Does this receiver have any use at this point? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 01-01-2020, 01:42 AM - Thread Starter
Liked: 0
The other day as I was rummaging throughout my family's garage I came across a 5.1 surround system.
After further inspection and some research, I now know that is the Panasonic SC-HT744 DVD Player and receiver from the early 2000s. I understand that it pretty outdated now, but it would still be much more surround sound than I currently have.
Now onto the big problem. It only seems to have one audio input, L and R aux. Because I'm not very familiar with audio I'm not sure what it is, but more importantly whether it can carry 5.1 signals.
Should I leave it in the garage or is there a way for me to use it as a 5.1 audio output. Any help is appreciated.
Extra question : Since it is also a DVD player would I be able to burn 5.1 surround sound discs and play them? As it does have hdmi output.
Name:	Screenshot_20200101-051202_Adobe Acrobat_1577868137187.jpg
Vortexzio is offline
post #2 of 3 Old 01-01-2020, 01:50 AM
rontalley's Avatar
Quoted: 827 Post(s)
Liked: 422
It has stereo input which more than likely is up-mixed to 5.1 using Dolby Logic.
It will play a 5.1 mix DVD and more than likely output it through the HDMI cable and/or the 5.1 speakers.
I still have a couple of these HTIB for quick and easy surround sound setups in a couple of bedrooms.
My Media Room
AVR 1-Yamaha RX-A3050 (7.2.4), AVR 2 Pioneer VSX-815-K(Used for 4ch Amp TF+TR)
Mains-Polk Audio RTi8, Center-Polk Audio CSi5, Surrounds-Polk Audio RTi4, Ceilings-Micca M-8C, Sub 1- UM18-22 (4cu.ft DIY) - iNuke 6000DSP, Sub 2-Klipsch RW12D
Projector-BenQ 3550 4K, Screen-110" Silver Ticket STR-169110, TV-Vizio P-65 4K
rontalley is offline
post #3 of 3 Old 01-01-2020, 01:55 AM - Thread Starter
Liked: 0
Thanks for the quick response, I'm new to the website and was expecting to wait a lot longer. I've decided that I'm going to try the speakers in the coming days and hopefully they won't disappoint. Happy New Year's
Reply Home Theater In A Box
