Originally Posted by
rtlancaster
Hi everyone,
I was hoping someone could offer some advice. I was dusting today, and (because I'm an idiot
) I wiped the cloth over the front of my Dynaudio Focus 220 speakers. The dome on the top driver is now caved in (photo attached). Is there a way to fix this?
-Todd
You are in Boston, did you get the speakers from Waltham (goodwins)? If so, call up your dealer to see what they say (I am sure they are authorized Dyn and have fixed similar problems and can give you tips). Otherwise, I would start with using a tape that I knew wouldn't damage the tweeter chemically, maybe masking tape.
