Looking for some small speakers like the Bose Cubes to mount on the ceiling. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 12-06-2019, 04:06 PM - Thread Starter
Quoted: 24 Post(s)
Liked: 0
I'm looking to have 5 speakers all ceiling mounted, and able to point down at like a 45 degree angle in my parent's house.
I'm willing to spend up to $3k.
- Andy
hrmHomeTheater is offline
post #2 of 3 Old 12-09-2019, 11:19 AM
Quoted: 432 Post(s)
Liked: 311
If by Bose-like you mean small form factor its hard to beat Bose because small form factor is Bose's biggest strength. Here are a few options that could work in your case but I think that in most of these cases you would be looking at larger speakers and subs to get better performance.
I've heard these and they sound really good for the size but a little on the expensive side.
https://www.bowerswilkins.com/mini-theater/mt-60d
The also have this package with a lower tier sub.
https://www.bowerswilkins.com/mini-theater/mt-50
my personal favorites for this application. If you can place the center under the TV I would upgrade the Center to a CG23
https://rslspeakers.com/products/cg3...ecial-edition/
SVS also makes these you can pair with one of their subwoofers. These allow for versatile placement options.
https://www.svsound.com/products/prime-elevation
You can mix and match as well. If you go the Bowers & Wilkins route I would still use the RSL or an SVS subwoofer do to a better cost-to-performance ratio.
Bowers & Wilkins and SVS can be found at Best Buy, and SVS and RSL are direct vendors.
Rgarc is offline
post #3 of 3 Old 12-24-2019, 05:35 PM
RayGuy's Avatar
Quoted: 3111 Post(s)
Liked: 2899
The usual substitute for Bose is Cambridge Audio Minx Min 12 or 22. Alternatively, the Gallo A'diva (among others) is quite small and has many finishes to choose from. If saving money is your thing, then look at the Boston Acoustics Soundware (on close-out at accessories4less.com).
It's a VIRTUAL channel unless stated otherwise.
RayGuy is online now
Reply Home Theater In A Box
