Toshiba DVR620, DVR670: Same Drive? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 11-06-2019, 10:32 AM - Thread Starter
Liked: 0
The DVD in my digital tuner-equipped Toshiba 670 has stopped working. It just won't read any disk, even after cleaning the lens. I recently acquired a tunerless 620 model which plays and records disks fine. Only problem is I have to use a digital to analog converter box between my outside antenna and the recorder.
Do the two models use the same disk drives? If so, I'm thinking about switching the two drives, so I would have a fully functional DVD recorder with VHS which doesn't require a converter box.
jumprun3 is offline
