Listening To Now In Surround - Page 145 - AVS Forum | Home Theater Discussions And Reviews
 10568Likes
post #4321 of 4672 Old 02-28-2020, 06:09 AM
weekendtoy's Avatar
Quoted: 621 Post(s)
Liked: 1883
I've had the Real Live Roadrunning disc for years and it plays on an Oppo 83, 105, & 203 without issue.
Is the importCD release different from the one on Discogs? Mine is catalog # 44417-2, region code 1.
I reject your reality and substitute my own.
weekendtoy is offline
post #4322 of 4672 Old 02-28-2020, 07:44 AM
kokishin's Avatar
Quoted: 1461 Post(s)
Liked: 1607
I believe they got this version: https://www.discogs.com/Mark-Knopfle...elease/2896878 which someone notated on Discogs is Region 2-6.
REGION 1 -- USA, Canada
REGION 2 -- Japan, Europe, South Africa, Middle East, Greenland
REGION 3 -- S.Korea, Taiwan, Hong Kong, Parts of South East Asia
REGION 4 -- Australia, New Zealand, Latin America (including Mexico)
REGION 5 -- Eastern Europe, Russia, India, Africa
REGION 6 -- China
REGION 7 -- Reserved for Unspecified Special Use
REGION 8 -- Reserved for Cruise Ships, Airlines, etc...
REGION 0 or REGION ALL -- Discs are uncoded and can be played Worldwide, however, PAL discs must be played in a PAL-compatible unit and NTSC discs must be played in an NTSC-compatible unit.
Bill Mac likes this.
Denon AVR-X6200W, Outlaw Audio 7125 Amp, Oppo UDP-203, Oppo BDP-103, Amazon FTV Stick 4K, Tivo Roamio Pro, Pioneer Elite Andrew Jones Dolby Atmos Enabled EFS-73 Fronts/EBS-73 Surrounds, Chane A2.4 Center, SVS SB-2000 Sub, Panasonic Plasma TH-58PX600
avsforum Members Atmos & Auro Configuration Spreadsheet
I'm just a caveman. Your modern world frightens and confuses me. RIP Phil Hartman
kokishin is offline
post #4323 of 4672 Old 02-28-2020, 11:09 AM
weekendtoy's Avatar
Quoted: 621 Post(s)
Liked: 1883
Originally Posted by kokishin View Post
Bill,
What's the issue?
Oppo 205 can play a PAL DVD disc and convert it to NTSC.
If it's a region code issue, then you can create a Superdisc as found on the Oppo website to unlock your 205: https://www.oppodigital.com.au/pages...ll-dvd-regions
If you need help with the Superdisc, PM me.
Just to be clear, the Superdisc only works with DVD's and not Blu Ray's? I have a Metallica Blu Ray I can't play because of region codes.
post #4324 of 4672 Old 02-28-2020, 11:14 AM
kokishin's Avatar
Liked: 1607
Just DVD's.
kokishin is offline
post #4325 of 4672 Old 02-28-2020, 02:34 PM
Bill Mac's Avatar
Quoted: 2351 Post(s)
Liked: 3653
Bill,
What's the issue?
kokison,
Actually it's a region issue as Matt mentioned and not an NTSC issue. I tried the DVD in my 103 and 205 with the same incorrect region warning. Will that Superdisc work with the 103? As always thank you for your help !
This is the version I got from Grooves Inc. https://www.discogs.com/Mark-Knopfle...elease/2896878
Bill
My SACD collection and HRAudio.net Library, getting larger as my wallet gets smaller ;-).
Emotiva XMC-1, Wyred 4 Sound STP-SE (preamp), SX-500s, ST-500, ST-250, Oppo UDP-205, UDP-203, BDP-105, BDP-103, BDP-93, BDP-83, Panasonic TC-P60GT50, Panamax 5100EX, Salk HT2-TLs, Salk 1801b center, Salk 1801TL (surrounds) and two Rythmik F12SEs.
Bill Mac is offline
post #4326 of 4672 Old 02-28-2020, 05:37 PM
Matt2026's Avatar
Quoted: 1138 Post(s)
Liked: 30820
Originally Posted by Bill Mac View Post
kokison,
Bill
Hi Bill,
Okay, I cleared Persistent Memory just to make sure nothing was left over from my first attempt to play the DVD. I also unplugged it, held in the power button 10 seconds, left it unplugged for over an hour while I talked to my son. I got off the phone, plugged in the OPPO, popped in the SuperDisc I got at the URL above provided by @kokishin on the OPPO site. I'm on a Windows 7 computer which automatically opened a disc burning utility. No visual indication, just a blank screen for a second or two and out came the disc. Put the DVD in and BINGO! It works.
Okay I'm off to watch/listen to the "concert",
Thanks again kokishin
Matt2026 is online now
post #4327 of 4672 Old 02-29-2020, 02:53 AM
kokishin's Avatar
Liked: 1607
kokison,
Bill
The Superdisc works on the 103 too.
kokishin is offline
post #4328 of 4672 Old 02-29-2020, 12:36 PM
sworth's Avatar
Quoted: 673 Post(s)
Liked: 482
When you get a region warning, you have to start the disc again and just before it starts hit stop. That will make it so it won't just jump straight back to the warning screen. Then take the disc out, change your region and start it again and it will work. This way is a lot better than clearing your memory and having to set the region again for every out of region disc you own.
sworth is offline
post #4329 of 4672 Old 02-29-2020, 01:30 PM
Bill Mac's Avatar
Liked: 3653
Huh? Where in the menu for Oppo players is the "change your region" setting?
Bill
Bill Mac is offline
post #4330 of 4672 Old 02-29-2020, 01:48 PM
Matt2026's Avatar
Liked: 30820
Bill
Ya got me Bill. I did as noted, didn't select any region. After loading the SuperDisc, (~2 seconds) the REAL★LIVE ROADRUNNING DVD played just fine. A bit later I popped in Judge Dredd DVD and it worked as usual. I may try a couple more later and verify the "REAL★LIVE ROADRUNNING " disc still plays.
Using a mod kit to get all region Blu-ray playback may require setting the region code.
post #4331 of 4672 Old 02-29-2020, 01:59 PM
SeeMoreDigital's Avatar
Quoted: 1190 Post(s)
Liked: 1036
There isn't one. After installing the Superdisc software, when playing DVD's with different regions, they just play! (Shame it's not the same for region coded Blu-ray discs).
Sufficed to say... Your TV will need to support both NTSC [60Hz] and PAL [50Hz] in order to view the images from all six of the main DVD regions
I SUPPORT 'FAIR USE'. MY MORALS PREVENT ME FROM HELPING ANYONE WHO OBTAINS COPYRIGHTED CONTENT ILLEGITIMATELY
TV: LG 65UH770V | DISC SPINNER: OPPO UDP-203 | STB: VU+ UNO 4K SE
AMPS: 1No Audiolab 6000A, 3No Audiolab M-PWR | SPEAKERS: 2No KEF 103.2, 6No Wharfedale Diamond 10
ISP: Virgin Media @ 100Mbps | NETWORK: 1000Mbps | NAS: Synology DS212+
SeeMoreDigital is offline
post #4332 of 4672 Old 02-29-2020, 02:03 PM
Bill Mac's Avatar
Liked: 3653
Originally Posted by SeeMoreDigital View Post
There isn't one. When playing DVD's with different regions, they just play! (Shame it's not the same for region coded Blu-ray discs).
SMD,
Thanks! I really wonder why some here post suggestions that have absolutely no validity . My plasma is just NTSC so I'll give the Superdisc a shot.
Bill
Bill Mac is offline
post #4333 of 4672 Old 02-29-2020, 02:10 PM
Matt2026's Avatar
Liked: 30820
Bill
I just fired up the OPPO, put in the "REAL★LIVE ROADRUNNING " disc and it started right up. Then tried Donald Fagen's Kamakiriad DVDA, no problem; The Treasure of the Sierra Madre DVD, no problem and lastly 2001 Blu-ray (since I hadn't played one yet) and it worked.
post #4334 of 4672 Old 02-29-2020, 02:12 PM
Liked: 1036
As I'm in the UK I'm in DVD region 2. But I have DVD's from regions 1 to 5 (and one from region 8). And they all load and play automatically with the BDP-103 and UDP-203...
That being said... I can't remember the last time I actually watched a movie (all the way through) on DVD
post #4335 of 4672 Old 02-29-2020, 02:14 PM
kokishin's Avatar
Liked: 1607
Nah, the Oppo's will convert PAL to NTSC.
My 2006 Pany Plasma does not support 50Hz and works fine playing a PAL disc.
Oppo's disc players are amazing machines for all the capabilities they offer.
kokishin is offline
post #4336 of 4672 Old 02-29-2020, 02:20 PM
Liked: 1036
That may well be the case... But such PAL to NTSC (and vice-versa) conversions can effect the colours of the image.
post #4337 of 4672 Old 02-29-2020, 02:24 PM
kokishin's Avatar
Liked: 1607
Never noticed and not particularly concerned because the Oppo's do a stellar job in general; at least to my satisfaction.
kokishin is offline
post #4338 of 4672 Old 02-29-2020, 08:07 PM
Matt2026's Avatar
Liked: 30820
. . . . . . . . . . . .PAUL
. . . . . . McCARTNEY
. . . . . . . AND WINGS
=ROCKSHOW=
(Blu-ray: dts-HD Master Audio 5.1)
Name:	PAUL McCARTNEY AND WINGS ROCKSHOW (Blu-ray dts-HD Master Audio 5.1).jpg
post #4339 of 4672 Old 03-01-2020, 10:27 AM
sworth's Avatar
Quoted: 673 Post(s)
Liked: 482
My Oppo is region free. I can switch regions. It remembers the last point played in a disc. If that is the region warning screen, it defaults back to that every time you play it and gets stuck in the wrong region. In order to get it to reset, you have to hit stop just as it is starting up. That clears the default and lets you switch region, without having to entirely clear your cache. It is a royal pain to clear the cache because the player defaults to the last played point on every disc you've played, so even if your player is set for the wrong region, it will jump to the last place played and remember the region code. If you clear the cache it forgets all that and you have to switch regions manually all over again.
sworth is offline
post #4340 of 4672 Old 03-01-2020, 12:26 PM
mavericks64's Avatar
Quoted: 26 Post(s)
Liked: 25
=ROCKSHOW=
Matt2026 I really enjoyed Rockshow.
JBaumgart and Matt2026 like this.
Sharp 80-inch 3D LED TV, Yamaha RX-A3070 Receiver, Outlaw 5000 Amplifier
Paradigm Reference Studio/100 v.2 front speakers Paradigm, Studio CC-690 center-channel
Paradigm CI Pro P80-IW Side Surrounds, Paradigm Monitor 9 rear surrounds, 4 CI Pro P80-R overheads
FV15HP Rythmik subwoofer
mavericks64 is offline
post #4341 of 4672 Old 03-01-2020, 04:37 PM
weekendtoy's Avatar
Quoted: 621 Post(s)
Liked: 1883
David Gilmour: Live At Pompeii (Blu Ray 5.1)
kevin j, Bill Mac, bguzman and 7 others like this.
post #4342 of 4672 Old 03-01-2020, 05:55 PM
bguzman's Avatar
Quoted: 192 Post(s)
Liked: 1290
Dire Straits ‎– Brothers In Arms
Label: Vertigo ‎– 9871498
Format: SACD, Hybrid, Multichannel, Stereo, Album, Remastered, HDCD, 20th Anniversary Edition
Country: Europe
Released: 23 May 2005
Genre: Rock
Style: Classic Rock
HT TCL 55P605, BenQ W7000, Pioneer UDP LX500, Panasonic LX1000, Firestick 4K, ATV4K, Pioneer SC-LX701, DefTech, Klipsch, Martin Logan, SVS @ 5.2.4 Atmos
Music Sansui SR-4050, SR-3030, Dual 1219, Pioneer BDP-85FD, Emotiva PT-100, Sherwood Newcastle R-972, Polk Monitor 10 & 5, SVS SB1000
bguzman is offline
post #4343 of 4672 Old 03-01-2020, 07:12 PM
Matt2026's Avatar
Liked: 30820
Same for me. I think it was 5 ★★★★★ worth of entertainment
post #4344 of 4672 Old 03-01-2020, 07:56 PM
bguzman's Avatar
Quoted: 192 Post(s)
Liked: 1290
=ROCKSHOW=
I’ve been enjoying this for some time as you can see from my copy of this fantastic concert. Maybe it is time for an upgrade.
bguzman is offline
post #4345 of 4672 Old 03-02-2020, 12:19 PM
Brent M. Wagner's Avatar
Country: Europe
Genre: Rock
Style: Classic Rock
One of my favorites as well.
mavericks64 likes this.
Brent M. Wagner is offline
post #4346 of 4672 Old 03-02-2020, 05:09 PM
Matt2026's Avatar
Liked: 30820
THE WALLFLOWERS
. . . .C O L L E C T E D: 1 9 9 6 - 2 0 0 5
(DVD: dts & DD 5.1)
Name:	THE WALLFLOWERS COLLECTED 1996 - 2005 (DVD Audio 5.1).jpg
JJHXBR and drh3b like this.
post #4347 of 4672 Old 03-03-2020, 08:19 AM
chevman's Avatar
Quoted: 96 Post(s)
Liked: 69
So I have listened to this 1812 Overture a hundred times on my old Klipsch RF-7's, RC & RS 7's with my old SVS 20-39PC+ Sub and thought it sounded pretty good. I just ran it through the new Klipsch Forte 3's, in ceiling CDT 5850's, B&K Sounds CSC1 center and dual SVS SB3000's.... I thought I sharted when the cannons fired. Never. Not a single time in my life have I experienced that before. I had my eyes closed and was enjoying the music knowing the cannons were about to fire, I had my system louder than I normally listen, and it scared me so much I jumped and turned the volume down. WOW, what a major sound improvement on this disk. Good night nurse, it was incredible. I don't know if it is because it is more of a mid-range tone and since the Forte's have that advantage over the RF's or what it was, but I was blown away. Anyway, I just wanted to share. Have a great day.
Video: 65" Sony 900X XBR; Sony X800M2 Blue Ray; OTA Tivo Roamio; Apple TV 4K
Audio Electronics: Rotel Pre-amp RSP-1066, RMB-1075 120x5 Amp; Schiit Modi 2 Uber DAC; Denon 2930CI DVD; MiniDSP DDRC-88A/BM
Speakers: Klipsch Forte III, CDT-5800 II (Surround); B&K Sounds CSC-1 (Center); Dual SVS SB 3000's
chevman is offline
post #4348 of 4672 Old 03-03-2020, 09:18 AM
sworth's Avatar
Quoted: 673 Post(s)
Liked: 482
You wouldn't want to play the Mercury Living Presence 1812 at a very loud volume. It has a massive spike on the cannon shots that would pop your woofers. My dog hates that version.
weekendtoy, chevman and morgiastic like this.
sworth is offline
post #4349 of 4672 Old 03-03-2020, 10:20 AM
Matt2026's Avatar
Liked: 30820
Memories... Back in the mid 80's I had "The Receiver" by Carver and was listening to the 1812 a bit too loudly and when the cannon fired it did blow out one of the woofers in one of my ADS L1290 speakers
post #4350 of 4672 Old 03-03-2020, 02:50 PM
chevman's Avatar
Quoted: 96 Post(s)
Liked: 69
I ran a search for that version, looks like it is only in Vynal, does that sound right? Sad if so, I have no turntable or place for one.
chevman is offline
Reply Surround Music Formats
