Low gain removable screen options? - Page 3 - AVS Forum | Home Theater Discussions And Reviews
 3Likes
post #61 of 62 Old 06-19-2017, 08:21 AM - Thread Starter
ohcello's Avatar
Quoted: 42 Post(s)
Well really then, the entire comparison is skewered badly. Who knows who put it together, if it was rolled or sprayed... and what materials it consists of? In any case, if you PM me or email me your address, I'll see if I can send you something asap you can try, and if usable, then duplicate. I'd send enough for a "sizable" sample ( 2'x3' )
BTW, the ALR shows excessive hot spotting...the Flexi's gain is much more evenly distributed.
Agreed I have no clue about how the sample was created. Thanks so much, I'll PM you my adddress.
ohcello is offline
post #62 of 62 Old 06-19-2017, 08:39 AM - Thread Starter
ohcello's Avatar
Quoted: 42 Post(s)
Yes, the Flexi's gain was smooth... too bad the sparkles were excessive to my eye. As for the ALR... here i my photoshopped attempt at how the viewing cone would look... I took the straight on and side view and extrapolated both levels smooth together into one full screen... not a perfect experiment, but you see some light dropoff, which probably would be a decent approximation(?)
ohcello is offline
Reply DIY Screen Section
