Yahama HTR-2067 + Technical Pro WM 201 (Wireless Mic) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 09-01-2017, 08:40 AM - Thread Starter
Kev84's Avatar
Hi All,
I recently bought an entry level Home Theater system. My wife wants to be able to sing Karaoke, so we bought a cheap Technical Pro WM201 to try.
So I'm running into connection issue, cause there is no 6.5mm (1/4 in) connection to my htr 2067.
My question is, do i need an additional AMP to amp up the voice from mic to receiver. Mic --> Amp --> Receiver?
Or can i direction just try to find an 1/4in female --> RCA adapter. Mic --> Adapter -> Receiver?
I am new into home theater, when i got the receiver, it says its also have amp capabilities (hence i wonder if i can just use an adapter). So is the "Amp" function in my entry level receiver sufficient or do i really need an additional amp.
Thanks for your help guys,
Kev
Kev84 is offline
post #2 of 3 Old 09-02-2017, 05:39 AM
Wayne A. Pflughaupt's Avatar
Quoted: 410 Post(s)
Liked: 333
The 1/4” female -> RCA adapter is all you need. Use either the Audio 4 or Audio 5 inputs on the Yamaha.
Wayne A. Pflughaupt
Equipment List
"A nice mid-fi system," according to an audiophile acquaintance.
Reviews and Tech Articles
Wayne A. Pflughaupt is online now
post #3 of 3 Old 09-06-2017, 07:59 PM - Thread Starter
Kev84's Avatar
Wayne A. Pflughaupt
Thanks Wayne, I found a 3.5mm female --> 1/4" male adapter. However, when i tried to use Audio 4/5, i can't hear anything coming out from my mic.
Do i have to do any setup/configuration to get the amp kick in? It maybe that i got a lemon microphone, is there anyway to test?
Kevin
Kev84 is offline
Reply Home Theater In A Box
