AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Denon 3808/4308/5308 Firmware Tracking Thread
Denon 3808/4308/5308 Firmware Tracking Thread - Page 69
post #2041 of 3803
Updated my 3808CI this morning to 1.95 without error. Looks like update is in preparation for the new features coming. Going to Add New Feature now displays two new panels about the Upgrade package, registration info (logically it says "Not Registered"), and a ID number. There is a new button that allows you to check the status with the Denon server.
post #2042 of 3803
Thanks for reporting your update. Denon change logs listed first post.
post #2043 of 3803
Successful FW upgrade for my 3808 CI.
Main ver = 01.95
Wireless.
post #2044 of 3803
Firmware update for AVC-A1HD - (5308CI equiv). Just done this - took 110 minutes - updated DSP and Ethernet according to screen + it's added Dynamic Volume into the Add feature screen - doesn't appear to have added feature but the again in the UK Denon expect us to pay £75 for this feature.
post #2045 of 3803
Has anyone yet established if I buy a 3808 today whether the firmware upgrade Audessey Dynamic Volume etc) is thrown in, or will it need the additional $100 fee?
post #2046 of 3803
If anyone knows about the "add new feature" option, please let us know on cost, is it software/hardware, etc. Called Denon and they had no idea. They directed me to a Service Center who had even less of an idea. Is this so new there are no details?
Chris
post #2047 of 3803
Chris
"Add New Features" will probably mainly be software/firmware type downloads. How they will be announced is anyone's guess. There is one "scheduled" for Oct which will allow activating Audyssey Dynamic EQ, Dynamic Volume, etc. I have no idea what the etc. would be, however.
Hopefully Denon will be a lot more forthcoming about what's available, what it costs, how you will remain entitled to it once you've paid, etc. They certainly don't see fit to make any kind of announcements about when firmware updates are available, what they fix, etc.
post #2048 of 3803
I bought my 3808 on Tuesday so three days ago and it shipped with 1.57 so no Dynamic Volume. Didn't receive any kind of documentation or rebates for it either so I'm assuming no.
post #2049 of 3803
Denon definitely is preparing for the release of the features. When I run "Add new feature", I get a popup saying there is no upgrade I bought and I should visit the Denon website.
When quitting the popup, I get a list of the available upgrade packages:
  • Audyssey Dynamic EQ
  • Audyssey Dynamic Volume
  • HMDI Control
The German Denon site now says that the "Exclusive Upgrade" will be available from October, but no price yet. So I guess technically the upgrades are available.
Mike
post #2050 of 3803
Just finished updating to v1.95, Oct. 1st can't come quick enough!
post #2051 of 3803
I guess I have to wait until October 1st b4 making my purchase.
post #2052 of 3803
Mwomwell, I'm also seeing this 110 minute firmware update. Have you had any problems (specifically networking issues) since doing this very long update?
post #2053 of 3803
Just finished updating 1.73 Sub 88 to 1.95, and it went without any problems.
This time though the update process almost gave me a heart attack... I happened to be sitting next to one of the rear speakers right after it started applying to "Sub Firm", and a loud pop went through all the speakers, sending me flying off the sofa (I may have set some sort of olympic record in the process)
post #2054 of 3803
finished upgrading to 1.95 no problems....
had internet radio playing when the update started as mention by a poster earlier... when it finished the radio started playing and all internet stations were still there... thx
post #2055 of 3803
Update 1.95 for my 3808CI just finished, roughly about an hour. Hardwire connection (of course!). All versions match what is posted on the 1st page.
post #2056 of 3803
How do I make the Denon work with Vista or twonkymedia. I can't seem to get them to work together. I'm using a Linksys wired router and internet radio is working properly on the denon3808ci. I have no problem using the webrowser to set up the denon but can't get it to see eye to eye with twonky media or vista to stream music.
post #2057 of 3803
No, update did take some while though and I did loose my internet favourites but no big deal and easily re-added.
post #2058 of 3803
Is 1.95 the update which includes the volume control? And is it the one one has to pay for?
post #2059 of 3803
^^^No, that will be on Oct. 1st
post #2060 of 3803
Updated my 4308CI to 1.95 this morning with no issues to report. I also cannot wait until October 1st!
post #2061 of 3803
Performed my "normal" steps:
Backed up config using Firefox 3
Reset microprocessor/config
Updated firmware
Restored config using Firefox 3
My 3808 is now at 1.95 ....
As of this writing all looks OK.
Captavs, Many thanks for your time and efforts.
post #2062 of 3803
Post in the official 3808 or 4808 thread. This thread is for items related directly to firmware updates only.
post #2063 of 3803
Updated successfully with static IP, UPNP enabled on router, and using Comcast Cable.
Took about 100 minutes, but did not require any user intervention after starting.
post #2064 of 3803
Updated my 3808ci to 1.95 today.
Using Time Warner Cable in NE Ohio.
Hops to firmware server right at 30 now (used to be lower).
Connection could not be made, never had this problem before as my hops were always below 30 in the past.
Removed my router, and put cable modem directly on 3808ci, this reduced my hop count to 29. Firmware update completed successfully.
Current 1.95 firmware still enforces the 30 hop rule
post #2065 of 3803
I got the update done today. But, not without drama. It stopped with a message saying:
"SFLASH 31minutes. Update failed". I powered it off with the small button. When I tried to go into the GUI it was screwed up. No text, just colored blocks. I started to navigate to the update menu using the front panel display. Before I got there the 3808ci resumed the update process. Fortunately it finished without incident. It had me very concerned there for a few minutes.
Does anyone know whether it downloads the complete update, stores it and then does the flash, or does it stream the update?
black88mx6, how do you check how many hops it is to the update server? If the server name or IP is known, I can use a traceroute app to do it, I know that much. Do the Denon machines have a method for checking that? I have never seen that option. How do I access it?
Phil
post #2066 of 3803
You can add 'New Zealand' to the 3808 firmware 1.95 *LATEST EUROPEAN* updates. No problems, approx 75 minutes to complete - all version numbers match.
post #2067 of 3803
Just updated Australian 3808 to 1.95, 60 minutes, all versions match.
post #2068 of 3803
Finished my Latest upgrade successfully on Denon 3808.
Did not lose my config or audyssey values, but the Favourites list on the main menu in my NET radio disappeared. However the favourites submenu in the "Internet radio" showed all the favourite stations that i added (The new folder name i created for my favourites was also restored).
I also noticed that Denon has given an option called "Mic select" in the auto set up menus...I dont know if that existed previously?
Update took 59 min. with just one major issue - abnormal heart beat throughout the updating process :-) By the way i use Comcast for ISP and a 4 year old D-link router, wired connection ofcourse.
Cant wait till oct to get new features - Sirius ready, HDMI control,Audyssey Dyanmic volume etc..
post #2069 of 3803
My AVC-A1HD (France) upgrade worked fine... The upgrade process was the following one :
Module ........ Remain time
Main Firm ..... 110 minutes
Mfash ......... 108 minutes
Sub ........... 105 minutes
DSP1 .......... 103 minutes
DSP2 .......... 088 minutes
DSP3 .......... 075 minutes
Realta ........ 063 minutes
SFlash Firm ... 041 minutes
SFlash Firm ... 029 minutes
Ether IM ...... 018 minutes
Ether WP....... 008 minutes
(note : AVC-A1HD had rebooted at 4 minutes... the upgrade was completed successfully)
post #2070 of 3803
Main ver = 01.95
Wireless.
Thanks for reporting your update folks.
