Can someone build me a atmos system - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 08-27-2017, 01:05 PM - Thread Starter
tacos's Avatar
Quoted: 22 Post(s)
for under $1000? looking for a 5:2 setup. Could go slightly over 1k if needed. thanks
tacos is offline
post #2 of 9 Old 08-27-2017, 01:25 PM
gajCA's Avatar
Quoted: 7975 Post(s)
Liked: 5293
I assume you have a receiver and a subwoofer?
Use the promo code SOUND10 to get 10 percent off.
Three pairs of these:
https://www.qacoustics.com/bookshelf...aker-pair.html
https://www.qacoustics.com/home-thea...l-speaker.html
That's $945 after discount.
http://thewirecutter.com/reviews/bes...helf-speakers/
If you need wall brackets:
https://www.qacoustics.com/speaker-s...t-bracket.html
For less money, in case you don't have a sub and that needs to be part of the budget:
Three pairs of these along with the center above will come to
Wall brackets:
If you don't have a sub.
https://www.amazon.com/JBL-Studio-55.../dp/B0071UQ8FS
Or these:
150watts 28hz $199 EMOTIVA BASX S8
200watts 27hz $299 EMOTIVA BASX S10
Geoff A. J., California
gajCA is offline
post #3 of 9 Old 08-27-2017, 01:40 PM - Thread Starter
tacos's Avatar
Quoted: 22 Post(s)
Wall brackets:
Or these:
Thank you. Unfortunately i dont have a receiver yet lol.
tacos is offline
post #4 of 9 Old 08-27-2017, 01:56 PM
gajCA's Avatar
Liked: 5293
No worries.
Here's your receiver, $250. Factory refurb are just fine (usually like new), and A4L has great customer service.
http://www.accessories4less.com/make...eceiver/1.html
We'll make a small adjustment to the speaker choice to get you close to $1000 with a sub.
Two pairs of these; one pair for the rear and one pair for Atmos.
One pair of these for your front Left and Right:
Here's your sub:
That is $1028.50 before wall brackets and cables.
Buy your cables at Monoprice.
If you want to save money on the sub, here's one for $100 cheaper; I have two in my secondary room and they are great little subs that punch down to 28hz.
http://www.accessories4less.com/make...er-port/1.html
Use the SOUND10 discount at Q Acoustics and if you buy the cheaper sub I listed you will have a 5.1.2 setup, including receiver that will kick the ass of any $1000 Home Theater in a box setup you can buy guaranteed for a grand total of $922.50.
I sure hope you live in the US because if you don't no way could you put that together overseas for less than $2000.
gajCA is offline
post #5 of 9 Old 08-27-2017, 02:14 PM - Thread Starter
tacos's Avatar
Quoted: 22 Post(s)
No worries.
Here's your sub:
Hey thank you very much!
tacos is offline
post #6 of 9 Old 08-28-2017, 07:58 AM
gajCA's Avatar
Liked: 5293
No problem.
Doh, I see your location is "BAMA" so definitely in the States.
I've been at this stuff since the seventies and these days the internet direct phenomenon offers tremendous values if you know what to look for.
I had Q Acoustics Concept 20s in my home on loan from them as they were new to the market and wanted some of us to test their products as they were getting short shrift on AVS because the only reviews were ALL rave reviews but from "foreigners."
The are a UK brand.
Well the then $430 pair of speakers were every bit as good as the $798/pair of Martin Logans I tested them against and the $1400 B&Ws I tested them against.
You will be blown away.
That JBL sub sells for $550 on the JBL site so act fast on the Amazon offer.
gajCA is offline
post #7 of 9 Old 08-28-2017, 09:01 AM
gajCA's Avatar
Liked: 5293
Just got a notification; 20 percent off today at Monoprice.
https://www.monoprice.com/?cl=res&ut...70828_sitewide
HDMI cables; no need to get anything more than the cheapest ones, just select the lengths.
These carry audio AND video from your cable box, BluRay player or Playstation to the receiver and one HDMI cable then goes from the receiver to the TV, so you might need several at differing lengths.
https://www.monoprice.com/search/ind...ord=hdmi+cable
Speaker cable; no need to get anything more than the third one down, select 14 gauge.
Buy enough so that it will handle all 5 speakers; 50 feet might be enough, if not, 100 feet. Cut to length and then use a wire stripper that you can get at Home Depot to expose the bare ends which attach to the speakers from the receiver.
https://www.monoprice.com/search/ind...=speaker+cable
RCA cable, a single one is needed to connect the sub to the receiver.
https://www.monoprice.com/product?p_id=2743
gajCA is offline
post #8 of 9 Old 09-14-2017, 12:28 PM - Thread Starter
tacos's Avatar
Quoted: 22 Post(s)
About to finally pull the trigger on the JBL sub. Just wondering if you knew a reason for it being so much cheaper than other places? Seems to good to be true. Thanks
tacos is offline
post #9 of 9 Old 09-21-2017, 11:58 AM
gajCA's Avatar
Liked: 5293
I believe because unlike the picture on Amazon it does not come with speaker level inputs.
Clearly they are discontinuing it as well.
gajCA is offline
Reply Home Theater In A Box
