Originally Posted by germanplumber
It is my understanding the LFE track of the 5.1 signal over multichannel is sent -10dB compared to rest of the track to not overload the amp. Some receivers correct for this, and some need to be set back to the correct levels. After listening to a movie over optical (which is set correctly automatically) and then trying over multichannel outputs, I can tell that the sub is nowhere near where it should be over multichannel outputs.
I'm just trying to set it back to correct levels. Is this not correct? Does the yamaha 663 already correct for this when using multichannel?
For analog multi-channel, the player is supposed to provide the +10dB boost to LFE. The 663 doesn't have a analog LFE Boost ability.
See my post here: http://www.avsforum.com/avs-vb/showt...3#post14013153
In a nut shell:
http://www.avsforum.com/avs-vb/showt...9#post13664569
To keep it simple the device with the DAC should apply the +10db boost. When passing by HDMI the AVR is the DAC so it applies +10db boost and player does nothing. When player is outputting analog it is the DAC so it applies the +10db boost.
