AVS Forum | Home Theater Discussions And Reviews (https://www.avsforum.com/forum/)
-   DIY Screen Section (https://www.avsforum.com/forum/110-diy-screen-section/)
-   -   DIY Round 3 139" Spandex for JVC 4910 (https://www.avsforum.com/forum/110-diy-screen-section/2493906-diy-round-3-139-spandex-jvc-4910-a.html)
laeriq 06-23-2016 06:04 PM
162 Attachment(s)
So projector fever caught me a few weeks ago so after researching the JVC 4910 looks to be the option I am most interested in. Currently I have a BenQ W600 with a CAVX III anamorphic lens throwing onto a curved 127" diagonal 2.35:1 white over grey spandex screen. Great combo but you all know how it is with change. Here's the link to the old project-
https://www.avsforum.com/forum/110-di...er-silver.html
My current plans are for a flat 139" diagonal scope screen 15' feet away that I will use the JVC lens memory to zoom with. I'll make a cedar frame and a 3" border with velvet. A few questions for this crew-
White over white will give me maximum gain over white over silver? Brightness is my only worry with the JVC and such a large screen.
JoAnn's spandex versus Spandex World? Looked at JoAnn's tonight and their stuff seemed nice but I did use Spandex World on the last build.
I've used the expensive JoAnn's black velvet for the last two borders... even with a 40% coupon I'm looking at $18 a yard. Should I be using SyFabric instead?
Thanks for any and all input. Even after I drop ~$250 on this screen, I'll be into three screens for under $800. The value in this forum is off the charts!
MississippiMan 06-24-2016 01:29 AM
White on White for maximum brightness, but somewhat reduced Black Levels
Spandex World is the "reference standard" however that's primarily based on price and known familiarity (tested)
SyFabric's Triple Black Velvet is excellent, and a incredible value.(-$8.00 yd) Using anything else simply amounts to spending more for no valid reason, and usually for less optimal results.
laeriq 06-24-2016 04:23 AM
162 Attachment(s)
Thanks again for all the help MM. They should rename this the MM Screen Section!
MississippiMan 06-24-2016 05:55 AM
wow.:eek:
That's quite the compliment, and appreciated....but OMG. :p
The hue and cry just suggesting such a thing in jest might cause could have ramification that go beyond anything one might expect.
Why, you can almost hear the pot about to boil over ! :D
laeriq 07-11-2016 01:43 PM
162 Attachment(s)
So good news is that the screen was assembled this weekend with about 8 hours of work and two movies have been viewed and I am quite pleased with it....
Bad news- my two center supports, mounted flat, are visible in bright scenes. We watched the last Bourne movie and the scenes in Tunesia revealed this. I did not paint my cedar as my last screen (white over silver) did not have this issue. My initial idea is to take some scrap white spandex and wrap those supports in it but I am open to any good suggestions!
MississippiMan 07-11-2016 04:52 PM
Wrapping in White Spandex is a good start. Seems you must have chosen White over White Spandex, as I have never seen anyone post that they could see central upright supports through a 2nd layer of Silver or Black.
I hope you have sufficient stand-off to add the material and still not have it tough the overlaying material.
Powered by vBulletin® Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
