Carl's Ambient Light Rejecting? - Page 10 - AVS Forum | Home Theater Discussions And Reviews
 54Likes
post #271 of 294 Old 10-30-2017, 06:10 PM
Gabre's Avatar
Quoted: 456 Post(s)
Liked: 71
Funny how people have different opinions.
Check this out. ALR produces awfull tint, and whites are completelly messed up,not to mention hot spot and vignetting, along with bad viewing angles.
Fyi,I just threw a white bed sheet over left side.
Gabre is online now
post #272 of 294 Old 11-24-2017, 10:14 AM
Quoted: 12 Post(s)
Liked: 4
Hi,
I got Sony VPL-45 and considering to buy a paint ALR or this Carl's material.
I see that whites are dimmed also on the sample I buyed of this paint at my store.
But blacks are better and also the dark scenes.
So what do you recommend?
radek0582 is offline
post #273 of 294 Old 11-24-2017, 11:19 AM
DIY Granddad (w/help)
MississippiMan's Avatar
Quoted: 3688 Post(s)
Liked: 1703
Opinions are one thing.....the eyes do not lie.
The real issue is how some refer people to this particular material for the wrong reasons: "Easy"...."Affordable"..."Effective" when asked about DIY ALR choices. But they also seem to willfully ignore the well known caveats.
I've suggested otherwise, because of the above stated issues and others too, for quite a while, but usually get shouted down (..yeah, that CAN happen.. )
Now don't take me wrong...I'm a advocate and supporter of Carl's, but there a few items that are sold that just do not measure up to the standards I have become accustomed to adhering to and suggesting to be considered as a "minimum" purveyor of image quality.
radek0582, there are DIY paints that can, and will do better. Some advanced, truly higher performance paints cost more, and require spraying, but some DIY paints that cost less than Carl's ALR do as good or better a job of ALR'ing but do it without the Color Shifts and dulling Whites. And...they'll not have the hot spotting, severe vignetting, or bad viewing angles. And some of those can be rolled on.
That's about all I can / should say on a Thread dedicated to Carl's ALR, so judge your decision making process accordingly.
MississippiMan is online now
post #274 of 294 Old 11-24-2017, 11:25 AM
Liked: 1703
Gabre,
Last Mid-June you posted a much more favorable evaluation of C-ALR.
Was it the employment of a White Reference material (Bed Sheet) that opened your eyes, or the inability to calibrate in an except-able image?
That information would be an important addition...and help to others when considering their options.
radek0582,
What Paint did you buy / have Tinted?
post #275 of 294 Old 11-24-2017, 11:44 AM
Ftoast's Avatar
Quoted: 2688 Post(s)
Liked: 877
The upper area of the comparison images appears very closely matched in many if those pictures, so it looks like the projector isn't ideally positioned for a lght-fighting screen this aggressive..the projector appears to be mounted too close and a little too high (or screen screen is a little too low).
A screen or paint with a wider viewing-cone (sadly also means a less aggressive light-fighter) can pair with more forgiveness despite a non-ideal projector mounting position. A lighter-grey screen or a dark-colored screen with less gain can be more forgiving.
The vpl45 is a solidly bright projector that's capable of a 1.5:1 throw-ratio without issues, so pairing it along with a reasonably-sized screen can work very well with Carl's ALR material while still providing a very bright image.
What screen-size are you aiming for and about how close or far back can you mount the projector?
Easy $25 DIY black (or any color) ALR paint +$40-$50sprayer screen mix smooth/clean and very easy to learn spraying with little/no mess.
Simple $25-40 DIY black/dark-grey ambient-light rejecting screen, grab two things from a local store..mix..roll..done.
Quick <$250 dedicated black-fabric theater room "A store that sells blinds can help your picture more than a store that sells projectors many times." -bud16415
Ftoast is offline
post #276 of 294 Old 11-24-2017, 11:59 AM
Gabre's Avatar
Quoted: 456 Post(s)
Liked: 71
Mississippi man, I share your opinion now after using it for a while.
And for my change of opinion, simply couldn't get the image to my liking.
When I first got it,I was impressed with black levels and boost in contrast. But after using it, drawbacks keep coming in more and more.
Simply; whites, details in shadow, dimmer image, hot spotting, and vignetting... To many to count.
Too many to count... I have to work on reflections in the room.
I am using white screen now, and I'm back to problems with washed out image at bright scenes
Will try going back to ALR and make my decision...
I did try a smaller light grey, and that might be actually a good balance.
Gabre is online now
post #277 of 294 Old 11-24-2017, 04:08 PM
Quoted: 12 Post(s)
Liked: 4
The paint sample I have is Evo High Contrast (or Evo MIXPAINT).
My projector is about 5 meters (16 feet) from the wall and screen size I would like to have is 120-130 inches.
Maybe I have to add some black borders to my screen. It is currently just the wall painted with gray matt paint.
post #278 of 294 Old 11-25-2017, 06:02 AM
Quoted: 12 Post(s)
Liked: 4
As I discovered for now the best results for this pj (VPL-45) are on max 125 inches from about 15-16 feet, since the white is strong enough (the lumens) and black or contrast is still good (while using my sample EVO paint) . Ofcourse on high lamp mode the white is also stronger than on low mode. On high mode maybe there could be 10 inches more (130-135").
post #279 of 294 Old 11-25-2017, 12:35 PM
Ftoast's Avatar
Liked: 877
Would you also be able to create a new thread about this Evo paint you used?
I don't believe there is one yet, and that could be a cool place to talk about this paint more in-depth while also making it easier for others to search that brand/name to ask questions about it from real users like you.
EDIT: It would also be a good place for posting comparison pictures of your Evo paint sample next to other paints or samples you are able to put together.
Ftoast is offline
post #280 of 294 Old 11-26-2017, 05:45 AM
Liked: 1703
I don't believe there is one yet, and that could be a cool place to talk about this paint more in-depth while also making it easier for others to search that brand/name to ask questions about it from real users like you. It would also be a good place for posting pictures of your new Evo screen.
Read a little closer....
radek0582 has only tried a sample of the Evo, and found it had properties he did not care for. He doesn't have a "Evo Screen" and he's asking fo ither suggestions. As for Evo paint, it's really just another attempt at someone trying to market another high contrast Screen paint, and the only examples to be seen "anywhere" are again...you guessed it....on YouTube. It apparently has managed to get some shelf space abroad, (...we know not where as of yet...) but without any real vetting and effective evaluation, it seems to be a bit of a moot, or rather premature in the least, request to ask for a Thread to be authored on a product whose only singular exposure has garnered a negative evaluation.
All that may change of course should radek0582 decide to use the Evo paint for his full sized screen, of course. He does state that the appearance of the Whites look somewhat better when Full Lamp mode is used....as might well be expected.
post #281 of 294 Old 11-26-2017, 11:41 AM
Quoted: 12 Post(s)
Liked: 4
Yes, currently I just got the sample of that Evo and consider buying the 0,5 L to paint 120" screen. The costs are about 300$ for half-liter at my store. They say that one painting is enough for 120 inches screen.
When I buy that Evo and paint, for sure I will make some thread with pictures.
post #282 of 294 Old 11-26-2017, 03:32 PM
Liked: 1703
$300 per 1/2 liter !!!!! That's $600.00 a Quart!
And some few talk about the cost of Silver Fire or Black Flame as being "high".
Of course they say you can paint a 120"er with 1/2 Liter...(16 oz) once in your stuck...and all you can do is cough up more money.
I tell ya something...you could "US" source every component for Silver Fire, and pay for International Economy shipping...all the Duties and Taxes, and you'd wind up with 3 QUARTs ( 2.8 Liters ) of paint...pay less than $300.00, and have more than enough to share with another person and cut your lower expenses by another 1/2 anyway!
Man...I feel sick. I shipped a lot of paint to exotic locations abroad in 3 qt quantities, and it never amounted to being more than $300+, or if so, only a few dollars extra.
post #283 of 294 Old 11-27-2017, 02:57 AM
Quoted: 12 Post(s)
Liked: 4
Silver Fire is also a good paint? What about Black Widow, which I read about somewhere on this forum?
Today I will take some photos with my EVO sample and post them in new thread.
post #284 of 294 Old 11-27-2017, 03:59 AM
Ftoast's Avatar
Liked: 877
SilverFire can be a good paintmix; it's roughly the same gain as Carl's ALR but a lighter shade of grey which means SilverFire doesn't hold blacks as deep against ambient light but it does hold brightness higher when viewed off-center.
BlackWidow can also be a good paintmix; it's lower-gain than Carl's ALR and lighter-grey than both Carl's and SilverFire which means it doesn't fight light as aggressively as either of those but it holds better brightness uniformity even with a shorter-than-ideal throw-ratio, and it holds the most consistent brightness off-center.
Ftoast is offline
post #285 of 294 Old 11-27-2017, 01:19 PM
Quoted: 12 Post(s)
Liked: 4
So I think, maybe I would try the Silver Fire (Black Flame).
Just need the ingredients.
post #286 of 294 Old 11-27-2017, 02:49 PM
Ftoast's Avatar
Liked: 877
If you haven't already visited it, here's the official SilverFire thread:
https://www.avsforum.com/forum/110-di...-2-thread.html
The first post in there lists the ingredients, amounts used, and where to find them as well as other important information for mixing it up. Feel free to ask questions if anything is confusing or unclear.
Ftoast is offline
post #287 of 294 Old 11-28-2017, 11:44 AM
Quoted: 12 Post(s)
Liked: 4
I wonder where I could buy the ingredients.
Maybe I will choose Silver grey instead of Black widow coz of probably deeper blacks. I want to watch movies without any lights, but I dont have dedicated theater room (light blue walls and ceiling, wooden floor).
I am in Europe, so dont know if there could be some proper shops with exactly that ingrediets.
Or I will look for recipe for Black Pearl, I like that screen results.
post #288 of 294 Old 07-17-2018, 12:52 AM
Liked: 0
Does Carl's ALR need to be raised above the frame? I read it's not completely opaque. Carl's instructions don't say you need to, but they are also not specifically for the ALR.
Tuomas Salokanto is offline
post #289 of 294 Old 07-17-2018, 12:00 PM
Ftoast's Avatar
Liked: 877
It's pretty opaque (though thin enough that strong sunlight can somewhat come through if you're trying to cover an otherwise uncovered window during the day).
You don't want screen material (especially light-fighting or high-gain material) resting against a frame's internal/middle supports or anything like that because those can ever so slightly push out a line or bump against the screen which can show particularly during brighter projected scenes because the screen isn't laying perfectly smooth and flat with that slight bump/line pushing against it.
Ftoast is offline
post #290 of 294 Old 07-18-2018, 03:42 AM
Liked: 0
I was planning to use little thinner middle supports for this. But still it would rest against outer frame. I don't want very thick border so I bought 2" felt tape, so it won't cover the whole 4" frame. Will this be a problem? Basically my plan is this: carlofet.com/images/howTo/cross-view.png (sorry, not allowed to link) It's suggested there but I don't want to rely on one opinion! Thanks!
post #291 of 294 Old 07-18-2018, 05:08 AM
Ftoast's Avatar
Liked: 877
Instead of using a wider border or a stand-off around the frame's front, would you prefer to build the frame with the edges and supports rotated to look thin while standing farther off the wall (like a shadow-box instead of a picture frame)?
This is another pretty common way to build a frame, but it does automatically mean the screen will stick out from the wall about 2.5"-3.5" (depending if you use 1x3's or 1x4"s).
Or you might be able to router or sand a flat/picture-frame style frame's edges so they slope inward/downward toward the middle and get thicker at the outer edges like a built in stand-off...kind of like trim or window frames/trim are commonly designed.
Ftoast is offline
post #292 of 294 Old 07-18-2018, 06:34 AM
Liked: 0
I prefer slimmer look. I think I will go with that idea, try to sand the edges inwards to make sure nothing touches the fabric. Good idea, thanks!
post #293 of 294 Old 07-18-2018, 08:14 AM
Liked: 1703
The amount of reduction (...done perfectly even all around the 3.5" frame...) would have to be at least 1/4" and be at least 2" wide, and still you'd have at least 1.5" at 3/4" high.....and then your Tape will not be sitting flat...... It's not really a workable solution...not nearly so as using Quarter Round as the Stand-off.
What you really need is to make the Frame in the most correct manner possible....on edge using 1x3s for the Perimeter, and 1x3s laid Flat, flush to the rear of the on-edge frame. Then, you can wrap the Black Tape over and around the 3/4" perimeter edge. You don't need to sand or plane down the inside edge of a 1x3...it will be fully covered by the Tape anyway.
That is how I would advise you do it, because that is how I would do it...and I've done more than a few in that manner.
.....but that's me...and I don't like poor results.
post #294 of 294 Old 07-26-2018, 09:40 PM
Gabre's Avatar
Quoted: 456 Post(s)
Liked: 71
If theres anyone from Canada reading here, I wanna sell mine, possibly with frame that I made....
Gabre is online now
Reply DIY Screen Section
