Hi all,
My Vista Media Center is refusing to play many of my mkv files in their proper aspect ratio. Hitting the info button and changing the zoom doesn't help because none of the settings it cycles through are right.
1280x720p 16x9 mkv files play with black borders on the sides of the picture (should be full screen on my 16x9 HDTV).
2.35 to 1 mkv files play stretched to full screen on my 16x9 HDTV (should have black bars on the top and bottom of the picture).
Again, hitting info and cycling through the zoom settings doesn't help because none of the settings it goes through are correct.
This does NOT seem to be an issue with MPEG-2 ts and mpg files, only mkv files.
The HDTV is a 36" CRT using component video connection (TV is too old for HDMI/DVI).
Any idea how to fix this?
