SACD decoding question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 11-27-2019, 09:59 AM - Thread Starter
fireprix's Avatar
Quoted: 35 Post(s)
Liked: 26
I bought Blue Oyster Cult Secret Treaties on SACD. I believe it is supposed to be the quad version 4.0 However when I play it back it is in 5.1 Playback is on an Oppo BDP-103D connected via HDMI to an Integra DHC40.2 I don’t have the analog multichannel outputs connected. The Oppo sends DSD to the Integra. I’d have to check the Oppo but the Integra shows it is receiving and outputting 5.1 Not that I’m complaining but would like to hear the quad mix if possible. Thanks.
fireprix is offline
post #2 of 7 Old 11-27-2019, 11:08 AM
antisuck's Avatar
Quoted: 137 Post(s)
Liked: 180
This is the release that has the quad mix: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
If that's the disc you got, have you walked up to your center channel speaker and listened to see if anything is coming out of it? Perhaps it's encoded as 5.1 but there is actually no audio in the center or LFE channels.
antisuck is offline
post #3 of 7 Old 11-27-2019, 12:01 PM
Quoted: 98 Post(s)
Liked: 739
All four of the SACD players I've had have only ever displayed tracks from the "Multi-Channel Area" as either 5.0 or 5.1 regardless of the amount of actual full range channels. As antisuck said, if you put your ear next to a speaker associated with a channel that shouldn't be in use (like the centre channel on a Quad mix or the rear channels on a three-channel stereo mix) you won't hear anything. I am surprised it would show .1 for a Quad mix, but perhaps they did a 4.1 mix.
Morgan
morgiastic is online now
post #4 of 7 Old 11-27-2019, 12:02 PM
Tornado Red's Avatar
Quoted: 603 Post(s)
Liked: 1466
Pretty typical for the Oppo players to show a quad mix as 5.0 or 5.1, can't speak to your Integra though. As the poster above stated, have listen to your centre channel to be sure what you have.
Tornado Red is offline
post #5 of 7 Old 11-27-2019, 12:41 PM - Thread Starter
fireprix's Avatar
Quoted: 35 Post(s)
Liked: 26
I will have to listen again. Although I’m pretty sure I have sound output from both the center and subs. I do run my fronts as full range and have the double bass enacted which may explain the subs but not the center.
fireprix is offline
post #6 of 7 Old 12-04-2019, 09:07 PM - Thread Starter
fireprix's Avatar
Quoted: 35 Post(s)
Liked: 26
Finally got around to listening to this again. The Oppo shows it as 5.0 and the Integra shows it as 5.1 guessing due to bass management.
fireprix is offline
post #7 of 7 Old 12-04-2019, 09:13 PM - Thread Starter
fireprix's Avatar
Quoted: 35 Post(s)
Liked: 26
My bad. Never actually put my ear up to center speaker to verify. Somehow it just always sounded like the vocals were coming from the center. However the center does not emit a peep.
fireprix is offline
Reply Surround Music Formats
