Toshiba RD-XS32 Help Thread, Current Owners Only - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 1074 Old 01-08-2005, 10:29 AM
PerryU's Avatar
I don't know of any programmable keys on the remote; I suspect you're out of luck.
I find the remote pretty good for controlling the XS32: lots of function-specific keys in positions that seem to work well (except a couple under the door), but I don't use it at all to control my tv or cable box. My cable box remote is far more flexible; I use it for tv and stereo as well. So I'm stuck juggling 2 remotes. I might get a good programmable one day in hopes of simplifying, but as I said I'm not hopeful that it'll manage all the XS32 functions.
Cheers... Perry.
"I'm more of an idea rat..."
PerryU is offline
post #32 of 1074 Old 01-08-2005, 12:53 PM - Thread Starter
joetoronto's Avatar
i agree 100%, the remote isn't really cut out to be a smart remote.
use something else, your better off.
Just say no to cable.
joetoronto is offline
post #33 of 1074 Old 01-09-2005, 11:00 AM
Bear15's Avatar
I have a Home Theater Master MX500. Highly Recommended. Able to learn practically anything, and very flexible. But I haven't figured out yet what to label the "O" button.
I'm curious, does anyone use the DVD-RAM disks? If so, what for and how? I've recorded a number of -R, and will use the -RW quite abot to record shows and view them on other TV's. I see the flexibility of the DVD RAM's, but if I can't use them on any other players, aren't they basically just an extension of the HDD? Or am I missing something.
Bear15 is offline
post #34 of 1074 Old 01-09-2005, 11:11 AM - Thread Starter
joetoronto's Avatar
basically ya, their like a portable mini hard drive. they also hold more than other dvd's.
post #35 of 1074 Old 01-10-2005, 07:20 AM
PhinPhan's Avatar
Originally posted by Bear15
Just going off of memory...Here's what I did.
Use the edit button to go to the edit menu, then select Chapter Edit. Start your first chapter mark at the start of the program, following any intro commercials, etc. Put chapter marks at the beginning and end of each commercial segment. If you fast forward through the show, it goes pretty quickly.
If you set it up right, all of the even numbered chapters will be the show you want to keep, and the odd numbered chapters will be the commercials you want to get rid of. Then create a playlist out of all of the even numbered chapters. From the Content menu use the Quick Menu to make a high speed copy of the playlist onto the HDD. You will end up with a new original version of the show without commercials. You can then delete the original recording, which will also delete the playlist you created.
The manual says that there can only be a limited number of chapters for each title, but I've done this with 3+ hour football games and created over 50 some chapters with no problem.
Anyone have a better method? I'd love to hear it.
I just received my RD-XS32 Friday and have already created a few dvd's from movies I had saved on my Directv Tivo, this unit is great. Thanks to all of you in this thread on the other thread for helping me make my decision.
Thanks Bear15 This method is prefect for removing commercials.
Also I have seen a few posters asking about what DVD-R/RW/RAM media that is best or which to use. Since we have this thread I was thinking of creating a post with a DVD-R/RW/RAM catalog of what everyone has used and what kind of success. Thoughts on this idea? I will maintain it if everyone thinks it is a good idea.
PhinPhan is offline
post #36 of 1074 Old 01-10-2005, 10:10 AM
flipcody's Avatar
I just got a XS32 and I do not yet have a remote. I bought demo unit with no remote and will not get remote that I ordered until end of week.
Is there anyway to set up XS32 without remote? I have tried recording to HDD and it tells me that I have to put in the time (which I can't do).
I have a MX500 universal remote and tried the codes but they did not work. Any ideas? Any way to navigate setup with buttons on unit?
flipcody is offline
post #37 of 1074 Old 01-10-2005, 10:25 AM - Thread Starter
joetoronto's Avatar
can you not just hit the record button as opposed to setting up a timer recording?
post #38 of 1074 Old 01-10-2005, 11:36 AM
flipcody's Avatar
nope, if I hit record i get the time needs to be inputed question.
This is so agrivating. It has to be the first time I have bought a toy like this and I'm unable to use it. I spent hours trying to do with MX500. Oh well, I did get it cheap.
flipcody is offline
post #39 of 1074 Old 01-10-2005, 11:41 AM - Thread Starter
joetoronto's Avatar
well ya, you got it real cheap and now you just have to wait for the remote.
the waiting must be hard though, it's a wonderful machine.
post #40 of 1074 Old 01-11-2005, 09:12 AM
Bear15's Avatar
flipcody, you got a great deal on that XS32. Even if you need to buy the remote, it's worth waiting for at that price. In the meantime, spend your time reading through the manual. By the time you have all of that digested, the remote should be there. PS. My first Toshiba PS DVD was a Best Buy demo, great unit with no problems.
In regards to media: I rec'd a box of Memorex -RW as a gift. I opened two and I now have two shiny new coasters. Neither would even format. They meet the specs, they just don't work. I've been buying Fuji -R and -RW from Best Buy and haven't had a problem yet.
Bear15 is offline
post #41 of 1074 Old 01-11-2005, 05:32 PM
nascar24's Avatar
Quoted: 32 Post(s)
Liked: 30
I bought some fugi from newegg and will report back on if they work ok or not. Im hoping so, Allready wasted money on some Ridata that didnt work on either the XS32 or my PC. Only reason I went with newegg over bestbuy is the bestbuy were only 1x as the ones at newegg are 2x.
nascar24 is offline
post #42 of 1074 Old 01-11-2005, 06:16 PM
jmscott42's Avatar
Never trust Best Buy online's media speed descriptions (this goes for most online stores, such as Staples, CompUSA, etc). The SKU's for 1X media is the same as 8X media as Fuji increases the speed. If you order from BB you almost always get the fastest available (currently 8x). They don't keep stockpiles of old media around just to sell later on.
jmscott42 is offline
post #43 of 1074 Old 01-12-2005, 07:19 AM
Mr. Stinky Pants's Avatar
I finally set up my XS32 that I bought in the weeks before Christmas. Unfortunately, it turns out that I have the ZL10 firmware. No big deal, I'm still happy with it. But is there anything I should look out for? Is media compatibility the big difference between ZL10 and ZL11?
I tried playing a DVD and I do noticed that the blacks seem somewhat lighter (in the scenes at the beginning of Superman with the Phantom Zone villians and Zor-El).
I placed an old problem DVD-RAM I had and tried to format it but it wouldn't do it. I even tried to do a physical format but it didn't help. This DVD-RAM came from a PC with a Panasonic LF-D311 drive. It used to work perfectly but then I tried to copy a Hong Kong DVD to it by using NeoDVD and for some reason I can never write to it afterwards. I can't even format it on the PC. I was hoping the Toshiba XS32 could format it and fix it.
I just think it's strange that I could ruin a DVD-RAM disk by trying to copy a DVD to it. And it's even stranger that I can't fix it by reformatting it. I thought DVD-RAM was supposed to be the most robust DVD media?
Anyways, I can't wait to get home after work and play with my XS32 some more.
Mr. Stinky Pants is offline
post #44 of 1074 Old 01-12-2005, 08:16 AM
PhinPhan's Avatar
I have only used Verbatim DVD-R's (Product Number : 94495) I have probably used closed to 100 (mostly in a pc) of these and I have not had one fail, and I just ordered more. The Verbatim's also have played just fine in every DVD player I have tried to play them in.
PhinPhan is offline
post #45 of 1074 Old 01-12-2005, 09:53 AM
MASteve's Avatar
I've had mine since May '04 and still love it.
I've used a couple of different types of DVDs, with success. Presently, I'm using a Memorex 8x speed bought at BB. I've had no problems with any of the 10-12 I've used off the spindle so far.
As far as commercial editing goes, I use the playlist > DVD creation option. Works like a charm and the menus are a good enough for my uses.
Has anyone noticed any incompatibilities with playback on other dvd players? I have had one issue with Sonys, but that's it.
MASteve is offline
post #46 of 1074 Old 01-12-2005, 03:17 PM
cbearnm's Avatar
I had an older Sony that won't play ANY burned DVDs (either +/- R), newer DVD players seem to have no problems with discs from the Toshiba.
cbearnm is offline
post #47 of 1074 Old 01-12-2005, 03:35 PM
Ralph P's Avatar
Just a note: I have recorded many DVD-r's on my PC and played excellent. I also used my DVD-r=R+ with the recording recorder set to DVD-ROM and played excellent. I think the thing I noticed is that the blacks were blacker than normal and I used my TV settings to lighted the picture. I have the 11 firmware. I haven't recorded anything yet on the Toshiba. As soon as I get a chance to read all the manual I will though. I appreciate all you guys have posted here. For an Old retiree it takes a little longer to get this stuff down even though I been in this field for some odd 40 yrs.
Thanks, and keep up the excellent postings
Ralph P
Ralph P is offline
post #48 of 1074 Old 01-12-2005, 04:31 PM - Thread Starter
joetoronto's Avatar
wow, somebody older than me?
post #49 of 1074 Old 01-12-2005, 05:10 PM
nascar24's Avatar
Quoted: 32 Post(s)
Liked: 30
Well, I just received my Fuji 2x DVD-RW discs from newegg and they appear to work so I am happy now. I was hoping the Ridata 4X that I bought from amazon for cheap would work but they do not, They wont even work in my PC DVD burners, So I would stear clear of those.
nascar24 is offline
post #50 of 1074 Old 01-13-2005, 06:44 AM
MASteve's Avatar
Thanks for the reply. It seems older Sonys may be the issue. I have an older GE player that plays every one. I also gave a bunch of discs as gifts that have all worked (so far).
MASteve is offline
post #51 of 1074 Old 01-13-2005, 06:57 AM
JK27's Avatar
Interesting ... my oldest DVD player, a Sony, plays all DVD-R disks burned on my RD-XS32 without problem. It will also play DVD+R disks burned on my PC. I think this very well may be model-dependent -- as to which models will/will not play burned DVD media. I'll check my model # and post it after work.
JK27
JK27 is offline
post #52 of 1074 Old 01-13-2005, 07:31 PM
mattack's Avatar
How old of a Sony? I've got a Sony "300" (I think it may have some letters before the number, but 300 is the main component of the version #), and was just curious whether burned DVD-Rs will work on it. This was about the first relatively cheap Sony DVD player. IIRC, it was about $300 street.
Mostly I don't care if they don't, just curious. What about DVD-RWs?
mattack is offline
post #53 of 1074 Old 01-13-2005, 09:51 PM
6volt's Avatar
Quoted: 61 Post(s)
Has anyone tried this? (I would but I don't have any -RW media yet to experiment with.)
To get frame accurate editing onto a DVD would this work:
1) Edit HD using VR (frame)
2) Do a Rate Conversion Dub HD to HD at the SAME bitrate. (When a bit rate conversion is done, all chapter markers are lost.) NOTE: it is possible that merging all chapters MAY accomplish the same thing.
3) Create new VOB chapters if desired.
4) Hi Speed Dub onto DVD.
This would eliminate the possibility of bits of commerials finding their way onto the DVD when the VR chapters are converted to VOB chapters during the Hi Speed dub.
Tom
PS: How do you go straight to your Subscribed Threads? Thanks
6volt is offline
post #54 of 1074 Old 01-13-2005, 10:05 PM
6volt's Avatar
Quoted: 61 Post(s)
The PC drive is a Micro Advantage and the Media is Maxell DVD-R.
I made a DVD from a HD file that I created VR chapters. It was Hi Speed dub of a SP Mode, 4.6 Rate, D/M1.
This worked on my PC dvd drive.
Then I took a 3 hr program from the HD with VR chapters and did a rate conversion dub to the DVD where I used a Manual setting of a 3.0 rate to get the desired 3 hour capacity.
When I did the burn, I lost the chapters.
Just to make matters a bit more obscure, I dropped the DVD and it has some nicks in it. But it plays OK in the Toshiba. In the PC, it appears as an Audio-CD with no content.
I figure my problem might be:
1) I violated a "Standard" LP bit-rate.
2) Only the SP bit-rate is compatible.
3) I damaged the DVD just enough by dropping it.
Any suggestions?
Tom
6volt is offline
post #55 of 1074 Old 01-13-2005, 10:14 PM
PerryU's Avatar
You know, 6volt, that just might work... now why didn't I think of that?? I've always set chapters using GOP, then created a playlist of the chapters I want, then dubbed directly to DVD... which is why I used GOP edit to begin with.
If you copy the playlist to the HDD, that creates a new title with just the content you want, and should be frame-accurate. I think whether you remove the chapters or not is inconsequential; dub that content to DVD and you couldn't possibly pick up bits of commercials that weren't in the copy, could you? Sounds right to me.
Thanks! Perry.
PS: Click on "User CP" (Control Panel) in the top menu. There's a panel in there showing current subscribed threads, and a link to view them all.
PerryU is offline
post #56 of 1074 Old 01-14-2005, 11:31 AM
6volt's Avatar
Quoted: 61 Post(s)
Thanks Perry for the CP tip. I probalby spent 15 minutes looking for that. Frankly, they should have a little button right on a forum page, but that is a small point.
Do you have any idea about my 3hour DVD compatability problem?
I was reading carefully the manual and they talked about rate conversion dubbing for 2 reasons:
1) Compress a long program to fit on a DVD-RAM, and
2) Convert VR to burn on DVD-R/RW.
It sounds like the 3hour "thing" I burned on my DVD-R is bogus???
6volt is offline
post #57 of 1074 Old 01-14-2005, 12:29 PM
PerryU's Avatar
Don't know about your 3-hour problem. Maybe someone else here; I'm far from the most knowledgeable. Quite a DVD newb, actually. (You did finalize the disc, I'm sure...?)
Good luck... Perry.
PerryU is offline
post #58 of 1074 Old 01-14-2005, 01:12 PM
jmscott42's Avatar
6Volt, which message are you talking about? When you do a rate conversion dub, you lose your chapter points (that's a given). There's nothing 'wrong', just inconvenient.
The trick with the XS32 is to try to figure out how long the program will be before recording so you can adjust the bitrate so you don't even need to worry about a later rate conversion; granted this isn't always possible (and the XS32 does a very nice job with the conversion) but it helps prevent stupid glitches like this from having their chance to mess your video up.
Or am I missing the post about the problem?
post #59 of 1074 Old 01-14-2005, 01:19 PM
myet01's Avatar
Does anyone know if there is a DVD-R bit rate / audio rate (M1/M2) matrix out there (similar to the DVD-RAM matrix at the back of the XS-32 manual)?
Tony
myet01 is offline
post #60 of 1074 Old 01-14-2005, 02:21 PM
6volt's Avatar
Quoted: 61 Post(s)
JMScott42:
Yes, you missed my problem.
I think I understand pretty much about the bit rate conversion and the losing of chapters.
The Problem is that my 3 hr DVD that I burned using a rate of 3.0 is not recognized by my Micro Advantage PC DVD burner.
I burned a LP DVD on the Toshiba and it was recognized.
So why the problem with the 3 hr DVD? In fact, it registers as a "Audio CD" with a single file fragment when viewed with Explorer.
I was just thinking that there is no such thing as a 3 hour DVD so maybe when I created one, it is some kind of non-standard format that conventional DVD players will not recognize.
6volt is offline
