AVS › AVS Forum › HDTV › Local HDTV Info and Reception › Columbia, SC - HDTV
Columbia, SC - HDTV - Page 208
post #6211 of 10033
Do not worry we are sure to get the little card by years end.
post #6212 of 10033
Without a doubt, and with no increase in channels. Still no NFL Network, ESPN2-HD, ESPN-U, StarzHD, Cinemax-HD, National Geog-HD, etc, ............
Oh I forgot, we did get the on demand commercials channels
post #6213 of 10033
yea, the more I read and research, the more it looks like staying with Dish and upgrading to Their HD plan and equipment will be the best option. Having the Braves in HD is a big draw for me, but I think that Dish is more on top in terms of HD.
I have to decide soon, my TV will be deleivered in the next 3 days..
post #6214 of 10033
Would you really expect TW to give you what you might want! TW is your father and they will tell you what you need!
post #6215 of 10033
Especially if you like an overly compressed soft looking HD picture.
post #6216 of 10033
Makes sense Diana about The taxes and fees and such.
One reason I thought it may be available there is because I have in the past, gotten a mailing from TWC with a very detailed breakdown on the prices with everything included. It was a little paper rate card type mailing. I think they put it out because of the rate increases that were about to happen at that time.
I think I have gotten the info that I need from some friends on another board!
We work very hard on the Annual Price and Product Review....
You can always email me at twcscnews@twcable.com with an address and I can get very close to an exact amount for you.
post #6217 of 10033
Can someone please give me some details about the HDDVR's from TWCSC? Or point me in the right direction. There may be info in this thread, but there are 208 pages, so it would take a while to dig through.
Are their more than one Model? If so, which ones are the best. Also What are the connection options?? Do they Have HDMI or DVI, both?? I assume they have the standard RCA, Composite and Componet and probably S-Video outs.. Just wanted to figure out what I might need cable wise..
post #6218 of 10033
Best way is to do the research using the search function.
post #6219 of 10033
the 8300HD would be preferable to the 8000HD. it has HDMI, all the analog outs you mentioned, a choice of optical or coax digital audio out and an active firewire port.
the 8000HD has DVI but as far as i know it was never activated, you would be limited to component outputs. the analog video outputs were only activated with PIP or Save to VCR functions.
post #6220 of 10033
Yea, I guess I could spend 1-2 hours reading and searching. Not a huge deal. But maybe someone that knows off the top of their head could take 5 minutes and type out a response that has the info to help save time. On many of the other boards that i frequent, thats what I do all the time to help people save time..but thats just me.
post #6221 of 10033
8300 with HDMI is available, no DVR with active DVI output is available.
8300 has better PQ than 8000
There is a 3250 with DVI active, but I know you are most interested in the DVR.
TWC only provides component cables. Customer's who desire to use the HDMI or DVI connection must purchase their own cables.
post #6222 of 10033
The problem is you did not ask for just a suggestion; you wanted details. And details often cover many aspects of said machine (and trying to talk cogently about same often takes me a bit more than five minutes but then again I am slow). Searching is definitely hard yes (I have not tried here recently myself) but I know there is a wealth of information here in our forum because we have covered this topic numerous times before and I know I do not have all the answers. I might also suggest you visit the HD recording forum here at AVS plus Scientific Atlanta's own website.
However to expand slightly on Scruffy7's info (and Diana's too now for I am really slow tonight) ... there are two DVRs currently available from TWCSC. The older model is the the SA8000HD DVR and it has a 160GB hard disk (~20 hours of HD recording time available); (inactive it would appear) DVI and active Component/YPrPb ports. To my knowledge the analog ports (composite; S-Video) are not activated other than working thru the VCR out (a hassle and generally not worth trying). I believe it also has a Firewire port which is not active either. (TWCSC may have some SA3250 HD converters that have active Firewire if needed).
The 8300HD DVR is slightly newer, has HDMI with HDCP, active analog ports, better HD PQ (an opinion shared by most) and better upconverting capability as well. It too can only record about 20hours of HD. However, it does have a SATA port and some forum members here have been able to buy the requisite SATA hardware and connect it up and find it works. The 8300HD also has Component YPrPB outputs (what I use) and a more sophisticated menu of output resolutions. Unfortunately I am not well versed in how those work and would have to recommend you find the manual off of the SA site. I use 480i/1080i output myself I think. It is Set and Forget and I have definitely forgotten how to use it (but I do have the instructions printed out somewhere on how to set it up; they were downloaded from the SA website).
Both of these DVRs burp on occasion; the firmware has a few bugs. They frequently upgrade it (generally at o'darkthirty) sometimes they fix an old problem and invent a new one. They are also ocassionally add some new features though there are some areas that still fall short in the eyes of many users. However, it is still a worthwhile box to rent unless you are a TiVoholoic in which case I suggest you immediately go with DirecTV and don't pass Go. (I cannot speak how well it compares though to DirecTV in-house brand of DVR nor those provided by Dish Network). Most of us with the 8300HD definitely recommend all HD viewers go and get one.
Many viewers here use HDMI just because they can. The PQ improvement over YPrPb may be significant; may not be. Might be worth checking out and trying the Component outputs since TWCSC Component cables are generally very usable and they come with the DVR. Be advised that sometimes there are switching problems for those who wish to use a A/V receiver with HDMI. HDMI cables from local retailers are often very costly (reasonable priced ones are available over the internet). Starting out with Component cables may be a reasonable choice for the PQ may be fine and gives you a chance to mail order some rather than having to secure a second mortgage first so as to buy them from your local discount retailer. (yes; oxymoron there).
Now, if you go to your local TWCSC office and ask for a HD DVR they may try to give you a 8000. The stock number for a HD DVR is apparently the same for both. So ask for an 8300HD DVR. If they don't have one in stock and you are in Columbia... go try a different TWC office. The Greystone office usually seems the best choice to get one at. Sumterites and some other smaller markets generally have only one local office to visit and so are stuck having to keep trying to get one from that one location.
So, suggest you go get one pronto and give it a try. It will cost you about $5/mo more than a SA3250HD (regular HD converter) and if you don't like it you can swap back for the 3250HD box. Holler if you have further questions.
____
Bruce
post #6223 of 10033
There is now both a 3250 and an 8300 with Firewire active, but you have to turn the unit over and look for a specific number on the bottom of the chassis - and you can't get one through the call center, because just like the difference between an 8000 and 8300 - the billing system just knows a the whole unit, not the model number or what part may be active at a time later.... yes I know, not very customer friendly - I have yelled my head off about it....
Please note, due to Construction, the Greystone Office closed for good this past weekend. There is no replacement for that location right now, so we suggest Harden Street or Sunset Blvd. We will have another major location open in a month or so.
post #6224 of 10033
oops
I stand corrected...
post #6225 of 10033
Everybody here please email TWC and share your thoughts on new HD channels.
We all have a couple minutes to spare to post here so please Email Corporate.
Fred.Dressler@twcable.com
Let's be civilized.
post #6226 of 10033
Thanks for all the Great Info.. I appreciate the time and effort
post #6227 of 10033
A big thanks goes out to Diana from TWC.. She has been a huge help this week in my decision process.
post #6228 of 10033
Whats the deal with channel 813(TWCHD)? If I turn there I see a black screen with title "BRAVES HD", but there is never a game on. Are we supposed to be getting Braves HD or not? I have the HD tier.
post #6229 of 10033
I think they may be on 814 for braves home games in HD.
post #6230 of 10033
Only the braves home games carried on TBS.. And Turner south through the end of April at least.
The braves are on a road trip right now
the next HD game is Saturday..
http://www.twcsc.com/AllHosted/DigitalSportsTier/BravesInHD2006.aspx
post #6231 of 10033
813 is TBS Home Games. 814 WAS Turner South Home Games. Here is the link for the schedule when games will air. This is not a 24/7 channel - only when it is a TBS Home Game.
http://www.timewarnercable.com/south...eChannels.html
Now, about Turner South - I do not know. We asked FOX Cable Networks representatives if we would continue to be able to provide the Turner South Home Games to our customers. They were not even aware of Turner allowing us to do that, so they didn't have an answer. I will send them another email asking if they have made a decision on this point yet.
post #6232 of 10033
http://www.hd.net/program_search_res...tosearch=title
Dead Like Me on HD Net
One of my personal favorites - cancelled before its time. If you never saw it on Showtime, watch it now!
post #6233 of 10033
On the 8300HD, is there and audio optical output that works along side the HDMI out??
I want to hook the HDMI into my TV, but I won't be using the speakers on the TV, rather I would like an digital optical output to run the audio through my receiver
post #6234 of 10033
Yes
post #6235 of 10033
You can research everything on the SA website - "User Guides, Installation and Wiring Diagrams".
post #6236 of 10033
Gary, it really wasn't hard for me to answer "yes".
post #6237 of 10033
Just adding additional resources to your explanation.
post #6238 of 10033
I take it is going to be a no-go on the braves hd on turner south from here on out??
I noticed it isn't on tonight. I know we were told it might happen, but i was holding out hope it would stay on
post #6239 of 10033
Noticed it too, but at least the non HD tier subs get their free INHD channel. Maybe ESPN2HD will be added to make up for it.
post #6240 of 10033
Diana,
Is there a 8300 DVR with firewire and if so what is the best way to get it and activate the connection on it.
