SLS - Q-Line Gold 650W Home Theater System - Page 20 - AVS Forum | Home Theater Discussions And Reviews
post #571 of 595 Old 03-11-2011, 12:13 PM
Elihawk's Avatar
Quoted: 2064 Post(s)
Liked: 2230
Hoff the good news is your wife sounds fully on board...the bad news is now you have to watch a lot of Glee!
Set up #1: EMP e5Ti, e5Ci, and EMP e5Bi surrounds, Outlaw LFM1 Plus sub, SVS NSD SB12 sub, Integra AV receiver
Set up #2: Def Tech CA Aero 2, CLR2002, SLS Qline surrounds and EMPtek10i10i sub, Slimline AV receiver
Set up #3: Philharmonics- BMR in a 2.0 system, music only, Integra AV receiver
Elihawk is online now
post #572 of 595 Old 03-11-2011, 01:06 PM
TheHoff's Avatar
Haha, you think our household wasn't seeing its fair share of Glee prior? I had to keep the peace then too!
TheHoff is offline
post #573 of 595 Old 03-15-2011, 03:12 PM
skiaddict77's Avatar
Just got mine last week to replace the a 2.1 Logitech computer speakers, wow...it is like upgrading from a sh*tbox 1995 Miata to Porsche 911. Prior to this, I bought a Pany Soundbar from Walmart and I was not way compare to my Logitech PC speakers so the soundbar was returned. I have a 54" Pany TC-P54G25 Plasma and everything are connected from my PC, I don't have a DVD or Bluray player. I was hesitated to get this system due to lack of HDMI input/output, however, I connect HDMI straight to PC to TV, toslink from PC to receiver, toslink from TV to receiver for TV shows/programs. I can't compare to others systems and I don't know whether it sounds $1K or $2K but it sounds good and the wife is really happy. Just make sure to get a couple Toslink (optical) and additional speaker wires for rear speakers, supplied speaker wires are three 10 ft for Front/Center/Lefts and 30ft for rear surround speakers are not enough for me (25x15 room).
skiaddict77 is offline
post #574 of 595 Old 04-02-2011, 01:42 PM
langeswelding's Avatar
Oustanding speakers
langeswelding is offline
post #575 of 595 Old 04-08-2011, 09:29 PM
placiusbr's Avatar
I like the reviews on SLS Q-Line Gold speaker set. Speakers are rated 4ohm. Is denon avr-1911 compatible with that. I read somewhere avr-1911 recommended with 6 to 16 ohm speakers. Is it bad for the sound quality?
This will be my first speaker set and I am confused with the possibilities.
I will use this set for mostly movies, but also like to listen good quality music time to time.
placiusbr is offline
post #576 of 595 Old 05-24-2011, 09:13 PM
nkletzing's Avatar
I have been through two receivers--first went went wonky, doing random things--dimming the display, changing inputs, volume, etc. I made sure it wasn't the remote by pulling the batteries. So SLS replaced it under warranty. Then 2nd receiver just kinda died. Now you hear it, now you hear a bit of mild static, now you hear... silence. Complete power down; power on; a bit of audio, some static, then silence.
The sub is in the attic (not bad, but kinda boomy, lacking on the very low end). The receiver is going out for the trash today. I have a spare remote--anyone interested?
The old Yamaha integrated stereo amp works really well with the SLS speakers on the passive Infinity bandpass box sub.
nkletzing is offline
post #577 of 595 Old 05-25-2011, 12:18 PM
Elihawk's Avatar
Liked: 2230
It may be beside the point...AV express is listed those speakers as out of stock and I hear they think they can get a few more systems, but the supply is almost out.
I have had the reciever for 6 months and it has been very good...except the lack of hdmi! With that AV-rec being so old (released in 2006?), I would think they would be best off selling the speaker sets alone....
post #578 of 595 Old 07-23-2011, 06:13 PM
GlibHarbinger's Avatar
I took a closer look at the SLS sub, it looks to be net about .8 cu ft, volume with a 3" port that's 9" long. That would be a 46 Hz tuning.
I found a driver that models pretty well in it, a Dayton DCS205-4 8", you'd have to extend the port to 14" long using a 90 degree bend. That gets you an F3 of 35.8 Hz, which is probably 10 -11 Hz lower than the stock setup. Produces 104dB at 50 watts.
Might be an interesting project someday, the driver is pretty cheap.
GlibHarbinger is offline
post #579 of 595 Old 08-09-2011, 07:34 AM
killscallion's Avatar
Hi guys,
I'm completely new to this surround sound thing (as well as hooking up video / audio cables). I've typically just been using the speakers on my TV so the full extent of my experience is connecting the PS3 to the TV.
After ordering the SLS Q-Line Gold, all the wires and possible connections are a little overwhelming. Can someone advise on how exactly I can go about hooking up my plasma TV (Samsung PN59D8000) with a HD cable box, my PS3 and the SLS Q-Line Gold? Do I need to purchase any cables currently not in the box?
Appreciate any help at all.
Sam
killscallion is offline
post #580 of 595 Old 08-09-2011, 08:33 AM
Elihawk's Avatar
Liked: 2230
You will need a optical digital cable. The Sherwood reciever doesn't have Hdmi ports...but does have toslink optical and coaxial connectors for digital transmission.
post #581 of 595 Old 08-09-2011, 08:47 AM
Thanks. I will order a digital audio optical TOSLink cable from Amazon then.
However, it sounds like I will need two optical digital inputs on the receiver, one for the TV and one for the PS3, but the SLS Q-Line Gold only comes with one. Any suggestions as to workarounds?
post #582 of 595 Old 08-09-2011, 01:03 PM
Elihawk's Avatar
Liked: 2230
I think you may have to run any "additional" opticals through your TV?! My SLS system doesn't have a PS3 to deal with, so....
post #583 of 595 Old 08-10-2011, 05:09 AM
jhsfosho's Avatar
Looks like the Sherwood does have 2 TOSLink optical ins and 2 coax digital ins so you should be fine.
http://www.sherwoodusa.com/pdf/RD-8601.PDF
Worst case scenario, get a TOSLink to coax adaptor from monoprice for $12 to convert your TOSLink optical output to a coax digital input for the receiver.
jhsfosho is offline
post #584 of 595 Old 08-11-2011, 08:52 PM
Yes the Sherwood has two optical in and two Coax in.
post #585 of 595 Old 08-29-2011, 12:14 PM
Sugarun's Avatar
Parts Express Model 830667, Part# 264-1102. About $60.00 It is the same as the one that came with my AV Express unit. The coil came lose and started making a rattling noise. AV Express send me another woofer that made a worse sound than the one I replaced, I think a return because the paper was torn half way around the cone. I don't think AV Express was aware of the tear as you had to compress the speaker to reveal the tear... I repaired it with RTV, sounds great now. I wanted to find a back up as these will be hard to find and replace in the furture. Searching found Parts Express.
Sugarun is offline
post #586 of 595 Old 09-11-2011, 10:04 AM
biomed_eng_2000's Avatar
Is the center speaker identical to the other speakers in the Q-Line Gold series?
biomed_eng_2000 is offline
post #587 of 595 Old 09-12-2011, 04:01 AM
Sugarun's Avatar
The Q-Line center is the same as the others in the set except the SLS logo is placed horizonal as would be for a center speaker. They have 2 x 4" Kevlar Cone Woofer & 1 x 1 1/4 Ribbon Tweeter. 4 Ohm.
Sugarun is offline
post #588 of 595 Old 09-12-2011, 05:28 AM
InVinoVeritas's Avatar
From my owner's manual, it also notes that the center channel is magnetically shielded. Also, unless it's changed, my owner's manual says that all the satellites are 6 ohms.
InVinoVeritas is offline
post #589 of 595 Old 09-12-2011, 06:55 AM
Sugarun's Avatar
The receiver is 6 & 4 Ohm. The speakers are 4 Ohm according to AV Express wep site specification sheet.
Sugarun is offline
post #590 of 595 Old 09-13-2011, 05:54 AM
Sugarun's Avatar
Looking in the manual it does say the speakers are 6 Ohm. InVinoVeritas you are right. So I decided to look at one of the speaker... The lable on the back of the speaker says they are in fact 4 Ohm. Go figure!
Sugarun is offline
post #591 of 595 Old 09-13-2011, 10:39 AM
This 4 ohm/ 6 ohm discrepancy was noticed a while back in this thread. I think everyone decided that the speakers are actually 4 ohm.
post #592 of 595 Old 10-31-2013, 03:29 PM
sociojeje's Avatar
I'm still using the speakers. The speakers are 4 ohm. Confirmed by SLS. My woofer drive broke and i put cheap pyle drive and it works well.
my receiver also died and replace to HK avr 1650. I am still glad that I picked this system.
Anyone still happy about the set?
sociojeje is offline
post #593 of 595 Old 11-06-2013, 08:09 AM
sonsyskyes's Avatar
good info,I can tell you exactly what's going into my main room next upgrade...thank you
BcF6ID
sonsyskyes is offline
post #594 of 595 Old 02-08-2020, 09:16 AM
Elihawk's Avatar
Liked: 2230
Bumping this really old thread to say I am still using the SLS speakers as surrounds in one system I have in my house and have two additional speakers in a system in my garage! Excellent little speaker, as long as you don't expect bass below 120 hz or so...
post #595 of 595 Old 02-09-2020, 10:54 PM
OPPOBUYER's Avatar
It's been about 10 years since I bought my SLS speakers and they still sound great. I really didn't expect to see this tread ever again but I'm glad there are others still enjoying them as well. It you are still rocking them, please chime in.
OPPOBUYER is offline
Reply Home Theater In A Box
