Recordings stop at weird times... COMMERCIALS. MOVIE TRAILERS,...? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 12-20-2008, 09:20 PM - Thread Starter
Guest
Quoted: 38 Post(s)
Liked: 203
More and more people are running into problems where their recordings just STOP for no apparent reason. The cause could be Copy-Once (CO) copy protection, or CO-like behavior, IN COMMERCIALS!
JVC engineering has acknowledged that the CO-protection, or CO-like behavior, is in commercials but they don't know why... yet.
This has been occurring since at least Sep 2008 on all different makes and models of recorders, some old and some new, and all kinds of commercials from auto mfgrs to pizza. Some say it might be in movie trailers with fast-action flashes, etc. The CO-protection can be in one or several of the commercials, but you'll be able to find the FIRST one cuz that's where recording will stop, either at that commercial, movie trailer, etc. or immediately after.
Programs that are CO-protected in their entirety or in elements like the commercials will record OK to only these media:
  • HDDs.
  • -RAM discs (a native VR-mode disc).
  • -R/-RW discs formatted for VR-mode.
Once on those media, they CAN'T be copied to a std Video-mode disc like the -R/-RW/+R/+RW we use everyday. They can only be copied to another HDD or VR-mode disc, which are not universally playable like our std Video-mode discs.
If you record a program to a HDD and find that it shows a CO-protection symbol on the title, you won't be able to copy/dub that title to a std disc. However, you CAN delete the commercials... or at least the CO-protected one(s)... then copy/dub it to a std disc.
7558037 is offline
post #2 of 3 Old 12-21-2008, 08:23 AM
CitiBear's Avatar
Quoted: 139 Post(s)
Liked: 145
It definitely has some connection to the accelerated preparations for the ATSC transition that many stations began in earnest this past summer. And it is skewed more heavily to over-the-air (analog and ATSC) than cable/satellite. Just from my off-line communications with other members, I'd say this issue hits hardest on those with ATSC-tuner recorders and off-the-air reception. As wajo conjectures, there might be some sort of unexpected interaction between the flash-cut editing in commercials and ATSC signal transmission that creates a false copy-inhibit trigger. I'm hearing somewhat fewer of these reports from users of older non-ATSC decks with cable or satellite decoder boxes, they are instead coping more often with overall mis-applied copy protection popping up for the complete running time of normally free-to-record programming.
One way or another, "false" copy-inhibit flags are becoming a problem for everyone: if you don't experience it directly, you'll be affected indirectly because crap like this is what causes "average consumers" to avoid buying or to return DVD recorders in favor of proprietary DVR decoder boxes. The independent recorder market is now so fragile it can't afford major stinks like this. Cross your fingers this gets worked out soon after February.
CitiBear is offline
post #3 of 3 Old 01-07-2009, 12:25 PM - Thread Starter
Guest
Quoted: 38 Post(s)
Liked: 203
Originally Posted by tmwalsh0 View Post
Not that anyone is interested in the LG, I found out that it is the LIPITOR commercials that are whacking those machines sensitive to digital rights. The one where the man is surprised to have a heart attack at 54(?) and lived in Lafayette, CA. Immediately after the first picture changes, the DRM copy notice pops up and the recording stops.
tom
Tom posted this in an LG thread... applies to this thread as well.
7558037 is offline
