DIY top masking - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 2Likes
post #31 of 54 Old 09-10-2019, 01:39 PM - Thread Starter
SJHT's Avatar
Quoted: 1091 Post(s)
Liked: 729
It depends of course on the length of the Roller Bar. But if you have the Bar Length right (...and you should...), 104" will do nicely
The roller bar is 106". This leaves some room if it doesn't roll up perfectly. I will paint it or line with black velvet so it doesn't show. The roller bar is silver in color. Thanks. SJ
SJHT is offline
post #32 of 54 Old 09-11-2019, 04:09 AM
DIY Granddad (w/help)
MississippiMan's Avatar
Quoted: 3611 Post(s)
Liked: 1672
Don't say that! If the Material is placed straight across the roller's Adhesive Tape, and the Roller itself is placed Level, you should get no "Barber Pole" wrapping at all. A 1/8"difference at one end from another across 104" of length will multiply quickly with every full rotation of the Roller.
It's no different from hanging a Electric Retractable Screen so that it's level. It simply MUST be done.
It doesn't take being much off to cause a real issue....but you have one thing going for you....the length of the Drop is small, so there won't be that much material to Roll up.
You should have at least 1.5-2 turns of Fabric still wrapped around the Roller when the material is extended to the Format Stop Point. Just like a regular Roller Blind, you don't roll it all the way out or you will risk detaching the material off the adhesive tape. If your concerned that the unwrapped Aluminum ends might show (must be a fairly shallow enclosure for that to be a concern...) then applying a Flat Black paint to the ends would be best. Any Fabric covering might cause inadvertent bunching along the edge if the Fabric isn't rolling up absolutely straight.
MississippiMan is offline
post #33 of 54 Old 09-11-2019, 06:21 AM - Thread Starter
SJHT's Avatar
Liked: 729
Yeah I intend to have it all level! . Could cut the roller to 104”, but really shouldn’t matter. I’m just going to paint the ends black if needed. SJ
SJHT is offline
post #34 of 54 Old 09-11-2019, 08:18 AM
Liked: 6
How I did mine ,This a standard Roll down shade bought the parts and added my own fabric from the fabric store. Not motorized ,Manual which is ok . Don't think you really need Velvet as it thick and heavy. This is fairly thin but blacks out just fine. Hardest part was getting the fabric perfectly level ..Glued it to the roller bar and added a rod on the bottom to weigh it down. that's a 120 inch screen
ZIRO is offline
post #35 of 54 Old 09-11-2019, 01:06 PM - Thread Starter
SJHT's Avatar
Liked: 729
Looks great. Per previous comments, the velvet material is not suppose to be thick or heavy. It is arriving today. SJ
SJHT is offline
post #36 of 54 Old 09-11-2019, 03:23 PM
Liked: 1672
It won't be.....heavy that is. In fact it would almost assuredly be as light as any other cloth that was opaque enough to block / swallow light.
@ZIRO
Not to say your solution isn't a commendable one.....in fact it looks highly professionally done.
post #37 of 54 Old 09-11-2019, 05:37 PM - Thread Starter
SJHT's Avatar
Liked: 729
@ZIRO
The material showed up. Wow, that’s dark and it is not heavy as you mentioned. SJ
SJHT is offline
post #38 of 54 Old 09-11-2019, 06:58 PM
Liked: 1672
I never said it was heavy...just the opposite.
post #39 of 54 Old 09-11-2019, 07:00 PM - Thread Starter
SJHT's Avatar
Liked: 729
That’s what I meant. Just not a good sentence.
SJHT is offline
post #40 of 54 Old 09-12-2019, 04:43 AM
Liked: 1672
B+ ain't bad.
Don't sweat it...it's not like I'm the epitome of sentence structure correctness. Now that I've read it again, I see it.
It certainly does gobble up light though! So much so that unless someone actually possesses some to observe it directly, they really cannot have a clue.
post #41 of 54 Old 09-12-2019, 06:28 AM
Rgb
Rgb's Avatar
Quoted: 602 Post(s)
Liked: 785
Now that my current pj, JVC RS420, has motorized lens shift and lens position memories, I can simply program the Harmony to set the bottom of the screen black margin border to the bottom of the image, then control the projector to shift the lens so the top of a 2.35 image is flush with a top fixed mask.
Funny it took ~20ys to get motorized lens shift/focus again like my first pj- a Mits X100 XGA
https://www.projectorcentral.com/Mitsubishi-X100.htm
https://www.hcinema.de/pdf/mitsubishilvpx100-en.pdf
Ahh, those were the days- $12K retail new for 200:1 contrast (On a good day), 600 lumens (Less after a week of use) and 1300hr bulb life (more like 600hrs if you wanted your lumens back)
And I was happy to pay $3K for a refurb in 1999!
Don't laugh- the original Panamorph lens was developed using the Chisholm branded version of this projector here in SE MI!
My 2nd pj also had motorized lens- PLV60, but neither had memories for position/focus. AE700 and subsequent Epsons all manual
Rgb is offline
post #42 of 54 Old 09-12-2019, 06:48 AM
Liked: 6
@ZIRO
Thanks and FYI behind the Projector screen is a 65inch 3D 4K for casual viewing
ZIRO is offline
post #43 of 54 Old 09-12-2019, 07:26 AM
Liked: 1672
@Rgb
Yes'sir!
I've watched as PJ mfg deleted convenience features to make units more acceptably affordable (since 1998). Just about everyone's PJs (...except the lofty 3-Gun CRTs...) catered to the Business sect, and the trickle down into Residential came about because so many of those Office /Boardroom PJs wound up being taken home for use.
While it may be hard for people today to relate to, absolutely there was a time when the gulf between having those who had a true Home Theater and those who use PJs for everyday entertainment was vast indeed. Lamp replacement was exorbitant. Lumen output minuscule. Resolution.....abysmally low. And that was the $10K+ units.
Just about everything else amounted to being in the realm of a Kenner Easy Show projectors.......
But for those of you who can claim hoary old status, the (Advent) Kloss Video Beam 1000 (circa '72) was the first Projection System primarily for TV viewing, (& BetaMax) and it's "huge" 60" wide "Silver Screen" was always a hit with the "kids".
Children too....
Name:	Kloss Video Beam 72.jpg
ID:	2614336   Click image for larger version
Name:	Kloss Kids .JPG
post #44 of 54 Old 09-12-2019, 07:32 AM - Thread Starter
SJHT's Avatar
Liked: 729
Does binding the sides create any issue with the roller since the ends will be double thickness? I can see why they need binding. Not sure there is a choice and maybe doesn’t matter. SJ
SJHT is offline
post #45 of 54 Old 09-12-2019, 07:32 AM
Liked: 1672
@SJHT
I can also see why the side need hemming. Has some binding material or something. You can see it in the fabric link you sent me. Assume the seamstress should fold this behind or cut off? Does hemming the sides interfere at all with proper roll up? Since the ends will be double material in thickness. Thanks. SJ
Yes....the Border Strip can / should be cut, and the edges hemmed when folded "once" over. The Fabric will roll up just fine if set straight on the Roller and the Carriage is level.
post #46 of 54 Old 09-12-2019, 07:40 AM - Thread Starter
SJHT's Avatar
Liked: 729
Changed my post because I realized the border is not on the sides, but rather top/bottom. The sides are just straight cut fabric. The top won’t show and the bottom will be hemmed for the bar. Guess in theory you could just leave the border as it won’t show?
SJHT is offline
post #47 of 54 Old 09-12-2019, 07:51 AM
Liked: 1672
Yeah...your right, and actually the Boarder end of the Fabric will adhere to adhesive strip on the roller better that will the fabric itself. But as to the Weight Bar, I would suppose that would be something for the Seamstress to judge.
post #48 of 54 Old 09-12-2019, 10:16 PM - Thread Starter
SJHT's Avatar
Liked: 729
Dropped off the material with the seamstress. Had to explain what I’m trying to do. Lol. I think she got it. She had the fabric spread out over a large table. Wow that is REALLY black. SJ
SJHT is offline
post #49 of 54 Old 09-13-2019, 09:44 AM
Liked: 1672
I know......and that is why if someone is really crowding a surface that is at right angle to a screen, nuthin'........ not nuthin' will absorb that light better than the Black Triple Velvet.
2nd best is ProtoStar material (Flocking for the Interior insides of Telescopes ) but that wondrous stuff isn't even as good when the light gets intense. It's meant to absorb low light that leaks inside a 'Scope.
Black paints....even the most saturated expensive types are still a distant 3rd
There is a Black Nano-Tube coating available that absorbs everything but you'd have to sell a vital Organ...(or 1st Born...) to afford it.
post #50 of 54 Old 09-13-2019, 02:54 PM - Thread Starter
SJHT's Avatar
Liked: 729
So I can mount so the material rolls off of the back of the roller or the front. The advantage of the back is that the material will be closer to the screen. The advantage of dropping from the front, is that the rolled up material which might slightly show will be the fabric backing vs. the velvet. I’m thinking rolling off the back is better and the fabric back is black anyway. Just not as black as the velvet front. Thanks for any suggestions. SJ
SJHT is offline
post #51 of 54 Old 09-13-2019, 04:29 PM
Liked: 1672
The Velvet should roll down /up from the rear of the roller. I've never built such a Roller Mask where the Roller assembly would be visible...it was always tucked up inside a Wood Casing (Valance) and set higher than the the Screen's casing. In fact...I've almost always used such a Mask with a Fixed Screen so the Valance's sole purpose was to hide the Roller Mask Bar.
post #52 of 54 Old 09-13-2019, 04:35 PM - Thread Starter
SJHT's Avatar
Liked: 729
The difference with my setup is that the valence is hiding the screen housing which is large as this is a drop down electric. I can easily hide the masking if I place in front of the housing but if I want to get close to the screen it has to be positioned under the screen housing which makes it more visible. Think I will play around and see what works best. Thanks. SJ
SJHT is offline
post #53 of 54 Old 09-13-2019, 06:34 PM
Liked: 1672
What about mounting the Roller Assembly to the inside Top of the Valence, above the Screen Housing?
post #54 of 54 Old 09-13-2019, 06:49 PM - Thread Starter
SJHT's Avatar
Liked: 729
That’s one option but it will put the mask further from the screen. I’m starting to think it won’t matter or even be noticeable. I will look when I get the hardware. Thanks. SJ
SJHT is offline
Reply DIY Screen Section
