AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Digital to analog HD sound converter????
post #1 of 25
I have a Yamaha RX-V659 that I love. I would like to send the HD soundtracks on movies via HDMI to an analog converter that I can send ot the 5.1 discrete analog inputs. Does anyone make this and if they do'nt, they should.
post #2 of 25
It's called a new AVR / Processor and/or using HDM players that have multi-channel analog output.
It would have to have all the software, legacy and lossless as well as extremely high grade Multi-channel PCM to extreme high quality analog outputs.
post #3 of 25
Well don't that just stink. Guess I 'll be putting the 659 on the market.
post #4 of 25
OR buy a player that has analog outs and can decode the formats to analog!
post #5 of 25
Gefen is promising to offer something that will do that. There's already a thread on it here and early announcement at the Gefen website. I saw a mockup at CES.
post #6 of 25
Really? I think if it works well, I bet it will sell well to alot of PS3 owners who have non-HDMI receivers.
Edit: I believe to have found the item in question from the thread Mr. Rubinson was talking about, but idk if it is the same one shown at CES. At $400, I retract my previous statement about it selling well.
http://www.gefen.com/gefentv/gtvprod...p?prod_id=5277
post #7 of 25
Dunno. Might be to pricey for them.
post #8 of 25
Yea, I just found that out and edited accordingly. Too bad
post #9 of 25
ooooohh, this gefen converter sounds like the gadget ive been waiting for so i can have surround sound and still use my 34 yr old pio quad amp.
YIPPEEEEEEE !
and its got (small) power amps onboard! whoooaaaaa!
post #10 of 25
PS3 will be my player of choice, until dedicated players with analog outs come way down in price I guess I will have to settle for plain old DTS and Dolby farmats. I really wouls like to hear the difference in the HD formats though.
post #11 of 25
Has anyone purchased of the GefenTV audio processor and tried it?
post #12 of 25
Not possible yet.
post #13 of 25
Kal, is it not shipping? It is listed as purchasable on the Gefen web page and it certainly goes into the shopping cart.
post #14 of 25
I was told it would not be shipping until the end of March. I have not seen one yet (and I have asked).
post #15 of 25
bump
post #16 of 25
Why would they not make this with at least 2 or 3 HDMI inputs? This device makes no sense to me.
post #17 of 25
good question. dont have answer.
im considering one ('supposed' to 'street' for under $300); if it works well with one source i'll then have to add an hdmi switch for multiple inputs. (more things to go wrong)
i called gefen last month; gent said device should be out end of june, '08; along with realta based video processor.
post #18 of 25
I found this device:http://www.cypuk.com/cyp_techpage.ph...ct=313&&parent
Looks like the gefen product but cheaper, if I converted correctly. I can't seem to find it for sale in the states. There are a few people on the avforums that are using with their ps3.
post #19 of 25
Cannot decode the HD codecs but will work if the player converts them to MPCM.
post #20 of 25
From my interpretation to reading the info about it, one would think it would be capable to do so. Especially after reading the PDF...
post #21 of 25
Read it carefully. HD codecs via HDMI to HDMI. MCH LPCM via MCH output ports.
post #22 of 25
Ah yes my mistake. For some unknown reason, I was forgetting to look at the output section for MC analog, and instead looked at HDMI.
post #23 of 25
Yeah. It is too bad but the cost of licensing the HD codecs is probably out of the range for a small manufacturer of a low volume product.
post #24 of 25
Very likely. Considering this product is intended for a small number of consumers.
post #25 of 25
I'm confused. So this won't work with a ps3? It says supports LPCM 7.1 channels output through multi-channel output ports. Doesn't the ps3 output LPCM?
