Black Flame DIY screen - AVS Forum | Home Theater Discussions And Reviews
 12Likes
  • 2 Post By biglen
  • 4 Post By biglen
  • 1 Post By biglen
  • 1 Post By biglen
  • 1 Post By biglen
  • 1 Post By biglen
  • 1 Post By fierce_gt
  • 1 Post By MississippiMan
post #1 of 30 Old 08-25-2019, 09:53 PM - Thread Starter
biglen's Avatar
Quoted: 571 Post(s)
Liked: 109
I recently bought an Epson 5050ub, and decided on a painted screen. After doing my research, it was clear @MississippiMan was the guy to deal with. He asked me about my setup, and he decided I should go with the Black Flame mixture, and it was best to paint the entire wall with the Black Flame, to avoid having black bars.
I primed the walls with 2 coats the other day, and sprayed the Black Flame today. I am an auto painter, so I used an Astro HVLP gun, with a 1.3mm tip. Here are some pics of the coats and final product as I was going along:
Sent from my SM-G950U using Tapatalk
pkinneb and Luminated67 like this.
biglen is offline
post #2 of 30 Old 08-26-2019, 05:25 AM
DIY Granddad (w/help)
MississippiMan's Avatar
Quoted: 3902 Post(s)
Liked: 1816
Nice Fan.
Same one I use.
That last macro shot shows a surface done to perfection. Very much looking forward to seeing the images to come.
MississippiMan is online now
post #3 of 30 Old 08-26-2019, 06:35 AM - Thread Starter
biglen's Avatar
Quoted: 571 Post(s)
Liked: 109
Nice Fan.
Same one I use.
Thanks MississippiMan ! I couldn't have got such a great finish without all your tips !
biglen is offline
post #4 of 30 Old 08-26-2019, 07:58 AM
Liked: 0
At that time the diy screen paint was Black Flame - a concoction which is now called Silver Fire and is in it's third rendition I believe
SuongSuong9x is offline
post #5 of 30 Old 08-26-2019, 08:49 AM
Liked: 1816
Black Flame is the commercially available version of Silver Fire, which is the open-source formula for do-it-yourselfers.
The difference between the commercial and the open-source formulas is in the reflective components themselves, which are similar but in the commercial version are of a higher quality, and even more so especially the colorants... which are very precisely mixed to achieve a truly dark and neutral gray additive.
Which of course is not to say that over the last 14 years that a great deal of time and effort hasen't gone into making sure that the best possible but retail available components have been selected to assure equally successful results. it is just such an effort that has led to the different versions of silver fire, which really only reflect searching out components to replace those which have been discontinued by various manufacturers.
So much so that today, after all of the revisions and changes, a do-it-yourselfer can dependably Assemble all of the components themself , and paint a screen which easily can compete with an even best it's manufactured counterparts.
post #6 of 30 Old 08-27-2019, 09:17 PM - Thread Starter
biglen's Avatar
Quoted: 571 Post(s)
Liked: 109
Here are some shots on the new screen. The picture is amazing.
biglen is offline
post #7 of 30 Old 08-29-2019, 06:09 PM
reechings's Avatar
Quoted: 107 Post(s)
Liked: 24
Where did you buy the pre-mixed paint? Is it possible to do with a roller? I haven't done much painting. Thanks
Sent from my Pixel 2 XL using Tapatalk
reechings is offline
post #8 of 30 Old 08-29-2019, 06:21 PM - Thread Starter
biglen's Avatar
Quoted: 571 Post(s)
Liked: 109
I got it from MississippiMan. A roller is not recommended, because a roller doesn't give you even distribution the way a spray gun does.
reechings likes this.
biglen is offline
post #9 of 30 Old 08-29-2019, 07:14 PM
reechings's Avatar
Quoted: 107 Post(s)
Liked: 24
How much did you need and how much did it cost? I'm in Canada so I'm guessing won't be cheap to get it here either.
post #10 of 30 Old 08-29-2019, 07:48 PM - Thread Starter
biglen's Avatar
Quoted: 571 Post(s)
Liked: 109
Message MississippiMan for a quote. I used a half a gallon on a wall that was 8'x12'. That was spraying with an HVLP auto paint gun. If you use an electric sprayer, it might use more paint than my gun.
biglen is offline
post #11 of 30 Old 08-29-2019, 08:54 PM
reechings's Avatar
Quoted: 107 Post(s)
Liked: 24
Yeah my wall will be around 7'4" x 14'2". Probably buy one of those guns I guess if it's that much better than a roller. So does the 5050 have a setting then that would remove the letterbox bars when watching content that's not 16x9 and I could just max out the image to the wall?
post #12 of 30 Old 08-29-2019, 08:58 PM - Thread Starter
biglen's Avatar
Quoted: 571 Post(s)
Liked: 109
When you paint the entire wall, the black bars just fade away into the screen. If you look really hard, you can faintly see them. I don't even notice them. MississippiMan can recommend a gun, and the size tip you need.
biglen is offline
post #13 of 30 Old 08-29-2019, 09:15 PM
reechings's Avatar
Quoted: 107 Post(s)
Liked: 24
Ok cool so the projector has different aspect modes too right? Either way I love the idea of being able to zoom a widescreen format movie to fill out the wall and if I have black on the other walls then the black bars won't matter.
post #14 of 30 Old 08-29-2019, 09:19 PM - Thread Starter
biglen's Avatar
Quoted: 571 Post(s)
Liked: 109
You set the aspects with the Lens button, then save them in the memory. So when you watch 16:9 content, you press the memory button, and the screen adjusts to the 16:9. Same with Cinemascope. Set the aspect, save it to memory.
biglen is offline
post #15 of 30 Old 08-29-2019, 09:50 PM
reechings's Avatar
Quoted: 107 Post(s)
Liked: 24
The part I get confused about is that you set the aspect but then you still have black bars?
post #16 of 30 Old 08-29-2019, 11:03 PM
fierce_gt's Avatar
Quoted: 2032 Post(s)
Liked: 1925
the projector has a fixed aspect ratio of 16:9, there's nothing you can do about that, it will always project a 16:9 AR out of the lens. but you can zoom it in/out to adjust the size of that 16:9 image to make it appear as though it's displaying a different AR. if your projector has suitably dark blacks, you won't notice the black bars.
as a more advanced method, some projectors have modes for use with anamorphic lenses. They still project a 16:9 image out of the projector, but the anamorphic lens stretches it to a scope AR. To make this work, the projector rescales the image and stretches it to fit the full height 16:9 image(so no black bars), then the lens stretches it horizontally back to it's original AR. the only downside is you don't have 1:1 pixel mapping, and you end up with rectangular pixels. But no black bars, and increased brightness since you can use the full size of the imaging chip.
Displays: Samsung PN64F8500/JVC X35
AVR: Pioneer VSX-1130K, 7.1/5.1.2 audio
Sources: HTPC, PS3, XBOX360, Wii
Control: Harmony One
fierce_gt is offline
post #17 of 30 Old 08-30-2019, 07:58 AM
Liked: 1816
One important aspect (...not an intended pun...) is that using a Paint Mix that has a decided Grey tint to attenuate Black Bars, yet does not proportionately compromise White and Colors is what allows the "near black" of Format Bars to recede virtually to unnoticeable levels.
As fierce_gt related, Anamorphic modes are intended for use with Anamorphic Lenses, who themselves correct the "Stretch". However one MUST be using such a expensive outboard A-Lens, and those individuals are in the extremely small minority...at least in comparison to the majority of PJ/Screen owners. Of course on AVS, if you chose the right Forum, there seems to be a veritable plethora of such users.
Ever since late 2012 when the PanasonicPT-AE8000u made the adjustments for optimizing the size of 2.35:1 / 16:9 a nearly a fully automatic process, and JVC followed suit closely thereafter, the "Poor Mans Scope Solution" has gained popularity. I myself immediately embraced the idea of using a border-less , as the vast majority of my posted Theater / Screen builds clearly indicate.
And I speak with the authority granted me by actual experience that in the ensuing years, and having listened to literally 10s of thousands of "live" comments, that virtually no one ever stated that it wasn't wholly desirable and cool. And that included 1080p content enlarged out to 144"-180" diagonal sized 2.35:1 . E-Shifted content and Native 4K is just gravy on the 2.40:1 potatoes.
Somewhat sadly, I feel that JVC is sorta lettin' down the Native 4K'ers by not making the sensing of Format changes fully Automatic. The same for Epson. But at least they do have the option.
post #18 of 30 Old 09-16-2019, 01:01 PM
sddp's Avatar
Quoted: 320 Post(s)
Liked: 127
Would a Graco TrueCoat 360 Paint Sprayer work?
EPSON 5040UBE | DENON X6400H | XBOX ONE X\PS4 | EMOTIVA XPA-7 GEN 2 |EMOTIVA XPA-3 GEN 3 | ELITE SCREEN 150" ZEREO EDGE W/LED KIT
9.3.4 SURROUND SYSTEM ALL KLIPSCH | L&R RF-7II | CENTER RC64II |FRONT HEIGHTS 2 x RB-81II | 4 SURROUNDS RS-62II | 4 ATMOS CDT-5800 | SUBS R112SW & 2 x R115SW
VEFXI 3D-BEE DIAMOND (2D TO 3D CONVERTER) | DARBE VISION DVP-5000S | LOGITECH HARMONY 800
sddp is offline
post #19 of 30 Old 09-16-2019, 01:21 PM - Thread Starter
biglen's Avatar
Quoted: 571 Post(s)
Liked: 109
[quote=sddp;58565946]Would a Graco TrueCoat 360 Paint Sprayer work?[/quote @MississippiMan would be the best person to answer that.
Sent from my SM-N975U using Tapatalk
biglen is offline
post #20 of 30 Old 09-16-2019, 01:49 PM
Liked: 1816
It could accomplish the job...to some degree or another, provided one knew exactly what to do to make it apply paint in the correct manner / volume.
However at the cost of the thing, there are better alternatives for no more than or less than it's cost, and they will almost assure you of a perfect end result.
post #21 of 30 Old 10-15-2019, 02:09 PM
Malodium's Avatar
Quoted: 49 Post(s)
Wait so, Black Flame paint isn't... black?
And here I was thinking it would not work for me. It looks more like a light brown. Is that correct? Dang maybe I need to do that after all......
Malodium is offline
post #22 of 30 Old 10-15-2019, 02:11 PM - Thread Starter
biglen's Avatar
Quoted: 571 Post(s)
Liked: 109
No, it's light gray.
biglen is offline
post #23 of 30 Old 10-15-2019, 05:36 PM
Liked: 1816
@Malodium
Actually, Black Flame is almost infinitely adjustable between being a light Silver'ish White (N/C) to a extremely Dark Neutral Grey that is for all intents and purposes a "Black Screen" (8.0)
One average the most used version is Black Flame v2.5 2.0 as it is excellent as a Neutral Light Silver hued screen being it also improves Contrast & Color saturation. The 2.0 designates the amount in Ounces of the BF Colorant is added. The higher the number (1 to 10) the darker the shade of Grey. (primarily for Ambient Light applications)
Black Flame N/C (no Colorant) is as close to being a Reference White Screen as any surface can be that also has Pearl & Silver Metallic content. Technically, it cannot be "Reference" because it does change up the reflected Image's contrast and color properties. Not as much as the darker Versions, but enough to amount to being "HDR in a Can". That's right...I said it. That's a first such reference I believe...
It's used as the Screen surface in Theaters with $20k projectors and in those with $500 projectors. Neither case is "slum'in.
post #24 of 30 Old 11-20-2019, 02:25 PM
aoaaron's Avatar
Quoted: 142 Post(s)
This does look amazing and beautiful.
Does anyone have an image showing the black levels?
aoaaron is offline
post #25 of 30 Old 11-20-2019, 03:10 PM - Thread Starter
biglen's Avatar
Quoted: 571 Post(s)
Liked: 109
Here's some screenshots on my Black Flame Interstellar screen.
biglen is offline
post #26 of 30 Old 11-22-2019, 02:59 PM
aoaaron's Avatar
Quoted: 142 Post(s)
Looks beautiful. Is that in a fully treated room?
Any clips with some ambient light?
aoaaron is offline
post #27 of 30 Old 11-22-2019, 03:45 PM - Thread Starter
biglen's Avatar
Quoted: 571 Post(s)
Liked: 109
All those pics are in a pitch black room treated with velvet on the ceiling, and the side walls near the screen. Here's a couple pics with some low lighting, from Lost in Space on Netflix.
biglen is offline
post #28 of 30 Old 11-23-2019, 07:38 AM
james111333's Avatar
Great picture, I'm just setting out on my research journey today.
james111333 is offline
post #29 of 30 Old 12-01-2019, 05:54 PM
TimHuey's Avatar
Quoted: 217 Post(s)
Liked: 57
Nah ah! That's amazing. I know camera's don't really show exactly what you see but still wow.
HTPC. Onkyo 636, Polk audio speakers and Klipsch sub. KHO-7 Outdoor speakers. Homeseer homecontrol over Z-wave.
TimHuey is offline
post #30 of 30 Old 12-04-2019, 02:01 PM
Oscarilbo's Avatar
Quoted: 28 Post(s)
I need this Black Flame paint (the commercial version) on my pull down screen, or maybe a the new DIY screen I'll work on, since my room is asymmetrical and the wall is uneven with thePJ. I have my own electric sprayer and have some experience painting my screen with it now.
Oscarilbo is online now
Reply DIY Screen Section
