Wireless surround sound system for TV - AVS Forum | Home Theater Discussions And Reviews
post #1 of 23 Old 10-23-2019, 07:09 PM - Thread Starter
Liked: 0
Hi there:
This is my first post in this forum so hello everyone!
I am in the market for a (Q) LED TV - 65 inches and wanted to supplement with a surround sound system that is wireless. Most of the ones that I could find were wireless from receiver to speakers but the speakers were wired for power. I know SONOS is wireless too but unsure if its speakers have to be wired for power.
Can anyone recommend a true wireless surround sound system that is powered by battery pack or something similar? Or the only thing in the market today are the above options OR the only other option is a wireless sound bar?
Thanks in advance.
Neil Mazumder is offline
post #2 of 23 Old 10-23-2019, 08:30 PM
Otto Pylot's Avatar
Quoted: 3874 Post(s)
Liked: 2766
Originally Posted by Neil Mazumder View Post
Hi there:
Thanks in advance.
Wireless surround can be a snake pit. Not only the technology but the connections. You are correct in that most of them are wireless to the main unit but the sides need to have power and are wired to each other. A battery pack option would be flaky at best.
There are some decent soundbars that will give you much better sound than the tv's speakers, and that my be your only viable option, other than a true 5.1 system (separates).
I never trust an atom, they make up everything.
Otto Pylot is offline
post #3 of 23 Old 10-25-2019, 02:58 AM
Wayne A. Pflughaupt's Avatar
Quoted: 494 Post(s)
Liked: 419
There is no such thing as a wireless surround sound system as you are describing. However, you can easily get stereo sound. Since there seems to be no concern about them going dead in the middle of your program, Bluetooth speakers are the only ones I know of that have batteries. All you would need is a Bluetooth transmitter that would connect to the TV’s audio outputs. Bluetooth can be blinky, but the Avantree Oasis appears to be one of the better transmitters. Just make sure the TV you buy has the audio outputs that your Bluetooth transmitter requires.
Wayne A. Pflughaupt
Equipment List
"A nice mid-fi system," according to an audiophile acquaintance.
Reviews and Tech Articles
Wayne A. Pflughaupt is offline
post #4 of 23 Old 10-25-2019, 06:15 PM - Thread Starter
Liked: 0
Thanks so much!
If I want to go with a modular setup where I get lets say an Onkyo receiver and couple side speakers and possibly a sound bar as well as couple in wall speakers away from the TV and on the back and side - can I do that ?
I guess get the Onkyo receiver as a one off and then get the 5.1 that includes the in wall? Is that doable? what brand(s) would you recommend?
post #5 of 23 Old 10-26-2019, 10:25 AM
Otto Pylot's Avatar
Liked: 2766
Thanks so much!
Ideally you don't want to use a soundbar or a wireless setup but to go with separates (speakers and receiver). Wall mounting your front sound stage speakers would work but you're best off not to. Can you fit RF/RL speakers on stands to the side of the tv and possibly mount a center above or below your tv? Might be helpful to us if you explained your setup (wall mounted tv, on a console, etc).
post #6 of 23 Old 10-27-2019, 10:12 AM - Thread Starter
Liked: 0
The TV is wall mounted about 6 feet (measured to the center of the TV) from the floor. Yes, R/L will work as well as the center that would take care of the front sound - but I was looking to supplement with the back sound - like have in wall for the back? So basically a 5.1 set up with woofer. This is for a family room approx. 14 X 20 FT that backs up to a dining area that is almost the same dimensions with regular 9 ft ceiling - so the reason why I thought of a sound bar was a suggestion that for the size of the the area a sound bar may suffice but I am unsure...
post #7 of 23 Old 10-27-2019, 12:23 PM
Otto Pylot's Avatar
Liked: 2766
Is there a reason why you can't put the side channels on stands to either side of the listening area (I'm assuming a couch). I have two HTS's. A smaller system downstairs for day-to-day use and a bigger one upstairs for 4k HDR viewing. Both are 5.1 with the side channels on stands at either end of the couch. The downside of wall installed side or back channels is that some of the sound is "encased" in the wall so you might not get the full benefit of atmospheric sound which is what the side channels (typical 5.1) and the back channels (typical 7.1) offer.
post #8 of 23 Old 10-28-2019, 10:26 AM - Thread Starter
Liked: 0
My couch is actually on the side not in front due to the layout of my room - rough layout attached. Also, sorry I am new to this what is an HTS?-
I have two HTS's
post #9 of 23 Old 10-28-2019, 10:35 AM
Otto Pylot's Avatar
Liked: 2766
HTS = Home Theater System. So you won't be facing the panel directly but viewing it from the side? If that's the case then that makes surround sound difficult. You could always "separate" the room by moving the couch in front of the tv, with the chairs (I'm assuming the squares are chairs) on the side where the couch is.
post #10 of 23 Old 10-28-2019, 05:44 PM
Quoted: 494 Post(s)
Liked: 419
What Otto said. You can’t do surround sound with the room set up like that. People will only hear the speakers closest to them. If you aren’t willing to re-arrange the room, just get a sound bar and be done with it.
Wayne A. Pflughaupt
Equipment List
post #11 of 23 Old 11-06-2019, 08:24 AM - Thread Starter
Liked: 0
Ok - thank you for your help. I will go for the sound bar and perhaps R/LHS speakers.
post #12 of 23 Old 11-06-2019, 08:57 AM
Otto Pylot's Avatar
Liked: 2766
That may work, sort of, but you're still going to lose proper audio fidelity due to the side viewing of the tv. If it were me, I wouldn't bother with side speakers and just stick with a soundbar if you're not willing to move the couch to sit directly in front of your tv or place the tv on the opposite wall.
post #13 of 23 Old 11-06-2019, 09:17 AM
Ricoflashback's Avatar
Quoted: 1920 Post(s)
Liked: 1362
***I'm a little confused with your room setup. If I look at it correctly - the couch (main seating area) is facing "East" while your TV is due North. That means that unless your are lying down (at which you'd still be off angle to the left) you are cranking your head 90 degrees to the left to see the TV. Is this correct? Is the main use of this TV for your dining room area (TV while eating?) I'm not sure I'd even invest in a soundbar (cheapo at most) with this setup. Not trying to be negative but I don't understand how you make this room work at all unless you find another alternate TV location.
Home Theater Setup
SONY 75X900F & 49X900E, BenQ W1080ST, Denon X5200 & Emotiva XPA-3
AudioSource 100VS, OPPO 103 & Samsung K8500, 9.1.4 Setup - Speakers - Studio 60's,
V.2 (FL/FR), CC-690 (C), V.5, ADP 590 V.5 (SS), MilleniaOne 2.0 (BS) - Velodyne 810 Sub,
Cornered Audio (FH/RH), Definitive Technology (Front Wides)
Ricoflashback is offline
post #14 of 23 Old 11-06-2019, 10:07 AM
Otto Pylot's Avatar
Liked: 2766
That's how we interrupted the OP's setup as well. Either he moves the couch to the middle of the room, places it on the wall opposite the couch's present position, or just leave it alone and purchase a garden-variety soundbar or use the tv's speakers. IMO, it's a waste of money to put speakers on either end of the couch.
post #15 of 23 Old 11-17-2019, 05:05 PM - Thread Starter
Liked: 0
I can't put the couch directly in front of the TV as it will block the entrance to the family room area and will look weird - LOL lets not get into interior design. But I get your point - I am leaning towards just getting a Samsung sound bar and perhaps L and R. The only option I can have my couch directly in front of the TV is to mount over the fireplace which is to the right of the graphic I had sent but that would entail dry wall work to fill the current hole for wiring plus other implications/complications or so I have heard associated with mounting TVs over a fireplace(??).
post #16 of 23 Old 11-17-2019, 05:50 PM
Otto Pylot's Avatar
Liked: 2766
If you get a soundbar then you don't need L/R speakers, besides you don't have anywhere to put them that's going to afford you the benefit of separate speakers. Just get a soundbar that has a wireless sub (LG makes a nice one) and be done with it. Mounting a tv over a fireplace is purely a personal decision. There are drawbacks so you really need to think it through before you commit.
post #17 of 23 Old 12-10-2019, 05:08 PM - Thread Starter
Liked: 0
Closing Out - Thanks everyone
I ended up getting this -
https://www.bestbuy.com/site/samsung...?skuId=6327856
Thank you all for all the help. You guys rock!
post #18 of 23 Old 12-12-2019, 07:41 AM
Quoted: 439 Post(s)
Liked: 326
its good that the OP found a solution that will hopefully work for him. For anyone looking for a wireless solution keep in mind that "wireless" speakers in this situation will most likely still need a power cord fo some of the speakers. There are new solutions out there for those that don't want to or can't go with a traditional AVR and wired satellites.
If you have a Yamaha receiver you can always use Yamaha Multicast wireless surrounds.
Here are some promising solutions from Klipsch:
https://www.klipsch.com/reference-wireless
https://www.klipsch.com/products/ref...model=rp-140wm
Rgarc is offline
post #19 of 23 Old 01-30-2020, 09:48 AM
Audio Pack Rat
sealmaniac's Avatar
Quoted: 86 Post(s)
Liked: 136
Originally Posted by ingridstephenson View Post
The "soundbar is good enough" crowd must also have 1080p TV's, think MP3's are how music sounds, and think McDonalds actually qualifies as food.
The view must be grand from that ivory tower.
Spoiler!
sealmaniac is online now
post #20 of 23 Old 01-30-2020, 02:39 PM
Quoted: 494 Post(s)
Liked: 419
Only certain Yamaha receivers can use MusicCast speakers as surrounds.
Klipsch’s speakers are WiSA. WiSA is a stand-alone ecosystem and won’t work with regular receivers without a WiSA hub, which will set you back about $1,000.
Wayne A. Pflughaupt
Equipment List
post #21 of 23 Old 01-30-2020, 03:37 PM
Quoted: 439 Post(s)
Liked: 326
Wayne A. Pflughaupt
I'm not a Klipsch person but it's nice to see that more options are becoming available to accommodate different needs or wants. My understanding was that the Klipsch hub would replace the AVR in this setup. Thank you for clarifying.
Do you think that WiSA compatible AVR's may be available in the future or is this going to stay a closed ecosystem?
Rgarc is offline
post #22 of 23 Old 01-30-2020, 04:16 PM
Quoted: 494 Post(s)
Liked: 419
That’s a good question. WiSA’s been around for nearly 8 years, and so far none of the major AVR manufacturers have signed on. Possibly because of the expense. So that doesn’t bode well for WiSA, IMO.
Oh, that WiSA hub I mentioned in my last post is the Axiim. I just checked and it has no analog inputs. So it couldn’t even be used for adding wireless surround speakers to a traditional system. Klipsch briefly made a WiSA hub that had analog inputs and costs far less than the Axiim, but it proved to be unreliable so they ditched it.
Here’s an article I put together on wireless rear surround speakers a couple of years ago. Towards the bottom is a discussion on the benefits and shortcomings of WiSA.
https://www.avnirvana.com/threads/wi...s-a-mess.2057/
Wayne A. Pflughaupt
Equipment List
post #23 of 23 Old 02-02-2020, 04:24 PM
Liked: 0
Stunning. Dare to dream if you can.
ingridstephenson is offline
Reply Home Theater In A Box
