any good one to recommend? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 04-14-2004, 11:02 AM - Thread Starter
gqsmuv's Avatar
for a price range of around 250-350 tops...looking for at least a multi disc dvd player and radio tuner...would love for the speaker connection to use A/V (the red/white/yellow ones) instead of hte copper wire (or whatever it's called) that some systems uses ~~> does it even make a difference?
not a big room at all, but just want something so i can have one, and hopefully not break that easily...sony dream system?...panasonic ht700?...please recommend some...thanks a lot
gqsmuv is offline
post #2 of 7 Old 04-14-2004, 03:32 PM
Q of BanditZ's Avatar
Any of those are good. Sony HT7700D might be nice, although it does go past your price range a bit.
Believe it or not, Zenith actually has some decent units that you can even order on Amazon if you feel like it.
Great ISF Job by Chad B.
Q of BanditZ is offline
post #3 of 7 Old 04-14-2004, 06:49 PM - Thread Starter
gqsmuv's Avatar
which zenith ones do you have in mind?
thanks
gqsmuv is offline
post #4 of 7 Old 04-15-2004, 11:43 AM
Zenith XBS344 or DVT 312. DVT216 is older and you might get clearance on it.
I think that XBS one might be newer and a little better.
http://www.amazon.com/exec/obidos/tg...066518-1661627
Good luck!
post #5 of 7 Old 04-15-2004, 04:49 PM
LasVegasMichael's Avatar
With your bedget, you should be able to find a decent selection (especially if you dig around online and/or a member of some wherehouse type stores like Costco).
I have heard very mixed reviews on the Sony Dream machines and the Panny HT-900. Haven't heard too much on the HT-700, but you might want to check out some of the other threads in this forum, as someone posted a link about the Panny.
I was originally going to get the Ht-900 but decided, at the last minute due to some reviews, to spend a little more and get a Denon HTIB system.
Like you are already doing, I would stick to a name brand, and with $350 max to spare, that should not be a problem.
Personally, I am not a big fan of 5 disc carousel for DVD players, but that is just me (CD, on the other hand, I have a 5D and like quite a bit).
Personally, I would vie toward those with separate components if possible.
Also, do you have a DVD player already? If so, or even if not, you may want to consider a better unit that has just the amp and speakers, and attach your own (or a new one) separately. The reason I recommend this is because DVD players (even with prog-scan) are getting so inexpensive nowaways that you could get a better then average sound system for the $350 now, use your current DVD player for a while (or pick up a new cheapie), and then upgrade to a better DVD player at a later time.
Just throwing out different ideas for you, sorry for the rambling.
Good luck!
Of course, this is just my opinion, and I could be wrong. -- Dennis Miller
My DVD Collection
LasVegasMichael is offline
post #6 of 7 Old 04-16-2004, 11:21 AM
garyfritz's Avatar
For the same general price range, $250 or less, are there any really decent 5.1 receiver + 4 spkrs + sub packages out there? I plan to get a Momitsu DVD so I don't want one of the packages with a cheap DVD. JBL used to sell some refurb systems on ebay that were supposed to be quite good and went for ~$250, but they seem to have stopped moving those.
garyfritz is offline
post #7 of 7 Old 04-16-2004, 11:25 AM - Thread Starter
gqsmuv's Avatar
yo LV Mike, no rambling at all, thanks for your insights...i dont have a dvd player (except PS2)...i jsut want to get a whole set instead of piece by piece b/c my living is small, just wanted one just so i can have one...if i ever move to a bigger place, i'll definitely do the piece by piece option...
well, any good ones to recommend?...=)
gqsmuv is offline
Closed Thread Home Theater In A Box
