Possible CEC incompatibility. Disable just the CEC portion on the OLED and the receiver and see if that corrects the issue. You may lose ARC on the receiver if it is associated with CEC, which is still common. If you don't need ARC, then disable ARC/CEC on both devices and either use a Harmony remote to control everything or use the two remotes control your tv and the Onkyo. If you can disable just the CEC protocols of the OLED and the Onkyo then you can still use the Harmony remote and maintain ARC functionality.
I just did that and then i the volume adjustment did work, but when i enabled arc on the tv the receive just kept turning off and on and the tv had disabled arc and re enabled cec
I do need arc cause i use the smart tv netflix for atmos
Is this TV defective?
I am also having another issue, dolby vision is not selectable on my xbox when i go through receiver, if i go direct to tv it is selectable and enabled but then i cant use my speaker system
I just disabled cec on both tv and receiver and then enabled them, now the receiver is not frozen but the smart tv netflix app wont recognize atmos on atmos films while arc is enabled, not only that but there is no sound only video
If i disable arc the tv recognizes atmos on netflix with its built in speakers and there is both video and sound
Hey did you manage to sort this out as I am having the same issues?
I've just got an LG c8 and the simplink freezes my onkyo TX sr444 receiver unless I disable ARC on the receiver but then lose atmos.
When frozen it requires the plug pulling from the wall as the remote or even the buttons on the amp itself dont work. The remote light flashes to recognize the command but does nothing.
Any help would be greatly appreciated as its doing my head in.
CEC causes all kinds of problems, especially if it is associated with ARC (same chipset). If all of your HDMI connected devices do not offer the capability of separate ARC and CEC (LG Simplink) controls then you are stuck. There is an adapter (Lindy CECless I think) that can disable CEC control and still retain ARC functionality. That has worked for some, but not all. CEC protocols are not standardized so it could be the C8 implementation of those protocols or the Onkyo. There are no firmware updates that can correct it.
Related Threads
AVS Forum
34M posts
1.5M members
Since 1999
