Hi folks - quick question about the test tones -
Its been year since I set up the unit the first time, so I don't remember for sure, but should the test tones sound the same from the same type of speaker? I'd expect the test tones to sound different from one speaker type to the next, say a left surround speaker versus the center, but in my case there is a noticeable difference in pitch, possibly volume too, but certainly pitch between speakers of the same type - so take the front left and right channels - same speaker, so I'd expect them to sound the same, but they don't. I thought perhaps the test tone was deliberately slightly different in pitch / tone as it moves around so that its easier to pick out when it switches speaker - but I've no idea if that's true and I don't remember how it sounded the last time when the speakers were new.
I checked the speaker levels and other settings, all the same for speakers of like-type so there should be no difference. The only other difference (though I cant believe t would make this much of a difference) is the speaker wire. One has 16 gauge wire, the other smaller, probably 18, though otherwise good quality wire.
These speakers aren't exactly high quality either, so it is possible the difference is in the speaker itself - I wouldn't take a bet on how matched they were from the factory.
Allan.
Allan.
