12 volt boombox cigarette power cord help - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 06-07-2015, 05:57 AM - Thread Starter
Leeboy's Avatar
I lost my 12 volt power cord cigarette power cord , and I was wondering if anyone knew the specs on it. To replace it, they want almost $30. I'm sure there must be a cheaper off shore one I could find someplace . Thanks
Leeboy is offline
post #2 of 9 Old 06-08-2015, 08:07 PM
Super Moderator
DrDon's Avatar
Quoted: 2256 Post(s)
Liked: 4247
Gonna need more info than that. WHAT boombox? Model number, please. Once you have that, search Amazon or Monoprice using the model number, "12v" and "power cord."
Walking the fine line between jaw-dropping and a plain ol' yawn.
DrDon is online now
post #3 of 9 Old 06-09-2015, 07:32 AM
Brad Bishop's Avatar
Quoted: 13 Post(s)
Very likely, on the back of the boombox, there is a sticker or embossed plastic detailing the details of the power requirement.
The four things you need to line up are:
- size of power adapter (I don't know official sizes and usually it's just a "does it fit" sort of thing)
- voltage, which you know: 12V
- amperage, which should be printed on the sticker/plastic. You need AT LEAST that amount of amperage delivered by the power source
- polarity - which should be printed on the sticker/plastic. Normally the inside is positive but it's not guaranteed.
Brad Bishop is offline
post #4 of 9 Old 06-13-2015, 07:42 AM - Thread Starter
Leeboy's Avatar
Hi Gang, all the back says is DC power and the model number is SUBX1C
Leeboy is offline
post #5 of 9 Old 06-13-2015, 07:47 AM
petew's Avatar
Quoted: 34 Post(s)
Liked: 78
google is your friend (when it isn't spying on you)
http://www.less4gadget.com/replaceme...y-p-27126.html
Building Bass - Subs
Surrounds - Easy as Pi
Storage - unRAID unDELL
Mains - Another piece of Pi
petew is online now
post #6 of 9 Old 06-13-2015, 07:51 AM
Super Moderator
DrDon's Avatar
Liked: 4247
Except that the OP wants the car cord for the boombox. At ten bucks, it's a far better deal than trying to make one.
DrDon is online now
post #7 of 9 Old 06-14-2015, 08:47 AM - Thread Starter
Leeboy's Avatar
$10 works perfect , thanks for the find
Leeboy is offline
post #8 of 9 Old 06-15-2015, 07:54 AM
Quoted: 13 Post(s)
I wasn't saying make one. I was just saying that you'd need to know the specs to get a suitable replacement.
post #9 of 9 Old 06-29-2015, 11:38 AM
pilotart's Avatar
Quoted: 658 Post(s)
Liked: 507
You should always check the "output" Voltage (and mA rate) of your replacement power supply as so many Radio's, GPS' etc. now operate at 5 or 6 Volts and connecting them straight to your auto's 12 Volt system will surely fry them. They will usually incorporate protection from reverse polarity, but not over-voltage.
The cigarette liter plugs for my SkyFi and GPS had 'transformers' inside them to convert the 12 Volts input into the lower voltage output necessary. A six volt (input) SkyFi works fine on the 5 Volts DC output from a USB one amp or greater power Jack.
I was further able to find (in auto's fuse-box) circuits which remained 'hot' for 20-30 minutes after the car was shut off, this was handy for gas stops etc. enabling continuing trip without re-initiating GPS or for having the XM play on while unloading the car. I just soldered wires from the +/- of cig plug to the "Add-a-Circuit" or "mini-Add-a-Circuit's" sold at Auto-Parts in their Auto Fuse display's, which just insert into fuse receptacles and add a fuse and + connections.
Art
pilotart is offline
Reply XM and Sirius Satellite Radio
