Verified support for Panasonic E80H, E85H, E95H in IsoBuster 4.4 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 07-10-2019, 04:00 AM - Thread Starter
jwillis84's Avatar
Quoted: 60 Post(s)
Liked: 53
The Panasonic DMR-E80H, E85H, E95H have been tested with IsoBuster 4.4
They are readable and can export recordings direct from the recorders hard disk to a PC, Mac or Linux system running IsoBuster using a garden variety hard drive to USB bridge. I've used both a Startech USB 2.0 dock and a Ugreen USB 3.0 dongle.
These are new additions to the verified "compatible" IsoBuster list. Previously it was assumed but unverified they would be compatible. They are members of the E100H and E500H "families". it was estimated they would use the same pseudo file systems. This turned out to be correct.
The PC has been tested with XP, Win7 and Win10 running IsoBuster 4.4 so the operating system version really doesn't matter, 32 Bit and 64 Bit versions of those operating systems are also supported. There are "no" device drivers to install associated with IsoBuster, so there is no need to worry about a Microsoft update messing things up.
A Maganavox H2080MW8 is schedule to be tested today.. and then that may be all for a while.
jwillis84 is offline
