Black velvet fabric - AVS Forum | Home Theater Discussions And Reviews
 27Likes
post #1 of 108 Old 06-19-2015, 12:00 PM - Thread Starter
ERuiz's Avatar
Quoted: 832 Post(s)
Liked: 342
Black velvet fabric
Does anyone have a link to a GOOD black velvet fabric? After a quick search, I was overwhelmed with how many options are out there.
So of course, I want to know what you guys use and recommend.
I need a couple of yards of this fabric, so I can build a few panels which will be used below my screen to catch spillover when viewing in 2.35:1 and to mask vertical bars on my screen when switching from 2.35:1 to 16:9.
Thanks in advance!
JVC DLA-NX7 / 125" 2.40:1 Stewart StudioTek 100 / Denon AVR-X4300H / Klipsch RP-280F (L/R) / Klipsch RP-450C / Klipsch RP-150M (x4) / Klipsch RP-140SA (Atmos) / HSU VTF-3 MK5 DualDrive / Apple TV 4K / Xbox One X / PS4 Pro / Logitech Harmony Elite
ERuiz is offline
post #2 of 108 Old 06-19-2015, 12:12 PM
asarose247's Avatar
Quoted: 1329 Post(s)
Liked: 1169
j0-ann's royal velvet #3 had received good recommendations wrt to light absorbtion/.mitigation.
AVS member kevings uses a projector also and did almost an entire popcorn ceiling wrt to unwanted,interferring light in his viewing area.
I had the opportunity to view it as before and after.
he nailed it.
i'm trying to adapt the same stuff in my own set-up.
ERuiz likes this.
DIY FAN Denon X4400 , ATI A 2000 for 7.4.6 SCATMOS Sammy 82" 4K/HDR
L/R: Fusion 15 V2 , C: 88 Special , SL/SR: 88 Special(V2) , RL/RR: F-3, TF/TR: Volt 6's TM: SLX, FH: F4Q4
SUBMAXIMUS V2, ,Submaximus V3,LOWARHORNCustom Dual Driver VBSS,2 x 6000DSP
asarose247 is online now
post #3 of 108 Old 06-19-2015, 12:37 PM - Thread Starter
ERuiz's Avatar
Quoted: 832 Post(s)
Liked: 342
he nailed it.
http://www.joann.com/crushed-panne-velvet/prd32173.html
Is this it? I searched for Royal Velvet and nothing came up.
ERuiz is offline
post #4 of 108 Old 06-19-2015, 12:39 PM - Thread Starter
ERuiz's Avatar
Quoted: 832 Post(s)
Liked: 342
Nevermind, I found it. It was under Royalty lol
http://www.joann.com/royalty-3-velvet/xprd728568.html
Thanks!!!!
ERuiz is offline
post #5 of 108 Old 06-19-2015, 01:01 PM
DIY Granddad (w/help)
MississippiMan's Avatar
Quoted: 4268 Post(s)
Liked: 2113
You DO NOT want to use the Royalty Velvet unless you have no other options.
And of course...you do have another option...and a better, far less expensive one no less.
http://www.syfabrics.com/View.aspx/P...Velvet/681/264
I cannot understand how...after over 10 years of posting that same information innumerable times, how people still do not get the message.
I used to shop at JoAnns and Hancock Fabrics...and I used the Double Eagle and Madonna Brands, which were good. But at the very least I was paying $11.00-$14.00 yrd w/Coupon and supply was almost always limited. Without a Sale or Coupon, the best Black Velvet can cost over $24.00 yd!
Having stumbled upon Sy Fabrics, I have never found anything that would remotely make me switch.
RLBURNSIDE, ERuiz and ipca204 like this.
MississippiMan is offline
post #6 of 108 Old 06-22-2015, 11:26 AM - Thread Starter
ERuiz's Avatar
Quoted: 832 Post(s)
Liked: 342
Hey MM, I ordered 4 yards of this fabric and had a quick question for you.
Is this the material that all I need to do is make a cut about 4 inches deep, then I grab one end and have my wife grab the other while we both walk in opposite direction thus making a perfect rip?
ERuiz is offline
post #7 of 108 Old 06-22-2015, 04:42 PM
Liked: 2113
Yep.....rip it.....rip it good.
Just be prepared to sweep...and also pull away the loosened threads.
PS....a straight 2" to 3" cut is really all that's needed.
post #8 of 108 Old 06-24-2015, 10:13 AM
Hank's Avatar
Quoted: 78 Post(s)
Liked: 33
"I cannot understand how...after over 10 years of posting that same information innumerable times, how people still do not get the message."
+1
MM: why not make a syfabrics Best Black Velvet Screen Frame Covering sticky?
Hank is offline
post #9 of 108 Old 06-24-2015, 12:17 PM
Liked: 0
Also on Amazon,
h0b0 is offline
post #10 of 108 Old 06-24-2015, 12:23 PM
Liked: 2113
+1
Sticky Status is designated by the Moderators as per need / request. I'll look into creating another updated Sticky concerning suggested materials that cove a widely varied range of DIY screen construction projects....not just mine.
post #11 of 108 Old 06-24-2015, 03:12 PM - Thread Starter
ERuiz's Avatar
Quoted: 832 Post(s)
Liked: 342
@MississippiMan
Hey man, I got the velvet today and I have a question.
Will the material "rip" both length wise and across?
Need to know before I start yanking on it and it won't rip right.
ERuiz is offline
post #12 of 108 Old 06-24-2015, 04:21 PM
Liked: 2113
Rip it length wise....cut it side to side.
Honestly though....I have never had need to do anything but cut it across the shorter width....so I cannot say it will or will not.
But I'm a'guessin' no.....
post #13 of 108 Old 06-24-2015, 04:28 PM - Thread Starter
ERuiz's Avatar
Quoted: 832 Post(s)
Liked: 342
Gotcha, I will rip it length wise and cut it across. Thanks, brother!
ERuiz is offline
post #14 of 108 Old 06-25-2015, 01:15 AM
Liked: 2113
Tear 'em up!
post #15 of 108 Old 06-29-2015, 08:39 AM
Naylorman32's Avatar
Quoted: 514 Post(s)
Liked: 225
I've seen a couple different answers on this, but how would i attach velvet to a drop ceiling right above my screen? I dont think push pins would be nearly enough, right? I'm thinking of coming about 5 feet out from the screen.
Naylorman32 is offline
post #16 of 108 Old 06-29-2015, 09:22 AM
Liked: 2113
Thumb Tacks work great. Simply get then stuck onto some Cardboard, and spray them with a Flat Black "Enamel".
One every 2' x 3' square, while slightly pulling the material will result in a very smooth and flat surface.
unretarded likes this.
post #17 of 108 Old 09-24-2015, 04:37 AM
varun432's Avatar
Quoted: 56 Post(s)
Liked: 24
Hi Guyz.., I am in India...
I have been looking at various black velvet fabrics..,
The nylon velvet fabrics I am getting is bit shiny cloth...
What should I be looking at,when buying black velvet fabric..
Can the material be shiny..?
Should it be thick material?
Please help..
Need to cover my walls and ceiling around the screen
varun432 is offline
post #18 of 108 Old 09-24-2015, 05:42 AM
Liked: 2113
Please help..
It can be a bit shiny....just a slight sheen under Incandescent lighting.
It should have a "Velvet-like" short Nap
It can and should be only one layer thick... thin cloth with a Velvet Map
post #19 of 108 Old 09-24-2015, 06:19 AM
varun432's Avatar
Quoted: 56 Post(s)
Liked: 24
Thanks for the response ..
Why should it be thin and single layered?
Sent from my iPhone
varun432 is offline
post #20 of 108 Old 09-24-2015, 07:26 AM
Liked: 2113
Sent from my iPhone
You don't need nor want to pay extra for "Flocked" (lined) material, nor do you want / need the additional weight such thicker material has.
Flat Black coated Thumbtacks are the easiest and best way to hang up such Velvet onto Ceilings and Walls made of Gypsum or Wood...unless of course the walls & ceilings are Concrete Cinder Block that's Painted or coated with Stucco. Then you'll need some sort of adhesive (yuck) , or screws w/Washers (...also painted Flat Black...)
varun432 likes this.
post #21 of 108 Old 09-24-2015, 10:03 AM
varun432's Avatar
Quoted: 56 Post(s)
Liked: 24
Thanks !!! MississippiMan
Sent from my iPhone
varun432 is offline
post #22 of 108 Old 06-19-2017, 01:17 PM
JCJetta's Avatar
Quoted: 350 Post(s)
Liked: 702
Bringing this back up from the Great Beyond to thank @MississippiMan .
I screwed up my first attempt using Royalty 3 from the large retailer mentioned in this post - but truly the visit to the actual store was where the real agony was. I'm looking forward to working with this stuff from SyFabrics for half the price of the Big Retailer, and the most I'll have to travel to pick it up will be my front porch.
MississippiMan likes this.
JCJetta is offline
post #23 of 108 Old 06-28-2017, 06:21 AM
JCJetta's Avatar
Quoted: 350 Post(s)
Liked: 702
Update:
So I received my 10 yards yesterday; it looks great but they folded it all up and put it in a tiny box. What are my options to get rid of the wrinkles? Is it iron safe?
I made the incorrect assumption I'd get it on a roll. What a pain!
JCJetta is offline
post #24 of 108 Old 06-28-2017, 06:27 AM
kmhvball's Avatar
Quoted: 569 Post(s)
Liked: 340
I love my Royalty 3 black velvet from Joann fabrics. I regularly receive 60% off coupons, so, I certainly didn't pay a 'full price' for it. I think it works exceptionally well at absorbing light. I did go to the store to pick it up, which in my case happens to be somewhere I pass by almost every day - so, not a real challenge for me.
This is NOT to say anything negative about the Sy fabric stuff, I have never seen it or touched it, so, have no real thoughts on it.
I just wanted to share that for some folks, the Royalty 3 works great.
kmhvball is offline
post #25 of 108 Old 06-28-2017, 06:51 PM
Liked: 2113
Originally Posted by JCJetta View Post
Update:
Yep. You cannot order direct via the Internet and expect it to be shipped on a Roll. Hanging the Velvet vertically, and steaming it works. DO NOT Iron...you will flatten out the Nap.
Just hanging will work...it just take longer.
If your wrapping, it doesn't have to be wrinkle free...just "Crease-free". Wrinkles will stretch out.
JCJetta likes this.
post #26 of 108 Old 07-12-2017, 09:40 AM
KilroyNo1's Avatar
Liked: 1
I'm planning on ordering this from the U.S. and using it for framing 4"-5" around the sides and bottom of my wall painted screen, but I'm not sure how to go about mounting it super straight/square.
I was considering attaching it to 3 lengths of door casing and then mounting it to the wall, but glue would be a nasty mess. I could wrap it around the casing and attach to the back, but then the casing wouldn't mount flat to the wall.
Any ideas or tips?
No person is an island.
KilroyNo1 is offline
post #27 of 108 Old 07-12-2017, 09:43 AM
Liked: 2113
Any ideas or tips?
Velvet is very thin, and wraps in one layer, so that with any degree of attachment, the Frame will look completely flush against the wall.
post #28 of 108 Old 07-13-2017, 02:02 PM
KilroyNo1's Avatar
Liked: 1
So a little glue to hold it in place on the back side an I should be good to go. Unfortunately I have to buy a 10' length so that I can wrap the bottom frame with one piece. :-(
post #29 of 108 Old 11-13-2017, 06:57 AM
2Charlie's Avatar
Quoted: 193 Post(s)
Is it because the fabric at Sy Fabrics is less expensive or better quality for light absorption?
2Charlie is offline
post #30 of 108 Old 11-13-2017, 07:41 AM
Liked: 2113
Among all the Black Plush Velvets, it performs either as good as the best of them or better than virtually all of them.
It also "tears" into uniform strips easily, not needing to be meticulously cut down it's length.
And it is the least expensive.
Share the love.......
Reply DIY Screen Section
