Extracting recordings working - Pana E500,EH50,EH55,EH57,EH58,EH59,BS750,BS780 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 04-29-2019, 01:46 PM - Thread Starter
jwillis84's Avatar
Quoted: 60 Post(s)
Liked: 53
It looks like this will be the roster for now. An alpha looks like it might be released later this week.
The E500H and probably the E100H and HS1 families use a special form of the UDF file system which Peter had to give special attention, delaying things a bit.
Also I ran into some Jumper issues with the IBM Deskstar drives from the E500H and earlier.. using a USB dock made those issues go away.
We are trying to fill in gaps.. but the coverage across models is pretty broad.
jwillis84 is offline
post #2 of 3 Old 04-30-2019, 02:27 PM
jjeff's Avatar
Quoted: 888 Post(s)
Liked: 340
Nice
Can we assume the much more common E80H(the same year as the E100H but while the E100H had a 120GB HDD the E80H had a 80GB HDD) is also supported?
Also there was a popular series that ended in a 5, the most common model being the E85H(same model year as the E500H to confuse things) any support for those?
If you haven't seen it, here's a link to a post I made many years ago that detailed the various US and some international Panasonics model numbers and years, might help??
https://www.avsforum.com/forum/106-d...-features.html
Never heard of those "BS" series Panasonics, they must be PAL only??
jjeff is offline
post #3 of 3 Old 04-30-2019, 03:25 PM - Thread Starter
jwillis84's Avatar
Quoted: 60 Post(s)
Liked: 53
Originally Posted by jjeff View Post
Nice
I think it would be a safe assumption those are covered.
I received access to the latest and 'last' potential alpha for a long while (today) and tested it against an E500H and it works.
The E500H was the last in a line of UDF format 'based' recorders in a curious format.. its very likely the E100H and HS2 families are also included, but until tested we cannot be certain.
