Toshiba dvr20kb DVD/VCR - Suddenly records black with no sound?? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 09-08-2019, 05:56 AM - Thread Starter
Liked: 0
First, please let me explain I'm a simpleton about things like recorders and such.
My Toshiba dvr20kb DVD/VCR which had been happily working - suddenly I find (from bringing up recordings on the menu - Sorry but I told you I was a simpleton in this regard) - brings the recordings up on the menu with a black screen and no sound.
I've tried to go in and check the connections but everything seems - and I stress seems - to be connected. Certainly the television is being seen through the scart connection ... and it loads and takes the recording commands fine - with no problem.
Maybe I just need to get another machine. Maybe something inside has just worn out. That said I don't hear any strange noises or such.
If you can help me by suggesting what I should or might do I would be ever so grateful.
Thanks so.
meunier007 is offline
post #2 of 3 Old 09-08-2019, 06:16 AM - Thread Starter
Liked: 0
Oh, should perhaps say that I can see previous recordings from the menu fine .... so the machine is working in that element.
Not sure if that is helpful or not.
post #3 of 3 Old 09-08-2019, 07:35 AM - Thread Starter
Liked: 0
Don't worry. I just figured it out .... The machine is working again.
All best wishes.
