Wall paint for economy projector - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 07-26-2018, 05:55 AM - Thread Starter
Liked: 0
I'm brand new to the projector game (to date, all of my projector time has been related to PowerPoint presentations ). To get started, I've opted for an economy projector in the RocketPro GP100. I am projecting on a sheetrock wall in a room with a drop ceiling and dark walls. The projector will be 10.5 feet from the wall to provide a 110" screen. Can I get some advice on paint for the wall? I will be rolling it on.
Teiharder72 is offline
post #2 of 3 Old 07-26-2018, 10:48 AM
DIY Granddad (w/help)
MississippiMan's Avatar
Quoted: 3512 Post(s)
Liked: 1636
Welcome to the Forum,
Well...................you did economize, didn't you.
I cannot attest to how bright that LED PJ is or will be at 110", but I would suggest that first,you roll on a White Paint such as Glidden/PPG Diamond Flat (Home Depot) and give that a watch-see. Keep in mind that is a Native 1280 x 800 PJ so your 110" screen area would be 58" x 93".
After a little bit of time, you might be better able to make some image quality determinations.
MississippiMan is offline
post #3 of 3 Old 07-26-2018, 10:59 AM
Goddard's Avatar
Quoted: 29 Post(s)
Liked: 24
Well I'm not sure if this would be considered just for projectors but we chose to use a color from Sherwin Williams called "Tricorn Black" in eggshell finish. After sifting through tons of user reviews and suggestions, this specific color was among the top recommended for home theater rooms or spaces.
Samsung 6 Series Curved UHD | Onkyo TX-RZ720 | Klipsch R-26FA Dolby Atmos | Klipsch RP-250C Center | Klipsch RS-42 II Surround | Klipsch R-10SW | OPPO UDP 203 | AudioQuest: Type 4 Speaker Cables ~ Carbon HDMI ~ Irish Red Subwoofer Cable
Goddard is offline
Reply DIY Screen Section
