Dutton Vocalion SACDS - Page 5 - AVS Forum | Home Theater Discussions And Reviews
 67Likes
post #121 of 140 Old 09-04-2017, 01:40 PM
Bill Mac's Avatar
Quoted: 2206 Post(s)
Liked: 3342
Originally Posted by thehun View Post
That maybe was true in your case however projecting that to the endless variations of other set ups and users would not be wise. Same way I'm not saying that all Sab/sut will equal or better all floor standing set ups, I'm simply saying one should not make some arbitrary rules to all based on a single experience. Naturally I've heard many different set ups and I don't have a clear favorite based on that.
It's interesting that you state "one should not make some arbitrary rules to all based on a single experience". Where in my earlier post did I infer my experiences were an absolute or should be applied to endless variations? I was posting my experiences in my room nothing more. The fact that you don't have a clear favorite is fine and is your opinion. That's cool with me. But the fact that I have a different opinion than yours leads you to believe I have no other experience listening to different systems. With that assumption you are dead wrong.
I've heard many different surround systems over the years. Some much more elaborate than my system and some that were not. With a few of those systems going from small surrounds to full range surrounds. On each occasion the addition of full range surrounds was a noticeable SQ improvement for surround music especially quad mixes. I'm not sure how one would not prefer a surround speaker that has the capability to reproduce more of the audio range (for multichannel music) than one that does not. But that's just my opinion and not some "arbitrary rule" .
Bill
My SACD collection and HRAudio.net Library, getting larger as my wallet gets smaller ;-).
Emotiva XMC-1, Wyred 4 Sound STP-SE (preamp), SX-500s, ST-500, ST-250, Marantz SA-10, Oppo UDP-205, UDP-203, BDP-105, BDP-103, BDP-93, BDP-83, Panasonic TC-P60GT50, Panamax 5100EX, Salk HT2-TLs, Salk 1801b center, Salk 1801TL (surrounds) and two Rythmik F12SEs.
Bill Mac is offline
post #122 of 140 Old 09-04-2017, 02:36 PM
thehun's Avatar
Quoted: 1121 Post(s)
Liked: 1132
So who implying/assuming what now?
Bill
LOL see what you did there? Probably not. The so called full range speakers don't reproduce any more FR's[audio range] than a sub/ sat system, it's usually the opposite since any decent sub will destroy the low end of most floor standing speakers.
Anyway there is a ton of research on this.....
De sagittis Hungarorum libera nos, Domine!
Attention, don't read my posts if you're a snowflake or easily offended.
The Hun
thehun is offline
post #123 of 140 Old 09-04-2017, 02:47 PM
Bill Mac's Avatar
Liked: 3342
Mind pointing out what I was implying/assuming .
Well again your assumption is wrong . In that I'm using my full range surrounds with Rythmik F12SE subs. Didn't see that coming did you . All things being equal (used with subs) in your opinion full range surrounds have no advantage over small satellite speakers? When I say equal same gear and room just swapping out surround speakers
Bill
Bill Mac is offline
post #124 of 140 Old 09-04-2017, 02:54 PM - Thread Starter
sworth's Avatar
Quoted: 620 Post(s)
Liked: 409
I blocked that guy. He just wants to argue.
My old surrounds went down to 80Hz, but at high volumes they couldn't keep up with my mains. I swapped them for some really nice speakers and now I can get the volume up. All my speakers are full range, but the crossover to the sub stays at 80Hz. My sub is MUCH more efficient at putting out sub bass than any full range speaker. My other speakers perform better above 80Hz because they don't have to strain to produce sub bass. More efficient sounds better. That's why we have bass management.
If you don't have a good sub then you would want full range speakers, but with a sub the ability to go loud without blowing out is the main limitation to small inexpensive rears, not the ability to produce sound below 80Hz. The size of the room matters too, because the larger the room, the more powerful the speakers have to be to fill it.
JA Fant likes this.
sworth is offline
post #125 of 140 Old 09-04-2017, 03:22 PM
Bill Mac's Avatar
Liked: 3342
I agree with your thoughts as far as the advantages of full range surrounds when compared to smaller surrounds. You make a valid point in that the full range surround will be able to handle more power and volume where a smaller speaker will be at a disadvantage.
Bill
Bill Mac is offline
post #126 of 140 Old 09-04-2017, 03:36 PM
thehun's Avatar
Liked: 1132
The very things you keep denying it's all there...
Well once again your assumptions are wrong . In that I'm using my full range surrounds with Rythmik F12SE subs.
Oh boy here we go.... But your "argument" wasn't about the sub was it but rather the mid range, since you must have used the same sub with your previous speakers didn't you?
What the second grader retort? I fully confess I expected a little more indeed.
Bill
There is no such thing as being "equal" every type of speakers need a different tailored set up, you can't just swap things out. But just for simplify things: Yes
it could, depends how small the satellite speaker was,[ and when I say "satellite" I mean anything between a Bose cube to a large bookshelf with multiple mid range and even bass driver], did it have a dedicated sub, and of course what do you replacing it with, since not all tower speakers are "equal" or even full range. The real advantage is it's simpleness, it's much easier to blend a "full range" tower speakers with a sub because the xo pint will be lower and therefore much less chance to localize the sub which ease it's placement or hear any phase issues.
It is much harder to set up a sub/sat system to perform to it's maximum, especially the rear/side surrounds. So yes if you wanna take the easy way and spend money on a new larger speaker it might just work out better just by replacing your old ones, but there is no guarantee.
The Hun
thehun is offline
post #127 of 140 Old 09-04-2017, 03:43 PM
Bill Mac's Avatar
Liked: 3342
C'mon man so serious, where's your sense of humor .
Well said and informative, thank you!
Bill
Bill Mac is offline
post #128 of 140 Old 09-04-2017, 03:45 PM
thehun's Avatar
Liked: 1132
Bill
yes efficiency is an advantage indeed, if my goal is simply to go super loud I would employ large full range speakers with even larger subs .No one argues that, you might wanna tell that to sworth since he ignores me now. What a difference a week makes last week it was you he called out.
No I don't wanna argue at all, I made my points and as I said there are lots of research out there from people who do this for a living.
Bill Mac likes this.
The Hun
thehun is offline
post #129 of 140 Old 09-04-2017, 03:46 PM
thehun's Avatar
Liked: 1132
Bill
Touche!
The Hun
thehun is offline
post #130 of 140 Old 09-05-2017, 07:08 AM - Thread Starter
sworth's Avatar
Quoted: 620 Post(s)
Liked: 409
Not you. You're fine! It's the other guy.
By the way, full range all around with a big sub is my theory exactly. My theater room is pretty big, so I have to pump up the volume to fill the room. It was simpler when I lived in an apartment and there wasn't so much space to fill.
sworth is offline
post #131 of 140 Old 09-27-2017, 07:54 AM
weekendtoy's Avatar
Quoted: 547 Post(s)
Liked: 1346
Latest Dutton Vocalion release
Another two-fer like Pure Prairie League. I sampled a few songs on YouTube and sounds like a jazz-rock-funk combo platter.
Pre-ordered!
https://www.duttonvocalion.co.uk/pro...prod=CDSML8532
Bill Mac and JJHXBR like this.
weekendtoy is offline
post #132 of 140 Old 09-27-2017, 08:50 AM - Thread Starter
sworth's Avatar
Quoted: 620 Post(s)
Liked: 409
I had those albums when I was a kid. It's proto-smooth jazz. Hubert Laws was on the same record label. Jazzy elevator music. The jazz version of the 2001 theme is funny though. I don't remember this being in quad. Is it a remix? I wonder if this one will have bass?
sworth is offline
post #133 of 140 Old 09-27-2017, 01:00 PM
Bill Mac's Avatar
Liked: 3342
Pre-ordered!
I listened to one of the Deodato albums in this set and enjoyed the music. A definite buy without a doubt. Hopefully there'll be many more DV multichannel SACD releases in the near future !
Bill
JJHXBR likes this.
Bill Mac is offline
post #134 of 140 Old 11-04-2017, 04:12 AM
Bill Mac's Avatar
Liked: 3342
Got a chance to listen to Deodato's Prelude & Deodato 2 multichannel SACD the other day. This is from a group I'd never heard of and features two of their albums. Another excellent sounding quad mix from Dutton Vocalion! The music is hard to pinpoint but it reminds me of early Chicago. Every SACD I've bought from DV has been excellent! The prices are excellent as well.
Bill
weekendtoy and JJHXBR like this.
Bill Mac is offline
post #135 of 140 Old 11-04-2017, 10:45 AM - Thread Starter
sworth's Avatar
Quoted: 620 Post(s)
Liked: 409
The genre on that is proto-smooth jazz.
sworth is offline
post #136 of 140 Old 11-04-2017, 11:17 AM
JJHXBR's Avatar
Quoted: 84 Post(s)
Liked: 164
Bill
I have a slew of these Multi-Channel Dutton Vocalion SACD's and find them very enjoyable. I don't have Prelude & Deodato 2 so I'll have to check it out after hearing your positive feedback.
One of the other titles I don't have and really want to hear is: "Tower of Power - Ain't Nothin' Stoppin' Us Now" MCH SACD
Available Here: https://www.duttonvocalion.co.uk/pro...prod=CDSML8523
Grew up in the S. F. Bay Area and have seen Tower of Power and Cold Blood many times.
HT Setup: Speakers - M&K S-5000 Monitors FL-C-FR-RL-RR on ST-1 titling stands - M&K B1600 Height speakers - 2x M&K MX-350 Mk II Subs - M&K SS-500 Dipole side surround speakers - M&K SW-85 surround back speakers
Denon AVR 4810CI - B&K 7270 THX 7 Channel Amp - Oppo BDP-203 - QNAP TVS-863+ Turbo NAS 32TB - LG OLED 65" C8 My Partial SACD Collection
JJHXBR is offline
post #137 of 140 Old 11-05-2017, 09:48 AM - Thread Starter
sworth's Avatar
Quoted: 620 Post(s)
Liked: 409
It seems they do better on the rock and jazz fusion than they do with orchestral and big band. Maybe they figure that is what the market is interested in so they spend time on it.
sworth is offline
post #138 of 140 Old 11-05-2017, 03:02 PM
ti-triodes's Avatar
Quoted: 516 Post(s)
Liked: 1114
Anyone get this? I was wondering how it sounds. There's a bunch of classic soul tunes on it.
ti-triodes is offline
post #139 of 140 Old 05-17-2019, 05:14 PM
Bill Mac's Avatar
Liked: 3342
I received an email from Dutton Vocalion today and there was some great news!
Our next batch of titles, due soon, comprise a tantalizing selection of soul, Latin, jazz and rock reissues, all of which are in the SACD format. Full details will be sent nearer the time; meanwhile, keep an eye on the Vocalion website for updates.
Bill
Bill Mac is offline
post #140 of 140 Old 06-16-2019, 05:11 AM
Tornado Red's Avatar
Quoted: 592 Post(s)
Liked: 1213
Tornado Red is offline
Reply Surround Music Formats
