I put 4 little rubber feet under my 360 last week. I put them next to the existing rubber feet. Since I did that, the amount of noise from the DVD drive and fans has dropped by a ton! This should also increase the cooling ability by increasing the space between the 360 and the shelf it sits on.
I got the feet at Radio Shack. The mall stores don't carry them. But the ones in the plazas that sell more electronic stuff have them.
$1.99 for 12 of them.
http://www.radioshack.com/product/in...entPage=search
And since you don't open the box, there is no issue with the warranty.
Basically, the feet help to dampen the vibration of the 7000RPM DVD drive and fans, quieting the console a lot.
