AVS › AVS Forum › HDTV › Local HDTV Info and Reception › Columbia, SC - HDTV
Columbia, SC - HDTV - Page 305
post #9121 of 10058
Agreed.
post #9122 of 10058
All,
I'm moving to Sumter, SC, in a couple months and am trying to choose between TWC and Dish Network. What do you guys recommend? I checked the rates through Dish Network and am very tempted to go with them. I guess I've been burned by Cox Cable for the last couple years (constantly rising rates) and am looking towards dish. Let me know what you think!
Casey
post #9123 of 10058
Why don't you just do a cost/benefit analysis? Look at the cost of packages that best include the channels you are interested in and factor in any up-front costs and commitments.
post #9124 of 10058
Thanks for the tip--I'll have to check it out...
post #9125 of 10058
Bob,
I currently have an rca flat 1450 amplified antenna. The reception comes in around 40% or so...oddly enough i still can't tune in ABC though.
ncxc stud gave a tip about a radio shack antenna, perhaps I'll try that...
post #9126 of 10058
Originally Posted by danfromjersey View Post
Bob,
I haven't tried that particular RCA unit, but I can tell you just by looking at it that VHF high performance will be compromised.No antenna, depsite fancy design nor cost, whether high or low, can overcome the laws of physics. You can try the one studman mentioned, bear in mind that no antenna is ideal for all situations. Also, moving it slightly in position can make all the difference.
Try the one studman mentioned, we use one of those for WOLO and it works well.
Here, I have a square shooter, and get ALL the locals fine, excpet WTVI(PBS)
which is on VHF 11. Since there are 2 other PBS here, (which is still 1.8 too much) I don;t care about WTVI.
post #9127 of 10058
Has anybody else been having trouble w/their SA8300HD box since the wknd? Mine has gone totally whack!
Harold
post #9128 of 10058
The box did wig out Sunday night....Blank screen on all but major networks. A reboot fixed it.
Jon
post #9129 of 10058
Man, I can't believe this is happening right as the World Series is about to start. And if I have to go get a new box I'm going to lose about 50 movies and tv shows I have recorded.
This settles it. As soon as TWC makes the SDV tuning adapter available I'm getting a TivoHD box. This is absolute BS.
H
post #9130 of 10058
No problems at all here in Lexington with either of my 8300hdc.
post #9131 of 10058
I climbed in bed Monday night and turned on the TV, began flipping thru TWC..and suddenly the box decides it needs to reboot..10 minutes later I had Tv back..
post #9132 of 10058
Originally Posted by fiteclub View Post
Just FYI
I went to WLTX studios last Thursday upon an invitation by Terry Wright. He wanted to show me all of the changes that they are going thru. They are in the process of upgrading their entire package audio and video processing equipment.
Their upconverted SD used to be pretty crappy (very soft, with muddy colors), which was one reason I hardly ever watched their local news programs. The other day I happened to tune into their news and was pleasantly surprised by how much better it looks now. This also improves network stuff that's sent out in SD such as the CBS "Early Show." It's now pretty close to WBTV in Charlotte, and better than WSPA in Spartanburg.
[added] And they can now do widescreen "crawls" without having to drop back into SD. I saw one for the SC Lottery results when I was home for lunch yesterday. The program wasn't actually HD, just upconverted SD, but the crawl bar extended across the full 16:9 image and the PQ was unaffected.
post #9133 of 10058
Looks like us Tivo CableCard users crippled by SDV can finally see some light at the end of the tunnel.
There has been alot of talk lately about the SDV Tuning Adapter, even some reports of it out in the "wild" in a Comcast market.
TWC finally has a page up to pre-order it.
http://www.timewarnercable.com/carol...ble/SwitchedDi
post #9134 of 10058
I just noticed this on TWCSC.
Oct. 29, 2008
Bio HD will launch on Digital Cable Channel 852.
Speed HD will launch on Digital Cable Channel 954.
post #9135 of 10058
Can anyone find where to pre-order on the SC TWC website? I ain't getting it.
Harold
post #9136 of 10058
http://www.timewarnercable.com/tuningadapter
there was a link for "How do I get the Tuning Adapter?" I clicked that and said to fill out the survey on the above link...
post #9137 of 10058
I don't get a survey when I click on that link. I get a page saying to enter my zip code and when I do it takes me to the SC TWC home page, from which I still cannot find where to sign up for the tuning adapter.
H
post #9138 of 10058
H
When you get to that point to a search of "sdv", it will give you 3 results, pick the first one, the one with the FAQ. All the info is there.
post #9139 of 10058
Am I going crazy? I've done that. When I click "How do I get a TA?" in the FAQ, it takes me to a link, that link takes me back to the page asking for the zip code in my area. It's circuitous. I still cannot find any place to pre-order the TA in SC.
Harold
post #9140 of 10058
Oct. 29, 2008
From today's State Newspaper that Weather Channel HD is coming as well. No channel number listed.
post #9141 of 10058
I'd like USA and CNBC in HD permanently..
post #9142 of 10058
Second on the USA HD permanently
post #9143 of 10058
Looks like FX HD is coming to TWCSC in the near future. There was a press release from Greensboro, NC that being added to TWC Carolinas. http://www.news-record.com/content/2...11_hd_channels
post #9144 of 10058
post #9145 of 10058
good catch!
post #9146 of 10058
Question for the locals:
Can I pull in the local CBS-DT (WLTX) station with a good UHF antenna? I'll be tailgating near Williams Brice and don't want to fool with the dish. I'll be using a Zenith Silver Sensor antenna and a Vizio HDTV with atsc tuner. What channel am I looking for? Or should i bring the dish? Much thanks in advance..
edit: looks like I am looking for 19.1. Anyone have an opinion what my chances are? Thanks.
post #9147 of 10058
You should be fine, but go to
http://www.antennaweb.org/aw/Address.aspx and enter this address:
1127 George Rodgers Blvd
Columbia,SC 29208
It will give you Antenna size and Compass Orientation and a street level view to help lock in on all the local siginals.
post #9148 of 10058
I use a basic old tv top uhf/vhf antenna, I think it was like ten dollars, I park in the fairgrounds so i have a clear line of sight in pretty much any direction, but I believe you should have no problem no matter where you park. I get all 4 of the networks in HD with no problems. I don't know if you will get abc in HD with just a UHF antenna though if you won't to switch to the game on abc.
post #9149 of 10058
Ditto on the fairgrounds tailgating. I pick up all 4 stations just fine with a regular set of rabbit ears. I do place the rabbit ears up on top of our vehicle though.
post #9150 of 10058
Ahhhhh. To order the Tuning Adapter:
http://www.timewarnercable.com/SoCal...v/default.html
