Quoted: 249 Post(s)
Liked: 91
The NEW Android App
I guess the new app does have some advantages, like video and being quicker to start up... I've tried it on three different android devices and seem to be having issues with the App Download Settings:
- If I try to change "Audio download quality" to High or Maximum, it will change, but then when I exit that screen and go back to the setting screen, it has reverted back to Standard/Normal.
- If I try to change "Video download quality" to High or Maximum, it will NOT change, it remians stuck on Standard/Normal.
- I can change "Audio streaming quality" to Maximum - that does work.
I've been back and forth with Sirius "support", they must not actually use their product because all they can tell me to do is uninstall, reboot, install.
Anyone else not able to change download quality settings?
Is there any active Sirius User Forum (besides here on AVS)?
XBR-65Z9D | UBP-X700 | Xfinity 4k XG1v4 | JRMC HTPC w/9 cable tuners
AVR-X2200W | Fluance SV 7.1 + eD A3-300
