Need help with Sintra board..... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 01-20-2016, 08:45 AM - Thread Starter
Quoted: 12 Post(s)
Liked: 2
Ok so I have been talking with my local sign shop they have access to the material Sintra, but there is a problem that I need your expert opinions.
They have 4x8 sheets in 6mm and 12mm. $150 & $225! Really want 5x9 actually not going any small than 5x9!!!
Called back today they can order 5x10 sheet and cut to 5x9 problem is it only comes in 3mm? Would it be too flimsy or too thin? And it's $100 (by the way I'm Canadian in case you thought the prices were crazy, our dollar is at 67 cents now compared to US dollar lol)
Please let me know MM & others, thanks in advanced!!
Detlions is offline
post #2 of 13 Old 01-20-2016, 09:38 AM - Thread Starter
Quoted: 12 Post(s)
Liked: 2
Oh and with a 5x9 cut will my projected image fit "zero edge"?
Jvc x500r throw distance have not been determined as of yet, but between 12-16 feet.
Detlions is offline
post #3 of 13 Old 01-20-2016, 12:42 PM
DIY Granddad (w/help)
MississippiMan's Avatar
Quoted: 3522 Post(s)
Liked: 1638
The x500r is limited to no less than 12'-8" Throw "Lens Face to Screen" for a 122" Screen (107" x 60") allowing for an additional 3" distance from the absolute shortest Throw of 12'-5"
Other than that...yes, a 5' x 9' sheet will obviously work.
MississippiMan is offline
post #4 of 13 Old 01-20-2016, 12:45 PM - Thread Starter
Quoted: 12 Post(s)
Liked: 2
The x500r is limited to no less than 12'-8" Throw "Lens Face to Screen" for a 122" Screen (107" x 60") allowing for an additional 3" distance than the absolute shortest Throw of 12'-5"
Thanks MM i guess my main question is if the 3mm would work fine for screen/black flame
Detlions is offline
post #5 of 13 Old 01-20-2016, 12:56 PM
Liked: 1638
The surface of the material itself is fine...the same as 6 mm. The thinness however does require that it be carefully mounted onto the wall (...a smooth, flat wall...) using very thin adhesive so that adhesive lumps, bumps and/or any wall related defects do not show through as a surface deformation. With 6 mm there are usually no issues.
You know might get you a better price for the Sintra......so you don't have to settle for 3 mm (which is notably less expensive...)
post #6 of 13 Old 01-20-2016, 01:34 PM - Thread Starter
Quoted: 12 Post(s)
Liked: 2
Please PM me if you can find a 6mm sheet. Problem is i am in Ontario Canada. I will wait a couple days and see if you have contacts near me.
Thanks MM
Detlions is offline
post #7 of 13 Old 01-21-2016, 12:19 PM - Thread Starter
Quoted: 12 Post(s)
Liked: 2
Thanks MM
All dealers near me only sell 4x8 sheets
5x9 or higher is special order $375?..
Lucky me...
Detlions is offline
post #8 of 13 Old 01-21-2016, 12:20 PM - Thread Starter
Quoted: 12 Post(s)
Liked: 2
Help
Thanks MM
Lucky me...
Detlions is offline
post #9 of 13 Old 01-21-2016, 12:28 PM
Liked: 1638
Ottawa is not that far from you and their is a Laird Plastics there you can but direct from and bypass those mercenary-istic "Dealers".
Laird Plastics
700 Industrial Av #6 & 7
Ottawa, ON K1G 0Y9
877*227*2296
post #10 of 13 Old 01-21-2016, 01:10 PM - Thread Starter
Quoted: 12 Post(s)
Liked: 2
Laird Plastics
Ottawa, ON K1G 0Y9
877*227*2296
You are very resourceful my man.
Thanks a million!
Detlions is offline
post #11 of 13 Old 01-27-2016, 06:02 PM
Liked: 0
Is Sintra @ 3mm thick easier to mount than 6mm. I want to stick with velcro mounting if possible but will consider using a french cleat if necessary
Namrak is offline
post #12 of 13 Old 01-27-2016, 06:03 PM
Liked: 0
Will Laird Plastics deliver?
Namrak is offline
post #13 of 13 Old 02-03-2016, 04:50 PM - Thread Starter
Quoted: 12 Post(s)
Liked: 2
Going to local sign shop they have 4x8 in stock and it's a better fit in my rec room..
Detlions is offline
Reply DIY Screen Section
