firmware update reported September 17, 2008 for Denon territory North America and European):
BUGS/UPGRADE ISSUES
4. Most owners report Net Radio and HD Radio presets lost after update of 3808/4308.
5. Owner reports receiver repeated retries to complete 'Ethernet IM' module update after turning off UPnP on router, performing a hard reset and choosing update again.
6. Owner reports iPod dock (ASD-1R) stopped working. Power down the iPod dock and turn the receiver off (small power button). Power up iPod dock and then power up receiver and configure receiver settings for iPod dock input source.
8. Owner of 3808 reports updating from firmware main 1.73 losing configuration settings. Was able to restore configuration settings from saved configuration.
9. Owner reports update stuck at "Sflash Firm34min, Updating" showing on display. Patiently waited several hours, power cycled, receiver resumed and completed update. Another owner reports unable resume update stuck showing "Sflash Firm34min, Updating" after patiently waiting several hours and power cycling; replacement receiver updated.
FIXED/IMPROVED
1. When stopping a radio station stream by holding down the enter button on the remote the display does not return and show folder station list. Holding down enter button to stop stream the display now returns to station folder list.
2. When a song is paused, browsing music server or USB folders behaves erratically. Browsing now works when pausing song.
3. When receiver NET/USB music server playback of MP3's that have UTF-16 formatted tags last letter missing of title, album, artist. Last letter now displays for UTF-16 formatted tags.
4. Internet radio continues to actively stream when receiver turned off (large power button, standby mode) and power saver turned off. This behavior is now the same for both Internet Radio and Local Music server streaming with power saver turned off.
5. Net Radio and Music server track information right to left scrolling shows up to 65 characters on receiver front display but only up to 53 characters on TV display before being cut off. Now same number of characters.
6. Improvements with JPEG album art handling (4308 only).
Reported by Denon USA and Denon European owner the following Denon change log info and are fixed in firmware 1.95 reported available September 17, 2008 for 3808/4308:
- The unit does not come back to the last state of playback when we turn off the power during playback Internet radio then turn on.
- The customer has connected a "USB-Stick memory" with more than 4GB. Random-function of USB devices is not active.
- Drop-outs via Ethernet playback from PC with "Windows Vista".
- Addition of up-grade function for Pay-upgrade. Note: Receiver must be updated to firmware 1.95 or higher prior to upgrade. To purchase Feature Pack Upgrade (for firmware FPU/updates) please visit Denon website beginning Oct 1, 2008 for information. Contact Denon technical support any questions concerning the Oct 2008 Feature Pack Upgrade.
Firmware version 1.73, Sub 00.88 (3808) and Firmware version 1.72, Sub 00.88 (4308) - 3808/4308 owners report (firmware update reported August 18, 2008 for 3808 and August 8, 2008 for 4308):
BUGS/UPGRADE ISSUES
1. When stopping a radio station stream by holding down the enter button on the remote the display does not return and show folder station list. Work around press down arrow after stopping the radio station to display folder station list or use the stop button (found on the second smaller remote).
2. When a song is paused, browsing music server or USB folders behaves erratically. Should either browse correctly or not allow browsing when song is paused. Do not pause a song and browse music server or USB folders.
3. When receiver NET/USB music server playback of MP3's that have UTF-16 formated tags last letter missing of title, album, artist. Work around convert existing MP3's to tag format ID3v2.3 ISO-8859-1 using utility program such as: http://www.mp3tag.de/en/
http://www.anytag.de/forums/index.ph...76&hl=mp3+tags
6. Some owners report hearing noise from speakers during this update. This has been reported to Denon technical.
7. Sometimes sporadic video sync loss with devices when using parallel HDMI and SVideo or component connections. This has been an issue with all firmware versions. Possible work around unplug SVideo or component connections for those devices and use HDMI only.
8. Some owners report losing audio and video after this update from previous update. Hard reset and configuration restore did not resolve. Work around hard reset the receiver after this update and redo all settings.
9. Net Radio and HD Radio presets lost after update.
10. When receiving 'connection failed' trying to update firmware Denon technical support advises on or about September 9, 2008 owner having Comcast ISP: "The reason why you are experiencing the "connection failed" when trying to access the firmware update is because Comcast takes much longer to make the connection than the receiver will allow. The AVR-3808CI will take about 30 hops before it times out waiting for the connection. While Comcast takes about 40 hops to connect. Therefore the connection is never made for the download. We are well aware of this issue and if there is a firmware update for comcast users we will make it available. You can take or send the unit to an authorized Denon service center and they will update the receiver with the latest firmware version. The other option, if possible, is to take the unit to a friend or relative's home where a different ISP is used. You will be able to complete the firmware update." Note: Based on Denon's explanation, this issue is not exclusive to Comcast and may be encountered with other ISP's or due to your ISP's current network traffic conditions when trying to update. Owner reports Denon support said they are working on this issue.
FIXED/IMPROVED
Reported by Denon USA owner and Denon European 4308 owner the following Denon change log info and are fixed in firmware 1.73, Sub 00.88/1.72, Sub 00.88 reported available August 18, 2008 for 3808 and August 8, 2008 for 4308:
- Last 2-pixel cropping at 1080p.
- Several pixels on the right hand side of the image are apparently gone or have been replaced with different information at 1080p.
- Sound (DAB) is distorted extremely loudly and totally in Zone 2. (European 4308 only)
Firmware version 1.73 (3808) and Firmware version 1.72 (4308) - 3808/4308 owners report (firmware update reported July 4, 2008):
BUGS/UPGRADE ISSUES
5. Net Radio presets lost after update.
6. Net Radio and Music server track information right to left scrolling shows up to 65 characters on receiver front display but only up to 53 characters on TV display before being cut off.
7. Owners report firmware update hanging when receiver display shows flash updating needing to power cycle receiver to complete the firmware update. Be patient and do not power cycle if the receiver is proceeding with the update which can take a while.
8. Owners report 4308 built-in wireless adapter WPA2 wireless encryption not establishing connection with wireless router after this update. Work around retype encryption key on receiver.
9. Owners report unable to restore previous saved configuration after this update and having done hard reset clearing all settings. Make sure unit is powered up using large power button and try Firefox version 2.0 or newer.
FIXED/IMPROVED
1. Web page control after selecting 'save' under 'setup' menu the top of the page said "Save Configration" now spelled correctly 'Save Configuration'
2. Web page control seems more responsive.
3. Receiver boots up more quickly after this update then it did when loaded with much earlier firmware main 1.28 version.
Reported by Denon USA and German owners the following Denon change log and are fixed in firmware 1.73/1.72 reported available July 4, 2008:
- Setup wrong translation in German.
- Problem for Tuner preset memory.
- Scroll speed of "Artist" becomes slow when playback music files with DLNA by network-audio.
- There is no direct "Tuner FM" or "Tuner AM" command (if customer issues tuner command twice accidentally, tuner band will change. This is an issue from an ease of use point of view)
- MVUP/down (master volume up/down) command can effect zone 2 volume if any zone 2 command has been recently sent. (MVUP command should only effect MAIN ZONE, regardless of what happens in zone 2. IR commands do not exhibit this behavior)
- Even when the function that allocates DENON Link is not used with MAIN ZONE, a digital signal is not output from ZONE-2 and ZONE-3.
- The disc where "DolbyDigital" and "TrueHD" are alternately recorded is play backed. And, when "DolbyDigital" and "TrueHD" are continuously changed, the sound is not outputted.
- When a specific stream sound source of "DTS-HD MA 7.1ch" is play backed by "5.1ch", the sound is distorted.
Firmware version 1.70 - 3808 owners report (firmware main 1.70 module updates released April 24, 2008. This firmware version module update was released only for European 3808 owners):
BUGS/UPGRADE ISSUES
1. When starting Internet Radio station play and song track information broadcast sometimes the Radio station information appears briefly in song track location, is replaced by current song information, and does not display in station information location (could be station specific). When this happens song track information does not update when song changes. You can press the left arrow, wait a few seconds, and it will then show the current song track and Radio station playing (song track information will then update when song changes).
4. Web page control after selecting 'save' under 'setup' menu the top of the page says "Save Configration"
5. Internet radio continues to actively stream when receiver turned off (large power button, standby mode).
6. German, Australia, England, French DTS HD HR titles showing incorrectly stereo signal on receiver. Signal not being decoded correctly by receiver.
7. Internet radio presets are lost after update.
8. After initiating firmware update receiver displays "Please Wait..." and does not proceed with update process after waiting extended period of time (i.e. 20 minutes waiting and still message "Please Wait..."). Power cycle receiver using small power button then retry update. Do not power cycle receiver when update in process!
9. Owner reports Denon working on firmware update to resolve disk issue encountered with New Line Cinema Golden Compass which uses different flagging. Issue encountered when down converting to 5.1
10. USB Random music play gets stuck in folders.
Note: If you are unable to update you might contact Denon support for advise, have a network technician pay you a visit, or try updating using a different ISP.
FIXED/IMPROVED
1. Except when #1 listed above occurs - Internet radio now displays correct track information when song changes for stations broadcasting song track. Album information also displayed correctly and changes when broadcast.
2. Web page control 'setup' menu spelling corrected "INFOMATION" now says "INFORMATION".
3. Surround sound quality seems improved.
4. When there are two rear surround speakers with 7.1 configuration the web interface now shows two rear surrounds. Was showing incorrectly only one rear surround speaker in web interface.
5. Net streaming seems improved.
6. EDID data stream changed for better compatibility. See thread: http://softwareblogs.intel.com/2008/...-av-receivers/
Denon Germany reports on April 30, 2008 the following are fixed in firmware 1.70 released April 24, 2008:
Improvement of HDMI playback
Setup menu OSD and setup menu FL-display are different
Improvement of the screen between Internet radio (Interpret and Title)
When the route of TwonkyMedia (4.4.4) is selected by "Net/USB function", it is not possible to reproduce.
Firmware version 1.70 - 3808 owners report (firmware update reported Feb 27, 2008. This firmware version was released only for European 3808 owners):
BUGS/UPGRADE ISSUES
1. Internet radio no change when song changes on most stations. You can press the left arrow, wait a few seconds, and it will then show the current song track playing.
2. When stopping a radio station stream by holding down the enter button on the remote the display does not return and show folder station list. Work around press down arrow after stopping the radio station to display folder station list or use the stop button (found on the second smaller remote).
3. When a song is paused, browsing music server or USB folders behaves erratically. Should either browse correctly or not allow browsing when song is paused. Do not pause a song and browse music server or USB folders.
4. Web page control 'setup' menu spelling incorrect "INFOMATION". Web page control after selecting 'save' under 'setup' menu the top of the page says "Save Configration"
6. German DTS HD HR titles showing incorrectly stereo signal. Signal not being decoded correctly by receiver.
FIXED/IMPROVED
1. Fixed analog FM radio station frequencies being skipped in Australia.
2. Base seems fuller and more realistic
Denon Germany reports on April 30, 2008 the following are fixed in firmware 1.70 released February 27, 2008:
Improvement of the help sentences and adjustemnt the translation of the setup
Improvement of the function "Dynamic EQ"
adjustment of the DPMS server for the update
Improvement of OSD
Improvement of the acceptance time of the remote control
Improvement of the compatibility via DVI-Monitoren
Improvement of signal output of SB (Sourround Back) speakers by BD disc (Bule-ray disc)
Improvement the adivisement on the FL dispaly by BD (Blu-ray disc)
Firmware version 1.69 - 3808/4308 owners report (firmware main 1.69 module updates released April 24, 2008 for 3808 and reported available May 15th for 4308):
BUGS/UPGRADE ISSUES
4. When receiver NET/USB music server playback of MP3's that have UTF-16 formated tags last letter missing of title, album, artist. Work around convert existing MP3's to tag format ID3v2.3 ISO-8859-1 using utility program such as: http://www.mp3tag.de/en/
5. Web page control after selecting 'save' under 'setup' menu the top of the page says "Save Configration"
6. Internet radio continues to actively stream when receiver turned off (large power button, standby mode).
7. German, Australia, England, French DTS HD HR titles showing incorrectly stereo signal on receiver. Signal not being decoded correctly by receiver.
8. Internet radio presets are lost after update.
9. After initiating firmware update receiver displays "Please Wait..." and does not proceed with update process after waiting extended period of time (i.e. 20 minutes waiting and still message "Please Wait..."). Power cycle receiver using small power button then retry update. Do not power cycle receiver when update in process!
10. Owner reports losing Audyssey configuration after update. Was unable to restore configuration. Update and configuration save/restore performed using wireless connection. Owner switching over to hard wired Ethernet connection to perform updates.
11. Owner reports Denon working on firmware update to resolve disk issue encountered with New Line Cinema Golden Compass which uses different flagging. Issue encountered when down converting to 5.1
12. USB Random music play gets stuck in folders.
13. If the 4308 is on and in HD Radio mode---and then you hit "DTU" on the main remote, the system will change bands (e.g. AM to FM or FM to AM). But, if you hit "DTU" immediately after powering the system on when it was last in HD Radio mode things go wacky. Work around when using a universal or Harmony remote and auto command sequence see this link: http://www.avsforum.com/avs-vb/showt...8#post14082938
14. HDMI random dropouts reported by several owners of some Projectors and some Sony TV's. The receiver will then re-sync the signal. This occurs during playback of various sources at random times. Not a Denon only problem.
FIXED/IMPROVED
Jeff Talmadge- Director of Product Development Denon USA reports on April 30, 2008 the following are fixed in firmware 1.69 released April 24, 2008:
- The scaling function of the HDMI input did not operate correctly when the firmware was updated to the latest version.
- Spelling error on web browser display.
- Setup menu does not coordinate with receiver front panel setting.
- When HDMI setting is set to TV pass through, some options should be grayed out (not available)
- The AVR-3808 appeared the Interpret and Title of song if you have selected an Internet radio station. (old firmware 1.05) With the new firmware 1.69 we can't see Interpret and Title of song.It only appears the name of radio station.
- When the route of TwonkyMedia (4.4.4) is selected by "Net/USB function", it is not possible to reproduce. (For only TwonkyMedia user)
Firmware version 1.69 - 3808/4308 owners report (firmware update released Feb 16, 2008):
BUGS/UPGRADE ISSUES
1. Internet radio now displays song track information for stations broadcasting song track but no change when song track changes on most stations (does not automatically update on screen). You can press the left arrow, wait a few seconds, and it will then show the current song track playing.
4. Some report update crashed WIFI/wired connection on many 4308/3808's. Turn DHCP off/on or set correct fixed IP settings, if using wireless after update then verify correct settings and search/rescan.
5. Some report loss of video and audio on some 3808's/4308's after update requiring a hard reset of the receiver. Some report unable to restore saved configuration without loosing video and audio again requiring hard reset to restore video and audio.
6. Some report loss of Internet radio after update on 3808/4308 after the update. Turn DHCP off/on or set correct fixed IP settings, if using wireless after update then verify correct settings and search/rescan.
7. Net Radio favorites and presets lost after update on 3808/4308.
8. Web page control 'setup' menu spelling incorrect "INFOMATION". Web page control after selecting 'save' under 'setup' menu the top of the page says "Save Configration"
9. A couple report receiver shows a 4 minute update after firmware 1.69 update performed. The 4 minute update notice continues to show despite trying to perform the 4 minute update. Receiver does not show 'latest' after trying to perform the 4 minute update. Owner reported problem to Denon, resolution pending.
10. Some report continually retrying the update when receiving 'connection failed' message. If receiver says "Please wait... Update Retry" be patient and wait for update to complete or 'connection failed'. If 'connection failed' then verify network connectivity to the receiver, UPnP is disabled on network router, turn DHCP off/on and verify IP settings or set fixed IP on receiver, then power cycle receiver using small power button. You may receive "Please wait... Update Retry" and then 'connection failed' many times until firmware update finally completes.
11. Some report after continually retrying the update when receiving "Please wait... Update Retry" and "connection failed" with firmware update incomplete, update completed following this procedure:
- Unplug the Ethernet cable.
- Turn off the main power.
- Hold down the 'Standard' and 'DSP Sim' buttons (note: microprocessor reset "hard reset")
- Turn on the main power
- After the display flashes 5 times or so release the buttons
- After the unit finishes booting up turn off the main power
- Hold the 'up' and 'down' arrow buttons (note: this described in instructions procedure #2 for firmware prior to 1.57)
- After the display flashes 5 times or so release the buttons.
- Re-connect the Ethernet cable
- After you see an IP address in network info, try updating the firmware again.
12. Video sync loss on main Zone for 1-2 seconds intermittent when a program fades to black and using Svideo on Zone 2. Workaround plug Svideo for source device into an input other then one main Zone (i.e. HDMI) also plugged into. Video sync still lost 1-2 seconds intermittent when a program fades to black on Zone 2 but keeps loss from occurring on main Zone. This behavior may be a DirecTV HR20 problem and not Denon. Problem occurs when having both HDMI and SVideo plugged in from the DirecTV box to the receiver.
13. Analog FM radio station frequencies being skipped even though valid frequencies in Australia. Rescan did not resolve.
14. Internet radio continues to actively stream when receiver turned off (large power button, standby mode).
15. German DTS HD HR titles showing incorrectly stereo signal on both USA and German receivers. Signal not being decoded correctly by receiver.
16. HDMI random dropouts reported by several owners of some Projectors and some Sony TV's. The receiver will then re-sync the signal. This occurs during playback of various sources at random times.
FIXED/IMPROVED
1. When using a USB drive the playback mode Repeat and Random work now.
2. DTS-HD MA 7.1 now reporting correctly on display. Also reported fixed by Jeff Talmadge director product development Denon USA.
3. Ethernet operations seem to work faster. (i.e. Internet Radio, saving configuration, Command3808 queries). These firmware modules were updated and acceptance time from remote/IP/232 improved as reported by Jeff Talmadge.
4. Music streaming control through web interface works faster. Likely perceived due to scrolling not being painted twice and acceptance time from remote/IP/232 improved as reported by Jeff Talmadge.
5. Configuration settings should be retained after update.
6. Base seems fuller and more realistic.
7. Audyssey seems to work better. Recommend re-running Audyssey setup after update if you use MultEQ as some bass fixes were introduced.
8. Internet Radio seems more stable.
Jeff Talmadge- Director of Product Development Denon USA reports on Feb 19, 2008 the following are fixed in firmware 1.69 released February 16, 2008:
3808CI/4308CI:
1. Firmware update stops to display 'Ether WP 01MIN' and 'UPDATE CHECK OK' - fixed
2. When scrolling on Net/USB, each step is painted twice - fixed
3. Acceptance time for remote/IP/232 commands is 4 seconds - fixed, down to 2 seconds
4. Internet Radio song/title information has been restored - note, not all channels broadcast this information
5. Connectivity to Wi-Fi access points with SSID information with 'spaces' in the name has been corrected
6. The "Cars" BD disc has a Dolby TrueHD 6.1 soundtrack, however these units would display and playback only HD 5.1 - this is corrected.
7. Same as 2808CI/988 with 'New Line Cinema' dts-HD MA 7.1 titles where the front panel display would show 'dts Surround' and only 5.1 channels - this is corrected. It will show dts-HD MA 7.1.
Firmware version 1.57 - 3808/4308 owners report:
1. Internet radio stopped displaying song track information for most stations that broadcast song track.
2. Internet radio sometimes stops streaming and requires rebooting the receiver using the small power button.
4. This update fixed GUI crash problems.
5. Some report receiver gets stuck during update process. After waiting sometimes hours update process still stuck (some modules can take quite a while to update so be patient). First try power cycling receiver using small power button. Second try disabling UPnP on network router, and power cycling receiver. If update still gets stuck for extended period of time try hard reset (instruction link end of this post).
6. Some report receiver shows a 3 minute update after 1.57 firmware update. The 3 minute update notice continues to show despite trying to perform the 3 minute update.
7. Video sync loss on main Zone for 1-2 seconds intermittent when a program fades to black and using Svideo on Zone 2. Workaround plug Svideo for source device into an input other then one main Zone (i.e. HDMI) also plugged into. Video sync still lost 1-2 seconds intermittent when a program fades to black on Zone 2 but keeps loss from occurring on main Zone. This behavior may be a DirecTV HR20 problem and not Denon. Problem occurs when having both HDMI and SVideo plugged in from the DirecTV box to the receiver.
9. EDID specification 'non-standard' causing problems with a few HTPC devices. Not a Denon only issue. If you suspect having EDID issues see this thread: http://www.curtpalme.com/forum/viewtopic.php?t=7321
10. Internet radio continues to actively stream when receiver turned off (large power button, standby mode).
11. See update instructions for firmware earlier then 1.57 for additional bug fixes.
Denon Japan 3808 posted change log as of October 18, 2008 translated:
Note: Specific 4308 Japan posted change log not found although this one likely applies.
AV surround amplifier AVC-3808
*latest update on the earlier apply.
2008/10/17
(1) GUI part of the display was improved.
(2) iPhone 3G show some improvement at the time of connection.
2008/09/18
(1) during the power play Internet radio OFF / ON operation when improved.
(2) USB memory, music playback using the random behavior improved.
(3) WMA (Lossless) operation when play was improved.
The need to update products, and serial number ending in 3900 the following products only.
2008/08/29
Scaling work better.
2008/07/03
(1) GUI shown some improvement.
(2) certain to improve the operation of audio formats.
*product warranty card number is the case in cartons and products mentioned in the back of the 10-digit number.
2008/04/30
(1) HDMI input to improve the scaling work.
(2) Internet radio station playing continuous playback of information improved.
The need to update products, and serial number ending in 3400 the following products only.
2008/02/25
(1) work to improve the online updates.
(2) GUI improved.
(3) ON power from the remote is acceptable to shorten the time available
(4) Some Internet broadcasting station improved.
(5) Some of the projector when connected to work better.
(6) Some of the Blu-ray Disc Channel to improve the display and audio playback.
The need to update products, and serial number ending in 2700 the following products only.
2007/11/01
AMP ASSIGN is Bi-Amp, 2ch (surround mode Stereo/2ch) set when the speaker's voice when using headphones output was fixed.
The need to update products, and serial number 900 at the end of the following products only.
2007/10/12
6.1ch speakers connected to the auto-setup was able to improve the stability of operation.
The need to update products, 6.1ch using a serial number and only 700 at the end of the following products only. Otherwise, if the update is necessary.
5308 Firmware Version Tracking
Firmware version A1.81 *LATEST* - 5308 owners report (firmware update reported October 27, 2008 for NORTH AMERICA and (EUROPEAN - with DV feature upgrade)):
FIXED/IMPROVED
Reported by Denon USA owner the following Denon change log and are fixed in firmware A1.81 reported available October 27, 2008:
BUGS/UPGRADE ISSUES
1. Web controller NET/USB Internet radio or local music server the Album or Song does not automatically update on web page when changes during play. Work around click on back arrow navigation control left of 'stop' button on Net Audio web page and wait for refresh showing current Album.
3. Receiver continues to display album art image with screen saver turned on and active.
Firmware version 1.77 *LATEST EUROPEAN* and A1.77 - 5308 owners report (firmware update reported October 16, 2008 for EUROPEAN and October 20, 2008 for NORTH AMERICA):
FIXED/IMPROVED
Reported by Denon USA owner the following Denon change log and are fixed in firmware 1.77 reported available October 16, 2008 and October 20, 2008:
BUGS/UPGRADE ISSUES
5. Owner reports first attempt the update failed at Sflash Firm update check (18 minutes to go) - resulting in corrupted GUI. Update resumed from Sflash Firm (29 minute update time required) after power cycle using small power button and using local display for navigation rather than GUI and the update completed successfully.
Firmware version A1.76 - 5308 owners report (firmware update reported October 1, 2008):
FIXED/IMPROVED
1. HDMI control set to ON now enables powered off HDMI pass through.
2. Source select and quick select IR commands now power the unit on.
3. GUI menu OptionSetup>GUI>MasterVolume can now be set to bottom, top, or off.
Reported by Denon USA owner the following Denon change log and are fixed in firmware 1.76 reported available October 1, 2008:
3-1. Additional of new features
1) SIRIUS Ready
2) Audyssey Dynamic Volume
3) Improving of connectivity with ASD-11R
4) Change the name of 2-way Remote in OPTION SETUP menu. (232C PORT(1))
5) Correspondent to Resolution of 1080p/24Hz Note: Better throughput of 1080p/24Hz signals via HDMI: "Adds scaling to 1080p/24 from any analog/digital signals"
3-2. Improvement of malfunction
1) The unit does not come back to the last state of playback when we turn off the power during playback Internet radio then turn on.
2) The customer has connected a "USB-Stick memory" with more than 4GB. Random-function of USB devices is not active.
3) Drop-outs via Ethernet playback from PC with "Windows Vista".
4) No playback of JPEG with Meta data.
5) Missing Aspect ratio setup for NET/USB source.
3-3. Improvement of GUI indication
1) Improvement of remote control receipt operation
a) To turn on the power supply of the unit in the standby by "INPUT SOURCE selection" button of remote control or "QuickSelect" code.
b) After the power supply of the unit had been turned on, the operation time by the remote control such as "INPUT SOURCE selection" button, "Surround mode", and "Master volume control" were shortened.
2) The display condition of "Subwoofer channel" of "DIRECT" and "STEREO mode" when 2ch is input is changed.
3) To turn off the channel indicator on the FL display when the subwoofer was not output.
(Subwoofer Mode : "LFE", Front Speaker: "Large")
4) The setting of "SB CH OUT" can be changed by operating "Standard" button at 5.1ch input.
5) When "PCM Multi Ch+Matrix" has been turned on, the surround mode display name is changed.
6) When the mastering volume is operated, the setting that displays "Volume display" of "GUI/OSD" in the screen upper row is added.
(A set value of Option/GUI/Master volume is changed to Bottom/Top/OFF.)
7) "Aspect setting item" is added to the "NET/USB" function. (SOURCE SELECT/NetUSB/video/Aspect)
BUGS/UPGRADE ISSUES
4. Owner reports incomplete firmware module versions after update using wireless. Hard reset the unit, wireless connection restored, 4 minute update then showing, ran update and completed, then restored from saved configuration settings.
5. When receiving 'connection failed' trying to update firmware Denon technical support advises on or about September 9, 2008 owner having Comcast ISP: "The reason why you are experiencing the "connection failed" when trying to access the firmware update is because Comcast takes much longer to make the connection than the receiver will allow. The AVR-3808CI will take about 30 hops before it times out waiting for the connection. While Comcast takes about 40 hops to connect. Therefore the connection is never made for the download. We are well aware of this issue and if there is a firmware update for comcast users we will make it available. You can take or send the unit to an authorized Denon service center and they will update the receiver with the latest firmware version. The other option, if possible, is to take the unit to a friend or relative's home where a different ISP is used. You will be able to complete the firmware update." Note: Based on Denon's explanation, this issue is not exclusive to Comcast and may be encountered with other ISP's or due to your ISP's current network traffic conditions when trying to update. Owner reports Denon support said they are working on this issue.
Firmware version 1.76, GUI DAT = 10003021 (without feature pack upgrade) - 5308 EUROPEAN owners report (firmware update reported September 28, 2008)
FIXED/IMPROVED
Reported by Denon USA owner the following Denon change log and are fixed in firmware 1.76, GUI DAT = 10003021 reported available September 28, 2008:
Note: To purchase feature pack upgrade (for firmware upgrade/update) please visit Denon website beginning Oct 1, 2008 for information. Contact Denon technical support any questions concerning the Oct 2008 feature pack upgrade.
BUGS/UPGRADE ISSUES
1. Web controller NET Audio the Album or Song does not automatically update on web page when changes during play. Work around click on back arrow navigation control left of 'stop' button on Net Audio web page and wait for refresh showing current Album.
2. Receiver continues to display album art image with screen saver turned on and active.
3. When receiving 'connection failed' trying to update firmware Denon technical support advises on or about September 9, 2008 owner having Comcast ISP: "The reason why you are experiencing the "connection failed" when trying to access the firmware update is because Comcast takes much longer to make the connection than the receiver will allow. The AVR-3808CI will take about 30 hops before it times out waiting for the connection. While Comcast takes about 40 hops to connect. Therefore the connection is never made for the download. We are well aware of this issue and if there is a firmware update for comcast users we will make it available. You can take or send the unit to an authorized Denon service center and they will update the receiver with the latest firmware version. The other option, if possible, is to take the unit to a friend or relative's home where a different ISP is used. You will be able to complete the firmware update." Note: Based on Denon's explanation, this issue is not exclusive to Comcast and may be encountered with other ISP's or due to your ISP's current network traffic conditions when trying to update. Owner reports Denon support said they are working on this issue.
Firmware version 1.76 - 5308 EUROPEAN owners report (firmware update reported September 19, 2008):
FIXED/IMPROVED
Reported by Denon USA owner the following Denon change log and are fixed in firmware 1.76 reported available September 19, 2008:
6) Addition of up-grade function for Pay-upgrade. Note: Receiver must be updated prior to upgrade. To purchase feature pack upgrade (for firmware upgrade/update) please visit Denon website beginning Oct 1, 2008 for information. Contact Denon technical support any questions concerning the Oct 2008 feature pack upgrade.
7) When 5.1ch signal is input, the setting of "SB CH OUT" can be changed by a cyclic operation of "Standard" button.
BUGS/UPGRADE ISSUES
3. Owners report Net Radio and HD Radio presets lost after update.
4. Owner reports losing audio and video after this update. Work around hard reset the receiver after this update and redo all settings.
Firmware version 1.57, fpga = A080719A - 5308 owners report (firmware update reported August 18, 2008):
FIXED/IMPROVED
Reported by Denon USA owner the following Denon change log and are fixed in firmware 1.57, fpga = A080719A reported available August 18, 2008:
BUGS/UPGRADE ISSUES
1. When a song is paused, browsing music server or USB folders behaves erratically. Should either browse correctly or not allow browsing when song is paused. Do not pause a song and browse music server or USB folders.
4. Sometimes sporadic video sync loss with devices when using parallel HDMI and SVideo or component connections. This has been an issue with all firmware versions. Possible work around unplug SVideo or component connections for those devices and use HDMI only.
Firmware version 1.57 - 5308 owners report (firmware update reported June 18, 2008):
FIXED/IMPROVED
Jeff Talmadge- Director of Product Development Denon USA reports on or about June 20, 2008 the following are fixed in firmware update reported June18, 2008:
- Addition of the RhapsodyMerge function.
- "ON/OFF" display of "Tone Defeat" is opposite.
- When space is used for the character of SSID, WiFi cannot be set.
- Problem for Tuner preset memory when RDS is received.
- Spelling error on web browser display. "Controler" > "Controller"
- MVUP/down (master volume up/down) command can affect zone 2 volume if any zone 2 command has been recently sent.
- No title via internet radio with the new firmware version 1.05
-When AVP-A1HD connects Marantz DV9500 with EXT.IN connection and chose "Monitor2", Sound output stops.
- The disc where "Dolby Digital" and "TrueHD" are alternately recorded is reproduced. And, when "Dolby Digital" and "TrueHD" are promptly switched, the sound is not outputted.
- When the stream signal of "DTS-HD MA 7.1ch" is reproduced by setting "5.1ch", the sound is distorted. Noise occur from surround channel when playback a blue-ray disc "The Golden Compass" when connected AVPA1HD and DVD3800BD.
- The connectivity of "HDMI" and "CEC" is improved.
BUGS/UPGRADE ISSUES
4. When power on and go to NET/USB, AVC-A1HD often displays “Please wait….” (on both front panel and screen) forever. Need to press a cursor key in order to get the NET/USB screen (and it prints the favorites screen)
5. Owner reports losing Audyssey configuration after update.
6. Update crashes WIFI connectivity. Turn DHCP off/on or set correct fixed IP settings, verify correct settings and search/rescan. May require hard reset of the receiver to make WIFI operational after this update.
Firmware version 1.05 - 5308 owners report (firmware update released Feb 16, 2008 and Sub module 0.58 update reported April 10, 2008):
FIXED/IMPROVED
Jeff Talmadge- Director of Product Development Denon USA reports on Feb 19, 2008 the following are fixed in firmware 1.05 released February 16, 2008:
AVR-5308CI:
1. Auto Setup with 6.0 channel option did not function - fixed.
2. The "Cars" BD disc has a Dolby TrueHD 6.1 soundtrack, however these units would display and playback only HD 5.1 - this is corrected.
Jeff Talmadge- Director of Product Development Denon USA reports on April 30, 2008 the following are fixed in Sub module 0.58 firmware update reported April 10, 2008:
- If the "Hi-vision-signal" inputs to the unit, it can scale to "1080i" but can not scale to "1080p".
- "Pop" noise occurs when the muting function turns on.
- The noise occurs when the input selector is changed.
- A different digital signal might be output to "OPT-4" output.
- The connectivity of HDMI is improved.
BUGS/UPGRADE ISSUES
6. Receiver continues to display album art image with screen saver turned on and active.
8. Owner reports Denon working on firmware update to resolve disk issue encountered with New Line Cinema Golden Compass which uses different flagging. Issue encountered when down converting to 5.1
Denon Japan AVC-A1HD posted change log as of October 18, 2008 translated:
AV surround amplifier AVC-A1HD (5308)
2008/10/17
2008/09/19
(1) Internet radio is playing the power OFF / ON operation at the time was improved.
(2) USB memory to play music when the random behavior was improved.
(3) WMA (Lossless) to improve the operation of playback time.
(4) JPEG files with metadata work at the time of play has improved.
(5) NET / USB function better in the aspect ratio has been set.
(6) GUI has been showing some improvement.
The need to update products, serial No. 700 at the end of the following products only.
*product warranty card numbers, carton cases, and products are listed on the back of a 10-digit numbers.
2008/08/29
2008/06/26
(2) Wireless LAN Settings some improvement.
(3) Internet radio to play some improvement in information display.
(4) specific voice to improve the operation of the disk format.
(5) HDMI, CEC to improve connectivity.
The need to update products, and serial number 700 at the end of the following products only.
2008/04/14
(1) Dual-scale operation when connected to monitor improvements.
(2) operation when switching function improved.
(3) work to improve the optical digital output.
The need to update products, serial No. 550 at the end of the following products only.
2008/02/21
(1) 6.0ch speakers connected to the auto-setup was able to improve the stability of operation.
(2) 480i and the output of video input and output improved.
(3) set up the operation has been improved GUI
(4) set some information to improve retention.
(5) Some Blu-ray Disc playback in Dolby TrueHD 6.1ch audio playback has been improved.
The need to update products, and serial number 400 at the end of the following products only.
post #3 of 3803
Firmware Module Change Logs
3808 FIRMWARE MODULE
VERSIONS CHANGE TRACKING:
USA 3808 firmware 1.69 module changes (released February 16, 2008):
Main = 1.69
Sub = .78
DSP1 = 36.56
DSP2 = 39.45
DM850 IMG = I200801290406*
DM850 WEB = W200801290410*
DM850 CNE = C20080129
USA 3808 firmware 1.69 module changes (released April 24, 2008):
Main Ver = 01.69
Sub Ver = 00.82
DSP1 Ver = 36.56
DSP2 Ver = 39.45
Ethernet IMG = I200803270536
Ethernet BL = B200707020733
Ethernet CNE = C20080327
WEB = W200803270558
GUI FPGA CONFIG = A070629B
GUI PRG = 00007621
GUI DAT = 37750008
DGTL PLD = 00.50
USA, Canada 3808 firmware 1.73 module changes (reported July 4, 2008):
Main Ver = 01.73
Sub Ver = 00.86
DSP1 Ver = 36.57
DSP2 Ver = 39.45
Ethernet IMG = I200805230152
Ethernet CNE = C20080523
WEB = W200805230718
GUI PRG = 00007621
GUI DAT = 37750011
DGTL PLD = 00.50
USA, Canada 3808 firmware 1.73 module changes (reported August 18, 2008):
Main Ver = 01.73
Sub Ver = 00.88
DSP1 Ver = 36.57
DSP2 Ver = 39.45
WEB = W200805230718
GUI FPGA CONFIG = A080719A
GUI PRG = 00007621
GUI DAT = 37750011
DGTL PLD = 00.50
USA, Canada 3808 firmware 1.95 module changes (reported September 17, 2008):
Main Ver = 01.95
Sub Ver = 01.07
DSP1 Ver = 36.59
DSP2 Ver = 39.48
Ethernet IMG = I200808192317
Ethernet CNE = C20080819
WEB = W200808192354
GUI PRG = 00007621
GUI DAT = 37750017
DGTL PLD = 00.50
USA, Canada 3808 firmware A1.94 (feature pack upgrade only) module changes (reported October 1, 2008):
Main Ver = A1.94
Sub Ver = 01.07
DSP1 Ver = 36.59
DSP2 Ver = 39.48
Ethernet IMG = I200808200004
Ethernet BL = B200707020733-0A
Ethernet CNE = C20080820
WEB = W200808200050
GUI PRG = 00007621
GUI DAT = 37750017
DGTL PLD = 00.50
USA, Canada 3808 firmware 1.97 *LATEST* module changes (reported October 15, 2008):
Main Ver = 01.97
Sub Ver = 01.09
DSP1 Ver = 36.60
DSP2 Ver = 39.49
Ethernet IMG = I200809050737
Ethernet CNE = C20080905
WEB = W200809050808
GUI PRG = 00007621
GUI DAT = 37750020
DGTL PLD = 00.50
USA, Canada 3808 firmware A1.97 (feature pack upgraded models only) module changes (reported October 15, 2008):
Main Ver = A1.97
Sub Ver = 01.09
DSP1 Ver = 36.60
DSP2 Ver = 39.49
Ethernet IMG = I200809040533
Ethernet CNE = C20080904
WEB = W200809040544
GUI PRG = 00007621
GUI DAT = 37750020
DGTL PLD = 00.50
USA, Canada 3808 firmware A2.01 *LATEST* (feature pack upgraded models only) module changes (reported October 27, 2008):
Main Ver = A2.01
Sub Ver = 01.10
DSP1 Ver = 36.60
DSP2 Ver = 39.49
WEB = W200809040544
GUI PRG = 00007621
GUI DAT = 37750020
DGTL PLD = 00.50
Germany, Australia, Canada, Greece 3808 firmware 1.69 module changes (released February 16, 2008):
Main = 1.69
Sub = .78
DSP1 = 36.56
DSP2 = 39.45
DM850 IMG = I200801290418*
DM850 WEB = W200801290420*
Denmark, Germany, Greece, Australia, France, Finland 3808 firmware 1.70 module changes (released February 27, 2008):
Main Ver = 1.70
Sub Ver = 00.78
DSP1 Ver = 36.56
DSP2 Ver = 39.45
Ethernet IMG = I200802210024
Ethernet CNE = C20080221
WEB = W200802210052
GUI PRG = 00007621
GUI DAT = 37750008
DGTL PLD = 00.50
Germany, Switzerland, Canada, Australia, Greece, UK 3808 firmware 1.70 module changes (released April 24, 2008):
Main Ver = 01.70
Sub Ver = 00.82
DSP1 Ver = 36.56
DSP2 Ver = 39.45
Ethernet IMG = I200803270529
WEB = W200803270558
GUI PRG = 00007621
GUI DAT = 37750008
DGTL PLD = 00.50
Germany, Finland, Australia, Italy, Denmark, New Zealand 3808 firmware 1.73 module changes (reported July 4, 2008):
Main Ver = 01.73
Sub Ver = 00.86
DSP1 Ver = 36.57
DSP2 Ver = 39.45
Ethernet IMG = I200805230201
WEB = W200805230718
GUI PRG = 00007621
GUI DAT = 37750011
DGTL FPGA = no entry
VIDEO PLD = 00.50
Finland, England, Australia 3808 firmware 1.73 module changes (reported August 18, 2008):
Main Ver = 01.73
Sub Ver = 00.88
DSP1 Ver = 36.57
DSP2 Ver = 39.45
WEB = W200805230718
GUI PRG = 00007621
GUI DAT = 37750011
VIDEO PLD = 00.50
Hong Kong, Australia, Finland, Switzerland, New Zealand, Portugal, Netherlands 3808 firmware 1.95 module changes (reported September 17, 2008):
Main Ver = 01.95
Sub Ver = 01.07
DSP1 Ver = 36.59
DSP2 Ver = 39.48
Ethernet IMG = I200808192321
WEB = W200808192354
GUI PRG = 00007621
GUI DAT = 37750017
DGTL PLD = 00.50
Germany, Australia, Denmark, New Zealand 3808 firmware 1.95 module changes (reported September 28, 2008):
Main Ver = 01.95
Sub Ver = 01.07
DSP1 Ver = 36.59
DSP2 Ver = 39.48
WEB = W200808192354
GUI PRG = 00007621
GUI DAT = 37750019
DGTL PLD = 00.50
New Zealand, Australia, Russia Federation, Netherlands, Belgium, Singapore 3808 firmware 1.97 *LATEST EUROPEAN* module changes (reported October 15, 2008):
Main Ver = 01.97
Sub Ver = 01.09
DSP1 Ver = 36.60
DSP2 Ver = 39.49
Ethernet IMG = I200809050744
WEB = W200809050808
GUI PRG = 00007621
GUI DAT = 37750020
DGTL PLD = 00.50
New Zealand 3808 firmware A1.97 (feature pack upgraded models only) module changes (reported available October 22, 2008)
Main Ver = A1.97
Sub Ver = 01.09
DSP1 Ver = 36.60
DSP2 Ver = 39.49
Ethernet IMG = I200809040536
WEB = W200809040544
GUI PRG = 00007621
GUI DAT = 37750020
VIDEO PLD = 00.50
Australia 3808 firmware A2.01 *LATEST EUROPEAN* (feature pack upgraded models only) module changes (reported available October 27, 2008)
Main Ver = A2.01
Sub Ver = 01.10
DSP1 Ver = 36.60
DSP2 Ver = 39.49
WEB = W200809040544
GUI PRG = 00007621
GUI DAT = 37750020
VIDEO PLD = 00.50
4308 FIRMWARE MODULE VERSIONS CHANGE TRACKING:
USA 4308 firmware 1.69 module changes (Note: USA Owners report having IMG = I200801290325) (released February 16, 2008):
Main = 1.69
Sub = 0.78
DSP1 = 36.56
DSP2 = 39.45
IMG = I200801290317*
WEB = W200801290327*
CNE = C20080129
Canada (purchased in the USA), USA 4308 firmware 1.69 module changes (reported available May 15th, 2008)
Main Ver = 01.69
Sub Ver = 00.82
DSP1 Ver = 36.56
DSP2 Ver = 39.45
Ethernet IMG = I200803270355
WEB = W200803270558
GUI PRG = 00007621
GUI DAT = 37750008
DGTL PLD = 00.50
USA 4308 firmware 1.72 module changes (reported available July 4th, 2008)
Main Ver = 01.72
Sub Ver = 00.86
DSP1 Ver = 36.57
DSP2 Ver = 39.45
Ethernet IMG = I200805230111
WEB = W200805230718
GUI PRG = 00007621
GUI DAT = 37750011
DGTL FPGA = 00.71
VIDEO PLD = 00.50
USA 4308 firmware 1.72 module changes (reported available August 8, 2008)
Main Ver = 01.72
Sub Ver = 00.88
DSP1 Ver = 36.57
DSP2 Ver = 39.45
WEB = W200805230718
GUI PRG = 00007621
GUI DAT = 37750011
DGTL FPGA = 00.71
VIDEO PLD = 00.50
USA, Canada 4308 firmware 1.95 module changes (reported available September 17, 2008)
Main Ver = 01.95
Sub Ver = 01.07
DSP1 Ver = 36.59
DSP2 Ver = 39.48
Ethernet IMG = I200808192343
WEB = W200808192354
GUI PRG = 00007621
GUI DAT = 37750017
DGTL FPGA = 00.71
VIDEO PLD = 00.50
USA, Canada 4308 firmware A1.94 (feature pack upgrade only) module changes (reported available October 1, 2008):
Main Ver = A1.94
Sub Ver = 01.07
DSP1 Ver = 36.59
DSP2 Ver = 39.48
Ethernet IMG = I200808200033
WEB = W200808200050
GUI PRG = 00007621
GUI DAT = 37750017
DGTL FPGA = 00.71
VIDEO PLD = 00.50
USA, Canada, Brazil (purchased from USA) 4308 firmware 1.97 *LATEST* module changes (reported available October 20, 2008):
Main Ver = 01.97
Sub Ver = 01.09
DSP1 Ver = 36.60
DSP2 Ver = 39.49
Ethernet IMG = I200809050541
WEB = W200809050808
GUI PRG = 00007621
GUI DAT = 37750020
DGTL FPGA = 00.71
USA, Canada, Brazil (purchased from USA) 4308 firmware A1.97 (feature pack upgraded models only) module changes (reported available October 20, 2008):
Main Ver = A1.97
Sub Ver = 01.09
DSP1 Ver = 36.60
DSP2 Ver = 39.49
Ethernet IMG = I200809040518
WEB = W200809040544
GUI PRG = 00007621
GUI DAT = 37750020
DGTL FPGA = 00.71
VIDEO PLD = 00.50
USA, Canada 4308 firmware A2.01 *LATEST* (feature pack upgraded models only) module changes (reported available October 27, 2008):
Main Ver = A2.01
Sub Ver = 01.10
DSP1 Ver = 36.60
DSP2 Ver = 39.49
WEB = W200809040544
GUI PRG = 00007621
GUI DAT = 37750020
DGTL FPGA = 00.71
VIDEO PLD = 00.50
England, Italy, Canada, Finland, Netherlands 4308 firmware 1.69 module changes (released February 16, 2008):
Main = 01.69
Sub = 00.78
DSP1 = 36.56
DSP2 = 39.45
IMG = I200801290335*
WEB = W200801290336*
CNE = C20080129
Netherlands, Italy, Sweden, Australia 4308 firmware 1.69 module changes (reported available May 15th, 2008)
Main Ver = 01.69
Sub Ver = 00.82
DSP1 Ver = 36.56
DSP2 Ver = 39.45
Ethernet IMG = I200803270412 (Australia owner reports having IMG = I200803270417)
WEB = W200803270558
GUI PRG = 00007621
GUI DAT = 37750008
DGTL FPGA = 00.71
DGTL PLD = 00.50
DAB = 300
Germany, Finland 4308 firmware 1.72 module changes (reported available July 4th, 2008)
Main Ver = 01.72
Sub Ver = 00.86
DSP1 Ver = 36.57
DSP2 Ver = 39.45
Ethernet IMG = I200805230651
WEB = W200805230718
GUI PRG = 00007621
GUI DAT = 37750011
DGTL FPGA = 00.71
VIDEO PLD = 00.50
DAB Ver = 0300
England, Italy, Brazil, Switzerland 4308 firmware 1.72 module changes (reported available August 8, 2008)
Main Ver = 01.72
Sub Ver = 00.88
DSP1 Ver = 36.57
DSP2 Ver = 39.45
WEB = W200805230718
GUI PRG = 00007621
GUI DAT = 37750011
DGTL FPGA = 00.71
VIDEO PLD = 00.50
DAB Ver = 0300
Netherlands, Norway, England 4308 firmware 1.95 module changes (reported available September 17, 2008)
Main Ver = 01.95
Sub Ver = 01.07
DSP1 Ver = 36.59
DSP2 Ver = 39.48
Ethernet IMG = I200808192349
WEB = W200808192354
GUI PRG = 00007621
GUI DAT = 37750017
DGTL FPGA = 00.71
VIDEO PLD = 00.50
DAB Ver = 0300
England, Netherlands 4308 firmware 1.95 module changes (reported available September 28, 2008)
Main Ver = 01.95
Sub Ver = 01.07
DSP1 Ver = 36.59
DSP2 Ver = 39.48
WEB = W200808192354
GUI PRG = 00007621
GUI DAT = 37750019
DGTL FPGA = 00.71
VIDEO PLD = 00.50
DAB Ver = 0300
Australia, Finland, Greece, Norway 4308 firmware 1.97 *LATEST EUROPEAN* module changes (reported available October 15, 2008)
Main Ver = 01.97
Sub Ver = 01.09
DSP1 Ver = 36.60
DSP2 Ver = 39.49
Ethernet IMG = I200809050721
WEB = W200809050808
GUI PRG = 00007621
GUI DAT = 37750020
DGTL FPGA = 00.71
VIDEO PLD = 00.50
DAB = 0300
Australia 4308 firmware A1.97 (feature pack upgraded models only) module changes (reported available October 22, 2008)
Main Ver = A1.97
Sub Ver = 01.09
DSP1 Ver = 36.60
DSP2 Ver = 39.49
Ethernet IMG = I200809040526
WEB = W200809040544
GUI PRG = 00007621
GUI DAT = 37750020
DGTL FPGA = 00.71
VIDEO PLD = 00.50
DAB = 0300
Australia 4308 firmware A2.01 *LATEST EUROPEAN* (feature pack upgraded models only) module changes (reported available October 27, 2008)
Main Ver = A2.01
Sub Ver = 01.10
DSP1 Ver = 36.60
DSP2 Ver = 39.49
WEB = W200809040544
GUI PRG = 00007621
GUI DAT = 37750020
DGTL FPGA = 00.71
VIDEO PLD = 00.50
DAB = 0300
5308 FIRMWARE MODULE VERSIONS CHANGE TRACKING:
USA 5308 firmware 1.05 module changes (released February 16, 2008):
Main = 1.05
Sub = 0.52 or Sub = 0.58 (update for Sub module reported 4/24/08)
Rom = 1.06 (Note: USA Owner reports having Rom = 1.05)
Pld = 0.25
DSP1 = 36.56
DSP2 = 37.14
DSP3 = 38.10
Ethernet IMG = I2007122220457
Ethernet BL = B200707020733-07
Ethernet CNE = C 20071222
Ethernet WEB = W200712220458
GUI FPGA = A070629B
GUI PRG = 0007621
GUI DAT = 10003006
Realta = 070C14
HDMI A PLD = 0.20
DGTL FPGA = 0.72
Video PLD = 0.10
Canada, USA 5308 firmware 1.57 module changes (reported available June 18, 2008):
Main = 1.57
Sub = 0.63
Rom = 1.57
Pld = 0.25
DSP1 = 36.57
DSP2 = 37.14
DSP3 = 38.10
Ethernet IMG = I200805220036
Ethernet CNE = C 20080522
Ethernet WEB = W200805220406
GUI FPGA = A070629B
GUI PRG = 00007621
GUI DAT = 10003012
Realta = 070C14
HDMI A PLD = 0.20
DGTL FPGA = 0.72
Video PLD = 0.10
USA 5308 firmware 1.57, fpga = A080719A module changes (reported available August 18, 2008):
Main = 1.57
Sub = 0.63
Rom = 1.57
Pld = 0.25
DSP1 = 36.57
DSP2 = 37.14
DSP3 = 38.10
GUI PRG = 00007621
GUI DAT = 10003012
Realta = 070C14
HDMI A PLD = 0.20
DGTL FPGA = 0.72
Video PLD = 0.10
USA, Canada 5308 firmware A1.76 module changes (reported available October 1, 2008):
MAIN Ver = A1.76
SUB Ver = 1.04
MAIN ROM = A1.76
MAIN PLD = 00.25
DSP1 Ver = 36.59
DSP2 Ver = 37.16
DSP3 Ver = 38.12
Ethernet IMG = I200808291121
Ethernet CNE = C 20080829
Ethernet Web = W200809020346
GUI FPGA Config = A080719A
GUI PRG = 0007621
GUI DAT = 10003019
Realta = 08030A
HDMI A PLD = 00.20
DGTL FPGA = 00.72
Video PLD = 00.10
USA, Canada 5308 firmware A1.77 module changes (reported available October 20, 2008):
MAIN Ver = A1.77
SUB Ver = 1.04
MAIN ROM = A1.77
MAIN PLD = 00.25
DSP1 Ver = 36.60
DSP2 Ver = 37.17
DSP3 Ver = 38.12
GUI PRG = 0007621
GUI DAT = 10003022
Realta = 08030A
HDMI A PLD = 00.20
DGTL FPGA = 00.72
Video PLD = 00.10
USA, Canada 5308 firmware A1.81 *LATEST* module changes (reported available October 27, 2008):
MAIN Ver = A1.81
SUB Ver = 1.05
MAIN ROM = A1.81
MAIN PLD = 00.25
DSP1 Ver = 36.60
DSP2 Ver = 37.17
DSP3 Ver = 38.12
GUI PRG = 0007621
GUI DAT = 10003022
Realta = 08030A
HDMI A PLD = 00.20
DGTL FPGA = 00.72
Video PLD = 00.10
England, France 5308 (AVC-A1HD) firmware 1.05 module changes (released February 16, 2008):
Main = 1.05
Sub = 0.52 or Sub = 0.58 (France update for Sub module reported 4/10/08)
Rom = 1.05
Pld = 0.25
DSP1 = 36.56
DSP2 = 37.14
DSP3 = 38.10
Ethernet IMG = I200712220508
Ethernet CNE = C20071222
Ethernet WEB = W200712220509
GUI FPGA = A070629B
GUI PRG = 00007621
GUI DAT = 10003006
Realta = 070C14
HDMI A PLD = 0.20
DGTL FPGA = 0.72
VIDEO PLD = 0.10
France 5308 (AVC-A1HD) firmware 1.57 module changes (reported available June 18, 2008):
Main = 1.57
Sub = 0.63
Rom = 1.57
Pld = 0.25
DSP1 = 36.57
DSP2 = 37.14
DSP3 = 38.10
Ethernet IMG = I200805220042
GUI FPGA = A070629B
GUI PRG = 00007621
GUI DAT = 10003012
Realta = 070C14
HDMI A PLD = 0.20
DGTL FPGA = 0.72
Video PLD = 0.10
France 5308 (AVC-A1HD) firmware 1.57, fpga = A080719A module changes (reported available August 18, 2008):
Main = 1.57
Sub = 0.63
Rom = 1.57
Pld = 0.25
DSP1 = 36.57
DSP2 = 37.14
DSP3 = 38.10
GUI PRG = 00007621
GUI DAT = 10003012
Realta = 070C14
HDMI A PLD = 0.20
DGTL FPGA = 0.72
Video PLD = 0.10
France, Hong Kong, England 5308 (AVC-A1HD) firmware 1.76 module changes (reported available September 19, 2008):
Main = 1.76
Sub = 1.04
Main ROM = 1.76
Main PLD = 0.25
DSP1 = 36.59
DSP2 = 37.16
DSP3 = 38.12
Ethernet IMG = I200808291113
Ethernet WEB = W200809020242
GUI PRG = 00007621
GUI DAT = 10003019
Realta = 08030A
HDMI A PLD = 0.20
DGTL FPGA = 0.72
Video PLD = 0.10
Hong Kong, Singapore 5308 (AVC-A1HD) firmware 1.76 module changes (reported available September 28, 2008):
Main = 1.76
Sub = 1.04
Main ROM = 1.76
Main PLD = 0.25
DSP1 = 36.59
DSP2 = 37.16
DSP3 = 38.12
GUI PRG = 00007621
GUI DAT = 10003021
Realta = 08030A
HDMI A PLD = 0.20
DGTL FPGA = 0.72
Video PLD = 0.10
France, Singapore 5308 (AVC-A1HD) firmware 1.77 *LATEST EUROPEAN* module changes (reported available October 16, 2008):
Main = 1.77
Sub = 1.04
Main ROM = 1.77
Main PLD = 0.25
DSP1 = 36.60
DSP2 = 37.17
DSP3 = 38.12
GUI PRG = 00007621
GUI DAT = 10003022
Realta = 08030A
HDMI A PLD = 0.20
DGTL FPGA = 0.72
Video PLD = 0.10
France 5308 (AVC-A1HD) firmware A1.77 (Dynamic Volume feature upgraded models only) module changes (reported available October 22, 2008):
Main = A1.77
Sub = 1.04
Main ROM = A1.77
Main PLD = 0.25
DSP1 = 36.60
DSP2 = 37.17
DSP3 = 38.12
Ethernet IMG = I200808291124
Ethernet WEB = W200809020346
GUI PRG = 00007621
GUI DAT = 10003022
Realta = 08030A
HDMI A PLD = 0.20
DGTL FPGA = 0.72
Video PLD = 0.10
England, France 5308 (AVC-A1HD) firmware A1.81 *LATEST EUROPEAN* (Dynamic Volume feature upgraded models only) module changes (reported available October 27, 2008):
Main = A1.81
Sub = 1.05
Main ROM = A1.81
Main PLD = 0.25
DSP1 = 36.60
DSP2 = 37.17
DSP3 = 38.12
GUI PRG = 00007621
GUI DAT = 10003022
Realta = 08030A
HDMI A PLD = 0.20
DGTL FPGA = 0.72
Video PLD = 0.10
post #4 of 3803
reserved
post #5 of 3803
reserved
post #6 of 3803
reserved
post #7 of 3803
reserved
post #8 of 3803
I have just done an update to my 3808
I have lost all video !!!!!!!
The Re set dose not work
I now have a paper weight
I will call Denon as soon as they open
post #9 of 3803
With S-Video cable, you have also no video ?
Did you try hard reset and manulay configuration ?
post #10 of 3803
I updated my system without issues last night. I do have a question what setting are you restoring ? Mine didnt wipe any settings this time (except recently played internet radio) Everything seems to still be set. But I must admit I have not gone through each setting as of yet
So just wondering what you settings you lost
Sorry to hear about those having issues with update
post #11 of 3803
Please remind me not to do any updates if I decide to order the 3808ci this Friday!
post #12 of 3803
I've held off on updating mine so far... But it's tempting, not because there seems to be any real reason to update it from v1.57 but just to see if I can update it and survive, LOL... Now, if my 3808ci were brand new out of the box, I wouldn't hesitate for one minute to update it...
Howard68 - How old is your unit? Do you have Cable or DSL? What kind of music do you listen to? Can't rule out any possibility at this point. ;-)
post #13 of 3803
Originally Posted by captavs View Post
What's your next step to resolving the problem?
I've emailed Denon support about the problem - we'll see what they come back with, if anything. To be honest, I've had this unit for about 10 days and have had nothing but problems: first in trying to get the update completed, which started automatically and left the unit virtually unusable until the update completed (took a week to get that problem straightened out through trial and error), and now the loss of internet radio.
post #14 of 3803
I had no issues with the update on my 3808. All settings were retained, no video issues and It seems that the web interface works better for net streaming......
post #15 of 3803
Did you do a master reset by holding in the 'Standard' and 'DSP Simulation' buttons while cycling power with the SMALL power button and then keeping the buttons pressed until the display goes on and off 3 times? That fixed it for me (as posted above) although I had to re-enter all my settings manually.
post #16 of 3803
hi everyone
just spoken to Chris, a Denon TEC, re: 3808 firmware upgrade after waiting for over 1 hour on hold.
He says I will have to take my Denon back to my dealer now if the reset does not work !!!!!
do not do the firmware upgrade!
post #17 of 3803
I bought my 3808 in August 07
post #18 of 3803
yes, I did that but I have not gotten any video back.
post #19 of 3803
reserved
post #20 of 3803
Howard, what firmware version were you running before this?
post #21 of 3803
I had no issues upgrading either. All my settings were retained as well. I did however have trouble updating through comcast service, so I updated through my Dads service(he has Optimum).
Besides that, all settings were retained, and it runs perfectly.
post #22 of 3803
Hi All,
I upgraded my 3808 firmware this weekend and so far (knock on wood) it seems to be working great (no video or gui issues and all my settings were retained). I have Comcast high speed internet (cable modem) and the 3808 updated over it just fine.
post #23 of 3803
Updated mine, too. First, the good news: update went smoothly, right within the 36 minutes estimate; all configuations were retained; no loss of Internet radio; and new versions are indicated on display panel.
The less serious bad news is that I am getting the bug captavs noted regarding Internet Radio displaying song track information, initially, but failing to change information when a new song begins to play on the same station. Haven't had the problem of the stream being stopped, but will report back if that does happen.
post #24 of 3803
Upgraded this last weekend to 1.69. All settings retained. Video works fine.
post #25 of 3803
How about your Internet radio?
post #26 of 3803
I finally got internet radio back after resetting the receiver and router several times. I do have the issue of the track information not changing.
post #27 of 3803
Came home this evening and decided to go with the firmware update after seeing DenonJeff's post. Upgrade went without a hitch. No sound or GUI issues. I bought my 3808ci at the beginning of January and the serial # ends in 4305. I can confirm that I also do not see the internet song name updating after the first one. The menu seems to be a little faster (although this could be my imagination)... It sounds awesome!
Captavs, kudos to you for starting this thread and doing a darn good job of keeping the first post updated with good detail!
post #28 of 3803
reserved
post #29 of 3803
reserved
post #30 of 3803
Did you do a master reset first? I currently have 1.57. To retain my current settings, do I need to do a master reset when going to 1.69?
AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Denon 3808/4308/5308 Firmware Tracking Thread
