Sony 6.2 Home theatre, have tried everything... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 04-07-2020, 08:48 AM - Thread Starter
Liked: 0
Exclamation Sony 6.2 Home theatre, have tried everything...
Hi Guys and Girls
I am new to this forum, in fact it will be the first forum I ever use.
If you could please assist.
I own a Sony home theatre system Model HT-DDW1600
Amp: STR-K1600
Speakers, probably irrelevant at this point but: 2 x standard front tall boys, 1x standard centre, 3 x standard surround (L,C,R), 4 x standard subs (came with 2, i got another 2) essentially now 6.4
My problem, i have used this system for 12 years, running on video 2/BD input with AFD set to DD PL IIX. When running it this way it would output DolbyD 3/2.1 which from I understand is 5.1
Sooo recently I must have done something, and the Video 2 Channel shows simply "Video 2/BD", and the back speakers give no audio on any AFD setting... From what I understand BD is Bluray disc.
The above displays whether I use the XBOX 360, LG Smart LED, or Laptop. To clarify, all components are run as inputs to the TV and then via Optical to the Amp/Receiver, it has worked like this for years, but now it doesn't seem to, any advice?
All settings are as they always were on the amp.
Below are the audio system specs for your convenience
THANKS
Amplifier
60hms1kHz 90W + 90W
Total Power Output (1kHz, 6Ohms, 10%THD) 185W x 6 + 200W x 2 = 1510W
Number of amp. channels 6.2ch Type Analog
Circuit Device Discrete
DSP Sharc
Sub Woofer X Over Fix 150Hz
Sound Field Link (w Lock) Yes (No)
Sound Field Program (Movie) 3
Sound Field Program (Music) 4
Sound Field Program (A.F.D) 11
Sound Field Program (2ch) 1
Sound Field Program (Heahphone) 2
Cinema Studio EX. A/B/C mode Yes
Speaker Selector A
Speaker Terminal Frt : Screw, Other : Push
4 Ohm/8 Ohm Switching No (6 Ohm only)
Portable Audio Enhancer Yes
I/Os
Audio In/Out (excl. tuner) 2 / 1
Optical: including Front A/V 2 /-
Coaxial 1 /-
HDMI Digital Video Switching In/Out 2 / 1
Digital Media Port Yes
Digital Assign
SW Pre Out Yes (x4)
Decoding Format
Dolby Digital/DTS Yes / Yes
Dolby Prologic Yes
Dolby Prologic II Yes
Dolby Prologic IIx Yes
Dolby Digital EX Yes
Digital Cinema Sound Yes
Digital Cinema Auto Calibration (D.C.A.C) Yes
96k/24Bit PCM Yes
Dolby Dual Mono Yes
Tuner
Preset Channel 60
Station Name Yes
Auto Tuning Yes
Direct Tuning Yes (RM)
Video Features
A/V SYNC Yes (Fixed)
HDMI Repeater No (Switcher)
General
Remote Commander Yes, RM-AAU027
Display 8 Seg. FL
Sleep Timer Yes
Pin Jack Nickel
Speaker System
Subwoofer: Output Power / Music Power 200W
Subwoofer size 25cm
Subwoofer Speaker System Bass Reflex
Subwoofer Magnetically Shielded Yes
Front Speaker size for L,R 16cm x 2 + 2.5cm Horn Tweeter
Front Speaker System Bass Reflex
Front Speaker Magnetically Shielded Yes
Surround Speaker Size 10cm x 1
Surround Speaker System Bass Reflex
Center Speaker Size 10cm x 2 + 2.5cm Horn Tweeter
Center Speaker System Bass Reflex
Center Speaker Magnetically Shielded Yes
Speaker Connection: Subwoofer RCA Jack
Speaker Connection: Satellite Speakers Push Terminal
Weight & Dimension (Speakers)
Front Speaker Size (W x H x D) 305 x 1000 x 325 mm
Front Speaker Weight 13.5kg
Center Speaker Size (W x H x D) 515 x 175 x 225 mm
Center Speaker Weight 4.8kg
Surround Speaker Size (W x H x D) 174 x 220 x 166 mm
Surround Speaker Weight 1.4kg Subwoofer Size (W x H x D) 335 x 420 x 430 mm
Subwoofer Weight 11kg
Wynand Geldenhuys is offline
post #2 of 3 Old 04-07-2020, 09:08 AM - Thread Starter
Liked: 0
Other details on pictures...
Name:	LG TV Model.jpeg
ID:	2706978   Click image for larger version
Name:	Sony 6.2 Model.jpeg
post #3 of 3 Old 06-02-2020, 12:44 AM
philpoe's Avatar
Quoted: 258 Post(s)
Liked: 103
It looks like something changed, and since it looks like everything is playing in stereo, perhaps the The TV or system was inadvertently set to stereo mode.
Check the audio output settings of the TV (maybe it was reset or a firmware update was taken that reset the audio) and make sure it's Dolby.
If not, check the receiver. Page 52 of the manual begins the section describing surround settings (Enjoying Surround Sound). Page 57 describes setting it to 2ch stereo.
Amp: STR-K1600
philpoe is online now
Reply Home Theater In A Box
6.2 , bd. , mu te ki , muteki , Sony
