Help - No sound - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 03-15-2020, 08:36 PM - Thread Starter
Liked: 0
Help - No sound
I have a Sony BDV-E870 5.1 system, it's been great over the years, the was not used regularly for about a year (only to watch dvd or Blu-ray movies). I recently was using it everyday as my tv output, one day it stopped outputting sound. I found that there is only no sound when trying to input a signal (RCA/HDMI/ARC/Optical) but it works perfectly fine when you pop in a dvd.... I found this very strange, i even called Sony and they told me that I would have to get it serviced. There has to be another solution, would there be somthing I should clean? Or somthing internal I can replace myself? Any advice helps! Thanks
Jhall878 is offline
post #2 of 2 Old 03-16-2020, 04:01 AM
bac522's Avatar
Quoted: 259 Post(s)
Liked: 141
Service or scrap, sounds like the input controller logic is having an issue. Local electronic shop could probably fix it for you, but not sure it's worth the cost. Used one's on Ebay seem to be around $100 when you including shipping.
bac522 is offline
Reply Home Theater In A Box
