Bad Media - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 73 Old 05-26-2007, 05:04 PM
Chuck44's Avatar
Quoted: 16 Post(s)
Liked: 49
Originally Posted by wabjxo View Post
I thought TDK announced they were getting out of the blank DVD business about a year ago or so? If so, maybe they're farming out their name?
You'd be amazed at how many "major manufacturers" simply put
their name on a different company's discs.
For instance, Memorex doesn't make any of the discs they sell.
The only way to know who actually made a disc is to look at the
MID with a program such as Nero Info Tool or DVDInfo Pro, etc.
Chuck44 is offline
post #32 of 73 Old 05-26-2007, 05:20 PM
Westly-C's Avatar
Quoted: 409 Post(s)
Liked: 276
Originally Posted by slprp1 View Post
In total agreement with you but......
I'm still curious if anyone has used this particular TDK media recently?
What's your opinion(s)?
jmscott42
TDK is VERY VERY uneven quality-wise. If you get a good spindle, it's pretty good media, but if you get a bad spindle, it's utter garbage.
I don't know if there is a way to tell what is what, beyond luck of the draw. Some of it has true TDK media IDs (Which is the decent-good stuff) and some has CMC codes, which are garbage.
I just bought a TDK 50 pack spindle from CC Friday, and the very first disc turned out a coaster...though I can't be 100% sure it was the media, because I thought I'd run a quick copy disc using Sonic's My DVD. That program has given me problems before, but since I hadn't used it i so long, I forgot why I rarely use it.
The media code on these TDKs says they're RITEKF1, which are listed as 2nd class media at digitalfaq.
I've had little problems using TDKs before, so it was rather disconcerting to read this thread first, and then buy a package, only to have the first disc on top of turn out [alledgely] bad.
Dazed and confused over high tech.
Sigh...Concrap. The Internet Overlord Cometh
They're not com-tastic!
Westly-C is online now
post #33 of 73 Old 05-26-2007, 05:56 PM
Chuck44's Avatar
Quoted: 16 Post(s)
Liked: 49
Ritek media is junk, period. Even if you get a good burn
they will deteriorate and be unplayable in as little as a
few months.
Chuck44 is offline
post #34 of 73 Old 05-26-2007, 10:40 PM
kshrine's Avatar
Originally Posted by FLSTFI View Post
...I just opened my Maxell MIJ (from Sears) and out of the first 4 recordings 3 were bad...
One possibility you could never rule out is that DVD medium could be a fake. Several years ago there has been warning by the Maxell that certain DVD blanks were not genuine:
http://www.maxell.co.jp/e/release/20030704.html
If you generalize further to other brands, they also suffer from unscrupulous scums that prey on unwitting consumers. But some brands probably doesn't make any difference in quality anyways.
http://www.supermediastore.com/what-dvd-media-buy.html
TS
kshrine is offline
post #35 of 73 Old 05-26-2007, 11:02 PM
mdyoung's Avatar
few months.
How does a DVD go bad? Not like records that were worn out from the needle, nothing touches a DVD.
mdyoung is offline
post #36 of 73 Old 05-26-2007, 11:14 PM
Sean Nelson's Avatar
Quoted: 25 Post(s)
Liked: 26
Ritek media is junk, period. Even if you get a good burn they will deteriorate and be unplayable in as little as a few months.
Some is, some isn't. I have a couple hundred RITEKG05 (8X) DVDs that I burned and have been quality testing using my computer every 3 months. So far after more than 18 months there has been no sign that any of them are degrading.
However all of the 16X RITEKF01 media that I've tried have made poor burns (they play perfectly but have quite high correctable error rates) and have degraded significantly (peak error rates 2-4X what I measured after the initial burn) in as little 3 months.
Sean Nelson is offline
post #37 of 73 Old 05-26-2007, 11:18 PM
Quoted: 25 Post(s)
Liked: 26
The dye that the laser burns (in DVD-R discs) is organic and by it's very nature it will slowly degrade over time. In theory it should take decades, but it seems that some dye formulations are a lot less stable than that.
It's also possible for moisture to penetrate the disk and corrode the reflective metallic layer beneath the dye - if that happens then the laser may not reflect back with enough intensity to read the data bits.
These effects are apparently hastened if the disk is stored at high temperatures, under high illumination (sunlight, as an extreme example) or in a high humidty environment.
post #38 of 73 Old 05-27-2007, 02:31 AM
FullOnShred's Avatar
RITEKF01 Media is hands down the worst I have ever used. I even prefer the el cheapo el crapo Playos to RITEKF01. Ritek should be permanently banned from producing any media of any type. They stink like a Monkey's Foot. All to be darned!
FullOnShred is offline
post #39 of 73 Old 05-27-2007, 05:09 AM
Chuck44's Avatar
Quoted: 16 Post(s)
Liked: 49
Originally Posted by Sean Nelson View Post
Some is, some isn't. I have a couple hundred RITEKG05 (8X) DVDs that I burned and have been quality testing using my computer every 3 months. So far after more than 18 months there has been no sign that any of them are degrading....
You must be one of the few lucky ones, as the G05's are the most
likely to suffer premature failure of the dye.
I'd seriously start thinking about transferring anything of importance
to other media while they are still readable.
Chuck44 is offline
post #40 of 73 Old 05-27-2007, 09:23 AM
Westly-C's Avatar
Quoted: 409 Post(s)
Liked: 276
Terrific..Conspiracy theory ahead...Is it any wonder that they were on sell for $10.99 when their regular price is $39.99? Trying to get rid of them....
post #41 of 73 Old 05-27-2007, 08:00 PM
videonut's Avatar
Quoted: 12 Post(s)
Sean is right on the money; type of burner, recording speed, DVD brand and firmware all play a vital part in creating a DVD. I have been experimenting over the last several months and made some startling discoveries:
I am noticing a steady failure rate with my 2-3 year old Ritek GO5s, but I never really tested the quality of their burns two years ago, so they may have been border line to start with.
My latest Samsung burner (38.00 NewEgg) and Taiyo Yuden WS 16X DVD-R creates better burns than my Plextor 716A (120.00) with the same discs. The Samsung averages a score of 93 with Nero's CD/DVD Speed, while the Plextor averages 70.
My biggest discovery is that I get the best burns using Verbatim (p/n:95052) DVD+R discs with the Samsung. I average a score of 98 with Nero and there are way less PI errors. This has proven consistent for close to 200 burns.
I also should mention that I have many Panasonic RAM discs that are now approaching eight years old, and NONE have gone bad.
I also have many twenty something year old VHS tapes that still play great. This is why I would never toss out any tapes containing important home movies.
videonut is offline
post #42 of 73 Old 05-27-2007, 09:34 PM
Quoted: 25 Post(s)
Liked: 26
Like DVD-RW and DVD+RW, DVD-RAM uses a phase change metal alloy recording layer instead of organic dyes. This strikes me as being less likely to degrade over time, but most references I've seen claim a longer life for DVD-R than for DVD-RW. I'd really like to understand if this is because DVD-RW life expectancy is based on the assumption that it will be repeatedly re-written. I can certainly appreciate that DVD-RW has a limited number of rewrite cycles, but I wonder if it's written to just once whether it would last longer than DVD-Rs.
Have you been re-writing your DVD-RAM discs over the past 8 years, or just re-reading the same data?
I recently converted several dozen CD audio tapes to MP3 and was having to continually clean the heads because of oxide shedding. I'm not sure if VHS tapes are as vulnerable to this, but it's something I'd be concerned about if I still had unconverted VHS tapes.
post #43 of 73 Old 05-28-2007, 10:43 AM
videonut's Avatar
Quoted: 12 Post(s)
Hello, Sean,
Most of my RAM discs were burned once for archival storage. But I should note that the dozen or so RAM discs that I've used over the years for bringing programs from the Tivo to the PC are all still working properly. I did have a few failures with RW discs that I use for the same purpose.
I did convert my tape library to DVD media, but I still feel a need to hold on to some originals (mostly home movies). I also notice that Video tape does not shed as much as audio tape. The only video tape I'd had problems with (sticking) are some of the older open-reel tapes from the early seventies.
videonut is offline
post #44 of 73 Old 05-30-2007, 02:12 PM - Thread Starter
FLSTFI's Avatar
Okay, I have been testing my dubs with the scan disc on CD Speed.
Out of 10 this week I think 7 were all green, 2 had 3 yellow dots and 1 had about 5 yellow and 1 RED.
I think they all still said 100%.
At what point do you decide that's too many bad spots and try another disc?
I checked one of the recordings I made on a Maxell MIT a month ago and it had a row of red spots and then got stuck, couldn't go any further.
I don't think I need to ask about that one
FLSTFI is offline
post #45 of 73 Old 05-30-2007, 03:39 PM
Quoted: 25 Post(s)
Liked: 26
I'm not too familiar with the software you're using, so I don't know exactly what criteria it uses to decide between green, yellow and red. I suspect that I'd probably reburn anything that wasn't completely green.
I go on the PI (Parity Inner) error rates. When I'm burning a new disc I throw it out if it averages more than 40 PI errors per megabyte over the whole disc, or if it has any single spikes above 100 PI errors. That's pretty conservative, the DVD standard allows up to 280 errors, and discs can be much worse than that and still play perfectly. But with good media I can go through an entire spindle and not have even a single disk that fails to meet my criteria.
post #46 of 73 Old 05-30-2007, 03:51 PM
Chuck44's Avatar
Quoted: 16 Post(s)
Liked: 49
I agree, except PIF's are much more important than PIE's.
Chuck44 is offline
post #47 of 73 Old 05-30-2007, 07:35 PM - Thread Starter
FLSTFI's Avatar
Quote
I am trying to use the scan disc test on Nero CD/DVD Speed.
I have tried DVDinfopro, DVDidentifier, and a few others, but that seems to be the only test I have found that my crappy drive will "support".
Does anybody know that test? Am I wasting my time?
FLSTFI is offline
post #48 of 73 Old 05-30-2007, 08:59 PM
FLSTFI, are you using "ScanDisc", or "Disc Quality Scan" on the Nero CD/DVD Speed Program? I use the "Disc Quality Scan". It even grades the DVD on a "Quality Score" of 100 or less, with 100 being perfect.
Sean, you are one strict grader. Few of the discs burned from my Sylvania would pass your test standards.
post #49 of 73 Old 05-30-2007, 09:13 PM
I use K-Probe (free download) more often as it is less buggy with my Lite-On External DVD Burner. I think K-Probe may only work with Lite-On, and maybe those Sony DVD drives which are made by Lite-On anyway.
post #50 of 73 Old 05-30-2007, 09:33 PM
Westly-C's Avatar
Quoted: 409 Post(s)
Liked: 276
I'm going to have to be more careful when I see even brand name discs on sale. Turns out the 50 pk TDK discs that were on sale at CC last week aren't all 16x. The spindle is a mix of 4x, 8x, and 16x. It even has 1-16x on each disc, as well as the label.
Only the disc at the top on the stack turned out to be a coaster. And CD Speed tests are coming up all green during Scan Disc.
post #51 of 73 Old 05-30-2007, 09:39 PM
jmscott42's Avatar
It's probably not that it's a mix of speeds, it's that the media (more than likely CMC) is so horribly inconsistent that your burner is having trouble at ANY speed and keeps going all over the place.
Definitely should be returned if possible. And sad, since genuine TDK used to be really really good stuff.
jmscott42 is offline
post #52 of 73 Old 05-30-2007, 09:46 PM
Westly-C's Avatar
Quoted: 409 Post(s)
Liked: 276
^^All the discs have the RitekF1 id code, and both DVD Identifier and CD Speed will show a single speed. Since I'm only out 11 bucks, I won't try haggling for a refund, but I wish I'd picked up the dvd+r pack instead.
post #53 of 73 Old 05-30-2007, 10:44 PM
Here is a K-Probe Scan readout of a Sony 8x DVD-R (Sony08D1 ID Code) that is a copy of a DVD made on my Sylvania HDVR200F. This is for FLSTFI to see what he can expect from K-Probe if he can use it. It also gives a nice graph readout of the errors which I have omitted here.
Date : 5/30/2007 11:25:36 PM
Model : 2-0-0-0 H:LITE-ON DVDRW SHM-165P6S MS0P
Disc : DVD-R , SONY08D1 [Sony Corporation]
Speed : 4x
ECC blocks sum (PI/PIF) : 8/1
Scanned range : 0 - 1793910
Sampling count : 44178
Errors : 0
PI Max : 117
PI Average : 44.84
PI Total : 512603
PIF Max : 2
PIF Average : 0.04
PIF Total : 446
The Sylvania seems to like Verbatim 16x DVD-R MCC03RG20 media the best. And they are the PAP6 of which some folks get bad batches.
post #54 of 73 Old 05-31-2007, 12:30 AM
Quoted: 25 Post(s)
Liked: 26
Here is a K-Probe Scan readout...
Boy, I sure wouldn't be happy with 446 PI Failures...
post #55 of 73 Old 05-31-2007, 09:42 AM
sgm26's Avatar
Has anyone checked the DVD-RAM with one of the computer programs mentioned? I have two recorders but none in my PC. I seem to have better experience with RAM than -RW. The Maxel -RW I have began to go bad after about a year.
sgm26 is offline
post #56 of 73 Old 05-31-2007, 12:33 PM
This is from SuperMediaStore's Website.
Explanation of PI Errors/PI Failures:
* PI(Parity Inner) Error: No larger areas on the disc should exceed
280 PI Errors, do not worry too much about high single spikes that
exceed 280.
* PIF(Parity Inner Failures): No large areas on the disc should
exceed 32 PI Failures, do not worry too much about high single
spikes that exceed 32.
* And as always; lower is better
post #57 of 73 Old 05-31-2007, 01:40 PM
jmscott42's Avatar
Unfortunately, DVD-RAM can't be checked the same way, and even if it could, no one knows what 'valid' results would look like.
Kind of a strange situation since DVD-RAM hypes itself on being more reliable (which most anecdotal stories support) but there's no way to verify that with solid numbers.
post #58 of 73 Old 05-31-2007, 01:42 PM
jmscott42's Avatar
exceed 280.
You need to check how your drive is scanning-- PIF can be scanned as 1/ECC or 8/ECC (I might be wrong on the terminology, someone please correct me). Depending on the setting your max PIF may be 4. (I think 1/ECC would be 4, 8/ECC would be 32, since you're talking 1 block vs. 8 blocks being scanned.. so for a 32 max averaged over 8 block, it'd be 4).
I'd be horrified to see a spike of 32 on my PIF scans. (at 1/ECC)
post #59 of 73 Old 05-31-2007, 02:30 PM
Chuck44's Avatar
Quoted: 16 Post(s)
Liked: 49
Nero DVD/CD Scan usually knows depending on the drive
being used.
LiteOn drives scan at 1 while BenQ's use 8.
Also, LiteOn's should scan at 4x while BenQ's
scan at 8x and NEC's at 5x...
Chuck44 is offline
post #60 of 73 Old 05-31-2007, 04:22 PM
The scan I posted had a Max PIF of 2, but a total of 446 for the whole disc. The 446 is what was blowing Sean's mind. Sean how many PIF TOTAL do you have on an average burn?
The default on K-Probe for PI is 8/ECC Block and for PIF it is 1/ECC Block. I scan at 4x read speed most of the time. I use a Lite-On SHM165P6SX (external) DVD Writer because my older NEC won't do quality scans. I get much better scans from TY + and - 8x and Verbatim - 16x than I do from the SONY08D1. I still don't mind using the SONY MIJ if the Price is right.
