AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Denon 3808/4308/5308 Firmware Tracking Thread
Denon 3808/4308/5308 Firmware Tracking Thread - Page 127
post #3781 of 3803
Updated 3808 successfully on first attempt via powerline ethernet, took ~ 30min.
Now shows:
Main Ver = A2.07
Sub Ver = 01.11
DSP1 Ver = 36.61
DSP2 Ver = 39.49
Ethernet IMG = I201108100620
Ethernet BL = B200707020733-0A
Ethernet CNE = C20110810
WEB = W201108100632
GUI FPGA CONFIG = A080719A
GUI PRG = 00007621
GUI DAT = 37750020
DGTL PLD = 00.50
post #3782 of 3803
Having issues with a 3808 firmware update, followed all the steps, direct connection to my router verified good fast internet connectivity (50 Mbps cable), 5 min power off, retry always failing at 21 min sub firmware update. Receiver is effectively a brick at this point. Any suggestions? Has anyone updated in the last month successfully?
post #3783 of 3803
TRied again this morning, still the same issues. Gets to 21 min on "sub firm" and fails. Sent e-mail to denon, will see what they say.
post #3784 of 3803
anyone here has verizon fios able to update the denon avr 4308ci still stuck at 0.44 firmware cant seem to update it help did the power on button arrows up and down still nothing
post #3785 of 3803
Main Ver = A2.07
Sub Ver = 01.11
DSP1 Ver = 36.61
DSP2 Ver = 39.49
WEB = W201108100632
GUI PRG = 00007621
GUI DAT = 37750020
DGTL PLD = 00.50
USA west coast, today ... took about a half hour. No issues (connected using netgear ethernet over powerline).
GB
post #3786 of 3803
Just did the Firmware upgrade on my 4308CI for the Dynamic EQ and Dynamic Volume. Firmware worked great however I can't turn on the Dynamic EQ or Dynamic Volume in the Audyssey menu. They are there now but they are not selectable. Is there a trick to doing this? Your help is much appreciated. smile.gif
post #3787 of 3803
Try running AUTO SETUP again.
post #3788 of 3803
is there one for 3808ci
post #3789 of 3803
I should have said New Feature Upgrade not Firmware. Thank you for your suggestion jdsmoothie. I was afraid of that. My dogs are never quiet when you need them to be. I am going to give that a try tomorrow morning.
post #3790 of 3803
Yup ...
http://usa.denon.com/US/Support/Pages/upgrade.aspx
post #3791 of 3803
Recalibrating the auto setup worked like a charm. Thanks for your help!
post #3792 of 3803
Sure. Also note that Audyssey must be enabled to use Dyn EQ which must be enabled to use Dyn Vol. Dyn EQ will boost the bass and surround channels at volume levels lower than the "reference" volume of 0db which can sometimes be too strong for TV and music source dialogue from the center channel. The newer models that feature Dyn EQ/Vol also come with another feature called "Reference Level Offset" which can be set to 10db to improve the center channel dialogue for TV and music sources. You can do the same by setting the "Source Level" setting for the cable/sat box or music source to -10db which will then require you to raise the master volume louder to get to the same level as before, thereby decreasing the impact of Dyn EQ.
post #3793 of 3803
Just updated 3808 after retrieving from storage since 2009. Now in new home, new media room. Update from Ver A1.94, update took 65 minutes via ethernet-over-powerline to Cox cable modem.
Now at
Main Ver = A2.07
Sub Ver = 01.11
DSP1 Ver = 36.61
DSP2 Ver = 39.49
WEB = W201108100632
GUI PRG = 00007621
GUI DAT = 37750020
DGTL PLD = 00.50
USA, Scottsdale, AZ
post #3794 of 3803
Is it really necessary to update the firmware?
I cant tell you what firmware it currently has, but I can tell you it (3808) was purchased in July of '09.
I have no complaints as it has served me very well.
Probably the biggest reason as to why I haven't upgraded the firmware is because my router is far away from where the 3808 is located. I know I could just take the 3808 closer to the router, but it's in a cabinet and has alot of wires connected to it. Just too much drama. If I decide to ever upgrade the firmware I will buy a looooong ethernet cable.
Here is what I have connected to the 3808:
- 80" Sharp LED
- "Phat" PS3 used mostly for BR and some gaming
- Apple TV
- Panamax M5300-PM
- (2) DefTech towers BP7002
- (1) DefTech center speaker C/L/R 2300
- (4) Speakercraft AIM8 mounted in ceiling
So the question is, am I missing anything by not upgrading the firmware? Also, is there a way to find out which firmware is installed on my 3808?
TIA!
post #3795 of 3803
post #3796 of 3803
post #3797 of 3803
Hello, I apologize in advance for my english...
I have a 3808 that was never updated, so i decided to do it now, but i have an error "login failed" (Internet radio play, so it means that internet work. and i have already done "factory reset")
What I'm missing?
Main Ver = 01.05
Sub Ver = 00.24
DSP1 Ver = 36.47
DSP2 Ver = 39.37
Ethernet IMG = I200707310746
Ethernet CNE = C20070731
WEB = W200707310749
GUI FPGA CONFIG = A070629B
GUI PRG = 00007621
GUI DAT = 37750004
DGTL PLD = 00.50
post #3798 of 3803
You may find that you are "too far" in Internet terms. The older/original versions of firmward had a TTL lilmit in terms of the number of hops from you to the servers in the Far East. See http://www.avsforum.com/t/995566/denon-3808-4308-5308-firmware-tracking-thread/1890#post_14624643 onwards.
(Try a traceroute to the IP given and count the hops...)
post #3799 of 3803
Thanks for the response, I did a "hard reset" 5 times and turned off UPNP in router. So i have updated to 2.04... and know i have ordered Upgraid kit
post #3800 of 3803
When I try to navigate to those pages, I get this message:
Site Blocked!
The Wetpaint site you've requested has been blocked by Wetpaint.
— The Wetpaint crew
Has there been any new firmware released for the 3808 recently? I think mine has the latest version already, but I'm not sure.
post #3801 of 3803
Site Blocked!
— The Wetpaint crew
No updates for quite a while now, but don't remember when last one was. Not sure what's up with Captavs firmware pages, but later today I can pull my versions and post them if you want.
post #3802 of 3803
No need, but thanks for offering!
post #3803 of 3803
del
Edited by lansings - 1/26/13 at 3:09pm
