AVS Forum | Home Theater Discussions And Reviews (https://www.avsforum.com/forum/)
-   DVD Recorders (Standard Def) (https://www.avsforum.com/forum/106-dvd-recorders-standard-def/)
-   -   pana DMR-HS2 tray stuck (https://www.avsforum.com/forum/106-dvd-recorders-standard-def/2927410-pana-dmr-hs2-tray-stuck.html)
metaguy 10-19-2017 03:52 PM
Thought maybe there were others with same problem.
jjeff 10-19-2017 04:20 PM
Probably not too many others out there with the ancient HS2, Panasonics first HDD DVDR dating back to '02 :eek:
While I don't have a HS2 I do have several other 10+ year old HDD Panasonics and I can say that several have a sticky DVD tray. What I usually do is if I push EJECT and only hear a humming, I immediately manually open the flap covering the DVD tray opening. Next I use my fingers to grab DVD tray and gently pull. Thats always worked for me, as soon as I start to pull the tray it opens, if the tray sticks in the open position I simply gradually push the tray in at which point it sucks it back in by itself.
I'm guessing a belt or idler pulley is shiny, giving it less grip to automatically open the tray. As pulling/pushing the tray has always worked for me, I haven't torn it apart to see if it could be serviced but I suppose it's possible your belt or idler pulley has broken, in which case replacement may be your only option.
If your not a DIY type of person you might send mickinct a PM, he's AVS's resident Panasonic repair person and should be able to take care of you.
Chingu808 11-04-2017 12:31 PM
Still have my HS2 in the closet. It broke a few months after I brought it. I forgot if it powers up or not or if there is another problem with it.
Powered by vBulletin® Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
