DVDR3576H HDD upgrade - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 04-16-2017, 08:29 PM - Thread Starter
pmatejcek's Avatar
Liked: 0
I have a Philips DVDR3576H that works fine. I'd like to install a larger HDD -- I run out of space at the most inconvenient times... I thought that I had seen detailed instructions for installing a bigger drive years ago. Now I can't find them.
- Are the instructions available somewhere?
- How big a drive can the machine use?
- Is there an easy way to use a SATA drive, or do I have to scrounge an IDE drive? They seem to be pretty available...
- If there's an easy way to install a SATA drive, can I install an SSD? That should obviate power issues with a bigger drive.
- How big is my stock drive? I'm thinking that it's 160 GB, but I'm not sure. It would be fun to put in 1 TB, but 500 GB would make a serious difference.
Thanks in advance for sharing your knowledge.
Paul in East Troy
pmatejcek is offline
post #2 of 3 Old 04-17-2017, 03:24 AM
Guest
Quoted: 38 Post(s)
Liked: 207
The instructions for HDD replacement, plus much more, are in this help file. 500GB is max. size, limited by the FW.
7558037 is offline
post #3 of 3 Old 01-28-2020, 09:53 AM
Liked: 0
DVDR376H questions
Page didn't come up and i am unable to PM you due to low post count.
Please help
Bradwarb is offline
