AVS › AVS Forum › Gaming & Content Streaming › Home Theater Gaming › Xbox Area › Huge decrease in XBox 360 noise for $1.99
Huge decrease in XBox 360 noise for $1.99 - Page 2
post #31 of 45
I found some similar things laying around, but forgot about' em. Put em' underneath, and voila, 360 is definitely quieter. I'm gonna pick up the jumbos, though. Raising the 360 just a couple inches makes a difference. Yay!
post #32 of 45
Originally Posted by newfmp3 View Post
lol.
I solved my noise issue with my 360 by getting 30 foot cables, sticking the darn thing in another room downstairs, and with the wonderful wireless controllers, I game up stairs....noise free.
I pictured somebody trying to stack rubber cables under their console
post #33 of 45
I hear if you wrap your "system" in a "rubber" it is better protected
post #34 of 45
Originally Posted by cap_167 View Post
To the people who have purchased the rubber feet, do you guys have it set up vertically or horizontally and have you noticed any difference in noise because of the way it's sitting?
I have it vertically and noticed a reduction in sound. My 360 sits on an wooden endtable for materials comparison.
I'm going to try it horizontally tonight to see if it's less.
post #35 of 45
I ran over to HD at lunch, and got a 12-pack of the Clear 3/4" Sqaure Feet for <$3.00; if it works, I have 2 more sets to give to friends as Easter/Passover gifts... I'll be a hero!
I don't know if anyone mentioned this:
I got a noticeable noise reduction from adding one of those "skins" that they sell at BB for $10. My white Falcon Pro was ugly in my AV rack, so I picked one up; the thing is made of thin foam-like material, which definitely deadens the sound. It does not seem to make my Falcon run noticeably hotter, and the feet mod should now compensate with increased airflow.
post #36 of 45
Originally Posted by Vincent Kennedy View Post
I would if they had a shelf/faceplate that would hold my HD DVD drive on top of the Xbox 360 like I have it now. I do not want to use 5U of space for my Xbox! (3 for Xbox, 2 for HD DVD Drive)
Even a stand-alone HD-DVD player would still take up 2U anyway.
post #37 of 45
I placed it horizontally last night with the rubber feet and didn't think I noticed any less noise. Going back to vertical tonight to make sure.
post #38 of 45
I'd leave it horizontal just for the increased cooling you get from not having that perforated side blocked off.
post #39 of 45
Originally Posted by KoRn View Post
I got these from RadioShack instead.
http://www.radioshack.com/product/in...entPage=family
They work way better than the ones you posted. The ones you posted I had also tried them before. These bigger ones lift the system higher allowing even more air flow and it being more quieter.
I installed these on my new Elite as well today. They definitely raise the console a good 1/4 inch off the shelf. I don't notice much of a difference noisewise (although the Elite is pretty quiet to begin with) but hopefully they'll help keep it cooler for the long haul.
post #40 of 45
i bought pack of twelve from home depot while picking up some painting supplies the raise it 3/8 of an inch and the thing is way quieter, also it does not heat up as fast so the fans stay off. great idea
post #41 of 45
monoprice.com 30 foot component or hdmi cables...noise gone.
Thanks, that worked great in my 600sq ft apartment
post #42 of 45
So you're the jackass above me who plays Halo 3 all night with the volume cranked to 11 ... Hold on, I'll come upstairs and "silence your 360" for you with my nine-iron.
post #43 of 45
I must be going deaf ,I cant hardly hear my 360. I hear the fans kick on once in awhile but it doesn't really annoy me. Ignorance is bliss.
post #44 of 45
lol.
What/how was your solution for IR extenders (for the wireless console controller)
post #45 of 45
lol.
Same here. 30' HDMI cable and no noise issues. Also helps keep the room from getting so hot.
No need for IR extension with the 360 but I have an RF remote with base station for the other equipment.
  Back to Forum: Xbox Area
