Connect Magnavox DVR to Samsung via Composite - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 01-26-2020, 11:29 AM - Thread Starter
Liked: 0
I'm trying to connect a Magnavox DVR (MDR557H) to a Samsung Smart TV (UN40MU7000F) via composite or component cables (yes, I can use HDMI, but there's a reason I'd like this to work) but Samsung says "no source" when I try the composite & gives no option when I try component.
The Samsung TV (Series7) has two options for A/V. There's a yellow input for composite. So I insert the small yellow cable (yellow input) with white, yellow, red connectors on the other end which I attached to one end of the composite cable with the other end of the composite cable attached to the composite OUT outputs on the DVR (white, yellow, red). I select the A/V option on the TV (one of the Sources) and it says no source found.
So I tried the RBG. There's a little cable with a blue input and two connectors (red and blue). I attach those red and blue cables to the red and blue connectors on one end of the rbg cable (leaving the green connector open). I plug the other end of the cable (red, blue, green) into the RBG outputs on the DVR. When I do this and go to the Source selection screen on the TV, there is no A/V option of any kind.
Any advice, suggestions?
ID:	2676372   Click image for larger version
ID:	2676374   Click image for larger version
ID:	2676376   Click image for larger version
Darci is offline
post #2 of 2 Old 01-27-2020, 08:45 AM
krazykanuck's Avatar
Most likely your Mag has the resolution set at 1080 in order to use HDMI. For the composite output from the Magnavox to work, you need to change the resolution on the Mag down to 480i, 480p for the component cable. You would need to change the setting every time you want to use a different output from the Mag, from where you are (HDMI) to where you want to go (composite) and vice-versa.
krazykanuck is offline
