Screen paint choice...Crumbs!!! - AVS Forum | Home Theater Discussions And Reviews
 4Likes
  • 1 Post By MississippiMan
post #1 of 9 Old 09-20-2019, 06:34 AM - Thread Starter
Liked: 0
Question Screen paint choice...Crumbs!!!
Hi there
Im hoping MississippiMan is about as this questions been asked before but it seems the answer is set up specific so i'm now very confused and hope its ok to ask for advice.
I'm in Scotland and have a Optoma UHD300x. The pj is in an all white room and looking to project onto wall screen with a diagonal of 100". I presently have a white 92" grandview but looking to get a larger ALR grey type screen but don't think i can afford it so now looking at diy painted screen.
I welcome any advice with thanks ☺
Pixl8 is offline
post #2 of 9 Old 09-20-2019, 09:23 AM
DIY Granddad (w/help)
MississippiMan's Avatar
Quoted: 3799 Post(s)
Liked: 1765
Lets switch from Cumbs to a Full Course solution
Originally Posted by Pixl8 View Post
Hi there
I'm glad you decided to come aboard and ask your questions. Never hesitate...that is exactly what this Forum is all about.
Your choices to create a Grey ALR screen will be determined by the availability (Local or Web-based) of certain components that ramp up the ALR performance factor to a level where your getting results decidedly superior to just a simple Grey Paint.
One thing you have on your side is your limiting your screen to 100" diagonal. That optimizes the 2200 Lumen output of the Projector.
Chief components you need to source are a fine flake White Pearlesecent and a clear Matte Polyurethane, both Water Based. The latter is often references in the UK as being a Clear Matte Water Based "Floor Finish" so looking under that designation can be fruitful. Finding a proper Silver Metallic will be a bit more problematical....but can be done. The proper White Paint (Dulux Ultimate White?) should be readily available to you however....and by tinting that White to a specified Grey, you can avoid the need to obtain the 4 separate Colorant Tints that make up the ultra dark Neutral Grey Colorant such advanced DIY Screen Paints usually require. It won't "quite" be the same, but will suffice in a pinch...and because your screen size is helping, and limitations in performance will be minimized.
The last choice would be to order a specific Screen paint designed to provide ALR performance, pre-mixed and ready to apply. All told the cost of the latter would still be far under the purchase price of even reasonably affordable, "truly proficient" Mfg ALR Screens.
Finally, be advised that to apply any high contrast Grey paint that has any really appreciable amount of true ALR properties, you need to spray on the paint. Rolling sets up sheen characteristics as well as potential issues such as visible Roller Marks.
There it is, your full course repast. Hope it all goes down easily. You might try a wee bit of some 100 yr old Scotch. Always works for me.
Pixl8 likes this.
MississippiMan is online now
post #3 of 9 Old 09-20-2019, 10:00 AM - Thread Starter
Liked: 0
Hi there and many thanks indeed for your help
You said "...by tinting that White to a specified Grey..." what would i used for that and what is the specified grey?
I'm certainly no videophile so can you suggest a low cost/mid ground ready made paint?
Also - I found these - Is this the kind of stuff i'm looking for?
Car Pearl White Electric Pearl Pigment Powder Metal Sparkle Shimmer Paint
https://www.ebay.co.uk/itm/100g-Car-...-/273861719574
Clear water-based floor varnish
https://www.wood-finishes-direct.com...BoCP8QQAvD_BwE
Ready Mixed Metallic Paint - Silver 600ml Water-Based
https://www.amazon.co.uk/Ready-Mixed.../dp/B009HOW4AO
Polyvine Metallic Silver Paint
https://www.stagedepot.co.uk/scenic-...hoCxY0QAvD_BwE
Dulux Trade Ultimate Weathershield Opaque White
https://www.amazon.co.uk/Dulux-Trade...86307898&psc=1
Pixl8 is offline
post #4 of 9 Old 09-20-2019, 10:10 AM
Liked: 1765
Give m time to review those alternative components and compile a suitable Mix.
Again...can you spray your screen? It's so small (sorry) that it should be extremely quick and easy.
Pixl8 likes this.
post #5 of 9 Old 09-20-2019, 10:20 AM - Thread Starter
Liked: 0
Hi - Really appreciate that thanks
Regards spraying - I've never sprayed anything more than an aerosol to be honest...Would i need specialised gear for that?
Oh and i can't find a thanks or like button fore your posts..can you show me where?
Pixl8 is offline
post #6 of 9 Old 09-20-2019, 10:36 AM
Liked: 1765
I found you your Pearl..........
I'll have to do some checking to find the correct Color Code of a Neutral Grey for the UK
If you manage to do a advanced DIY ALR Screen Paint application....you will quickly become a discerning Videophile.
These are the kind of Paints your looking for?
Pearlescent Paint (x 3)
https://www.amazon.co.uk/Deco-Art-Am...996728&sr=8-18
Clear water-based floor varnish (x1)
Polyvine Metallic Silver Paint (x1)
The gear is inexpensive,,,but it is the HVLP type. Here is one others have used here in the US and the UK
The Like button is over on the far right of each post, down toward the bottom.
Pixl8 likes this.
post #7 of 9 Old 09-20-2019, 10:45 AM - Thread Starter
Liked: 0
Thank you so much for your effort
So when i have the colour code - do i just buy a grey tint and mix it all up and apply?
Thing is it was my better halfs idea to paint on the wall as shes fallen out with the screen casing...Of course my initial idea was to paint the wall...funny that!!! ;D
Ah - found the Like buttons thanks..and a spray gun https://www.amazon.co.uk/VonHaus-800...58985561&psc=1
Just wondering - I have a 92" white Tab tensioned screen and the picture (obviously in darkened room) aint half bad...I've just spotted another Grandview except NOT TT and 106"...Are these all made from same material - Mines is the Large Flat Series?
Pixl8 is offline
post #8 of 9 Old 09-20-2019, 12:00 PM
Liked: 1765
The Paint Store you purchase the Paint fromwill tint and mix it up.
You will have to mix everything else together along with it in a separate container, strain it, and the squirt. We'll go over the technique later.
I have successfully painted onto Matte White TT screens with fantastic results:
https://www.avsforum.com/forum/110-d...2-5-4-0-a.html
Pixl8 likes this.
post #9 of 9 Old 09-20-2019, 01:04 PM - Thread Starter
Liked: 0
Wink
Okydoke thats grand and again many thanks
I remember looking at that thread before i think...great pic in daylight... Looking forward to the technique talk lol
Pixl8 is offline
Reply DIY Screen Section
