I need a screen that will reflect as much light back at me as possible - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 05-25-2019, 02:10 PM - Thread Starter
MAYAmanIGN's Avatar
Quoted: 22 Post(s)
I need a screen paint that will reflect as much light back as possible yet still give me good contrast. Is this possible? This is for a large format curved screen with an aggressive curvature. Screen is 16 feet across but curved into an 8 foot diameter so the curvature is aggressive. I need light reflected back so that the individual in the middle gets light bounced back at them for illumination purposes.
What screen paint mix should I use to accomplish this. I need the cockpit to get ambient light from the simulation.
MAYAmanIGN is offline
post #2 of 4 Old 05-25-2019, 08:34 PM
DIY Granddad (w/help)
MississippiMan's Avatar
Quoted: 3403 Post(s)
Liked: 1601
To do what / all that you want in a Painted solution, you will need both a dark Grey and highly Reflective surface.....the latter almost solidly into the Retro-Reflective range.
Been there...done that years ago. Why not now? Because in any such case, DIY or Mfg...there are caveats we / I as DIY Screen advocates don't like, or won't tolerate.
  • A decided Grainy look to the image, especially in lighter content areas (Sky...light Pastels...Flesh Tones...)
  • Overt Retro Reflectivity. This will be the lessor issue in your application...except for the next point.
  • Projector Positioning ( extremely critical if Retro Reflectivity is used )
Three important things for you to make clear:
1. What is / are the PJ/s being used?
2. What Material is to be used for a screen surface?
3. Just how much Ambient Light is there to deal with (Level of, and Type/Source/direction)
How about usage / content?
There is / are solutions.....but to select the best one...even a compromised one, more input is needed.
MississippiMan is offline
post #3 of 4 Old 05-26-2019, 10:17 AM - Thread Starter
MAYAmanIGN's Avatar
Quoted: 22 Post(s)
3 projectors using warping software
Polycarbonate type material
Ambient light is totally controlled for now. Can be fully bright or total darkness. For this prototype its a completely light controlled environment. Once this goes into production it will more than likely be used in a convention center type environment.
Automotive simulation, heavy industry, aerospace, military
Answers above in your quote.
Any help is appreciated. I’m great at engineering mechanical solutions but the image is a tad more challenging.
post #4 of 4 Old 05-26-2019, 10:21 AM - Thread Starter
MAYAmanIGN's Avatar
Quoted: 22 Post(s)
Here is my prototype just so you’re familiar with my work so far.
Reply DIY Screen Section
