Originally Posted by rdgrimes
Better amp section, yes. Yamaha does have a compare function, jes sayin'.
The 667 and 765 have basically the same amp section. It's just smoke and mirrors to claim an extra 5W per channel for the 765, given that they have the same 400W electrical power consumption and both specs are for 20-20kHz, 0.08% THD, at 8 ohms.
On the other hand the 665 really is a weakling, with an integrated amp and 270W max power consumption. So they had to use 1kHz, 0.9% THD specs in order to claim 90W per channel. But Yamaha got so much criticism for pulling that trick on the 665, that it was relegated to the 567 and lower this year. The 667 is back to where the 663 was (or at least close to it).
So if you're interested, go check them out.
